4 Wheel Drive still not working...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma Ride Days, Jul 8, 2020.
  1. Jul 8, 2020 at 3:07 PM
    Tacoma Ride Days
    Tacoma Ride Days [OP] TonI the Tacoma
    Brad
    2004Tacoma
    Hello again!
    Just installed a new actuator to the front axle. I tested the actuator before I bolted it in, light came on and everything, and it worked perfectly. However, when I bolted it into the axle, then proceeded to put the truck in 4 wheel drive, but it did not engage.
    I could hear the motor in the actuator move when i put the truck in 4 wheel drive, but the light would not come on and I could not feel the front wheels engaging.
    Please help! I am truly at a loss right now
  2. Jul 8, 2020 at 3:11 PM
    02hilux
    02hilux Go where the few dares to travel
    Planet: EARTH
    point and GO
    Did you position/clock the collar to the far right and place the fork into the collar?
  3. Jul 8, 2020 at 3:21 PM
    Tacoma Ride Days
    Brad
    2004Tacoma
    Yes, it was the only way it would fit in and have the holes for the bolts line up
  4. Jul 9, 2020 at 2:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just how did this start I read through your other thread I only saw it did not work ??
    I am guessing it worked at one time .
    You have ruled out anything in the front axle keeping it from engaging ?
    Did you check the actuator you removed to see that still works ??
  5. Jul 9, 2020 at 10:54 AM
    Tacoma Ride Days
    Brad
    2004Tacoma
    Yes, so I broke it down to the old actuator had gone bad because it was the only thing that wouldn’t work when I put the truck in 4x4. I took the old one off and tested it and knew it went bad. But when I put the new one on, I could hear the motor spin but no 4 wheel drive
  6. Jul 9, 2020 at 12:41 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    How long have things been sitting ??
    When you installed the new actuator you made sure the sliding sleeve was free. Not like your dealing with a powerful motor.
    If the sleeve is stuck it is not going to move This is a cause for many failures not to engage 4x4
