4 wheel drive tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bragado, Dec 5, 2010.
  1. Dec 5, 2010 at 11:44 AM
    bragado
    bragado [OP] Member
    ill
    08 toyota tacoma
    Hi everybody, I'm new to this site. I hoping someone can help me.
    I have 2008 tacoma V-6, 6 speed manual. I love this truck.
    resentley I noticed something I never experienced before, we had our first snow here in ill and roads where a little slushy so i decided to activate the 4 wheel drive just for fun and noticed when i pulled into a dry parking lot and tried to stear into the parking spot it was like putting on the brakes, it would not move unless pushed really hard, after taking it off 4 wheel drive, or stearing the front wheels to straight position it was fine again. planning on taking it in for service but wanted to know if anybody has this same issue or it may be normal. any feedback is apreciated.
  2. Dec 5, 2010 at 11:47 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    NORMAL... 4WD is for poor traction road or no roads... As soon as you are on dry pavement, return to 2WD...
    In 4WD, the front and back drive shafts are locked together, but the wheels all turn at different speeds, so so slipping must occur and off road or wet roads that isn't a problem.
  3. Dec 5, 2010 at 11:49 AM
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    :taco:
  4. Dec 5, 2010 at 11:55 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    check out the links in my signature below...
  5. Dec 5, 2010 at 11:57 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    yeah no 4 wheel drive on dry pavement. For slushy roads you will be fine in 2wd.
  6. Dec 5, 2010 at 12:18 PM
    lightnin
    lightnin Member
    jeff
    west palm beach
    05' 4x4
    33'" tires
    the braking feeling will be worse in 4 wheel low i use 4 wheel high in poor driving conditions.
  7. Dec 5, 2010 at 12:19 PM
    bragado
    bragado [OP] Member
    ill
    08 toyota tacoma
    Thanks guys, all this makes a lot of sence now. I love this site already.
  8. Dec 5, 2010 at 4:35 PM
    David K
    Glad you joined... I started posting here regularly one year ago to learn about my 2010's traction controls... as the manual and salesmen couldn't provide the details I seek... but the gang here were very helpful. I decided to payback TWers by getting the details posted in a way I could understand them, and hopefully others who think the way I do will benefit as well. Your question was an easier one that applies to all Part Time 4WDs on pavement... 'er DRY pavement... Since you can shift on-the-fly, just pop in and out of 4WD-HI when your truck has difficulty driving but never when slowly turning tight into a parking spot.
    Ask any question, anytime!
  9. Dec 5, 2010 at 4:49 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    Oh good. The monthly "4 wheel on dry pavement" question. Running a litle late this month.
    Welcome to TW, BTW! Now go finish reading your owner's manual, and note that it recommends driving a few miles (straight!) with it on monthly to keep the gears lubed.
    (I think I might have started with this question too)
  10. Dec 5, 2010 at 4:53 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Now all we need is Skistoy to chime in and tell you it's OK to run it on dry pavement , in fact it's says so in the manual .
    (OP ^^^ disregard this , I'm just kidding around , do not use 4WD on dry pavement . LOL ) :D
  11. Dec 5, 2010 at 5:10 PM
    jandrews
    '09 FourDubDee TRD OR
    It says no such thing.
    The manual indeed says to run at least 10 miles in 4wd per month as maintenance. NOWHERE in there does it say to do so on dry pavement.
  12. Dec 5, 2010 at 5:12 PM
    OZ-T
    Peter North
    British Columbia
    I was being sarcastic R-Tard . ;)
  13. Dec 5, 2010 at 5:14 PM
    OZ-T
    Peter North
    British Columbia
    You didn't get this part JAnn ^^^ ?
  14. Dec 5, 2010 at 5:15 PM
    jandrews
    I got that part. I was pointing out that the same people you were bashing were, in fact wrong.
    Ergo, agreeing with you.
    Didn't get that part T? ;)
  15. Dec 5, 2010 at 5:16 PM
    OZ-T
    Peter North
    British Columbia
    No .
    We still OK ? You need a hug ?
  16. Dec 5, 2010 at 5:22 PM
    jandrews
    I winked didn't I? That means I'll keep lettin' ya make me all those baked goods, ya crazy ass faggy canadian. :D
  17. Dec 5, 2010 at 5:29 PM
    OZ-T
    Peter North
    British Columbia
    I like cheeseburgers
  18. Dec 5, 2010 at 5:29 PM
    jandrews
  19. Dec 5, 2010 at 6:34 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    you two are allstars !!!
