4 wheel drive on a 98 tacoma with locking hubs
Discussion in '1st Gen. Tacomas (1995-2004)' started by tenn, Jan 24, 2012.
  1. Jan 25, 2012 at 6:01 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Do the greywire mod, get some good tires on there, and a lift kit, and your truck will take you just about anywhere you can think to go.
  2. Jan 25, 2012 at 6:02 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You're mistaking "locking hubs" with a "locking differential."
    These are totally different things.
    Without the hubs "locked" no front wheel has power delivered to it.
    With both front hubs "locked", the open differential will equalize power distribution across both front wheels. If one wheel has no traction, then it can spin at full speed with basically zero torque, so zero torque is delivered to the other wheel. That's what an open differential does.
    Left rotation speed * Left Torque == Right Rotational Speed * Right Torque.
    When you've got a wheel on a zero friction surface, zero torque is required to spin the wheel, so:
    100 RPM * .001 torque == .001 RPM * 100 torque. And so the wheel with traction does not move - well, it does, but so slowly as to do you no good at all.
    The reason you feel bind when you're in 4 wheel drive is NOT because the front wheels are unable to move independently, but rather, because the center transfer case has no differential. So one front wheel, and one rear wheel must always rotate at exactly the same speed. However, as soon as you turn the steering wheel, all four wheels prescribe a slightly different radius arc, so they would all naturally rotate at a slightly different rotational speed, if they were free to do so.
    They are not - and this resistance is the bind you perceive.
    Hope this helps.
  3. Jan 25, 2012 at 6:02 PM
    tenn
    tenn [OP] Active Member
    98 Tacoma 4x4 v6 auto trans.
    yes as far as i know
  4. Jan 25, 2012 at 6:03 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    If it has a rear diff lock it there should be a swith to the left of the steering wheel, that says RR diff lock
  5. Jan 25, 2012 at 6:05 PM
    tenn
    is a diff located in both axels
  6. Jan 25, 2012 at 6:07 PM
    tenn
    it does not. but in the 98 model does it come with open diff or locking diff? front and back?
  7. Jan 25, 2012 at 6:08 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Yes a "diff" is short for differential. 4x4's have front and rear differentials.
    If it is not a TRD it came with open differentials in both the front and rear.
  8. Jan 25, 2012 at 6:11 PM
    tenn
    so the 4x4 is not as good as it could be
  9. Jan 25, 2012 at 6:12 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    No, but depending on how extreme you plan to go it is fairly capable as it sits.
  10. Jan 25, 2012 at 6:15 PM
    tenn
    is it possible to put a locking diff in the front? or in the back? and if so how much trouble is it
  11. Jan 25, 2012 at 6:21 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Yes it is possible to install lockers in both front and rear. The air actuated lockers (ARB) are about $1000 a piece and need to be installed by someone who has experience on working with differentials, most 4x4 shops can do it. Most people install a locker in the rear first, then if they feel they need the extra traction, install a front locker. You would be surprised at what an locked rear diff and an open front diff will get you over.
  12. Jan 25, 2012 at 6:22 PM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    My truck came with a electronic rear diff lock. I put a lunch box locker in the front, so now both diffs can be locked at the same time. Anytime there is power going to the front diff, it is locked. If I only want one wheel to pull, I just lock one side.
  13. Jan 25, 2012 at 6:23 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Or this^
  14. Jan 25, 2012 at 6:23 PM
    tenn
    if i put a locking rear in will the rear wheels ALWAYS spin together or is there away to "disengage" it when driving on the highway?
  15. Jan 25, 2012 at 6:25 PM
    #35
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    It depends on what brand you go with. The ARB locker is turned on/off with the flip of a switch, but those do require a compressor to engage the locker.
  16. Jan 25, 2012 at 6:25 PM
    #36
    tenn
    by lock in one side you mean the hubs?
  17. Jan 25, 2012 at 6:26 PM
    #37
    tenn
    will it hurt to get a locking rear diff that is full time and use it for casual driving
  18. Jan 25, 2012 at 6:27 PM
    #38
    tenn
    what do u mean by a compressor?
  19. Jan 25, 2012 at 6:31 PM
    #39
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    I wouldn't recommend it, it will handle alot differently esp. on slick surfaces.
    This was taken from another thread.
    The Powertrax locker is a no-slip type, meaning that when one tire starts to slip the locker automatically engages. In which case you have no control over.
  20. Jan 25, 2012 at 6:32 PM
    #40
    tenn
    are there any locking rear diff that do not require a compressor and can be disengaged
