400 hp
Discussion in 'Performance and Tuning' started by Miller time, Dec 19, 2017.
  1. Jan 5, 2018 at 8:51 AM
    #61
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    Those are pretty amazing numbers for the mods you listed. Do you know what kind of dyno they used? Stock highway tires I assume.
  2. Jan 5, 2018 at 8:56 AM
    #62
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I’m not certain on the type of dyno. I think it’s similar to dynojet? I don’t know for certain. But yes those numbers were from the stock tire size 265/65r17 pulls done in 3rd gear.
  3. Jan 5, 2018 at 9:00 AM
    #63
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Cheapest way is probably to gut it and drop your choice of Chevy V8 drivetrain in there.
  4. Jan 5, 2018 at 9:54 AM
    #64
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pfff. This guy.
    Brice and yota243 like this.
  5. Jan 5, 2018 at 9:56 AM
    #65
    Frenchfrylover69
    Frenchfrylover69 Well-Known Member
    Chad
    Toyota tacoma
    Lift n stuffs
    About 7-10k depending on if you know how to pull an engine yourself and engine swap for a 350. 350 crate engine can run you anywhere up to 10k itself based on what you want and how built you want it. You won't get 400hp out of a 4.0
  6. Jan 5, 2018 at 10:00 AM
    #66
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pfff. Then how did I?
  7. Jan 5, 2018 at 10:02 AM
    #67
    Frenchfrylover69
    Chad
    Toyota tacoma
    Lift n stuffs
    Seriously? I have no idea how you did? Lmfao I stand corrected. Now I must know... how did you? Was it worth it? Or woukd engine swap be cheaper?
  8. Jan 5, 2018 at 10:12 AM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There is guy in the turbo BS thread, whom probably has the cheapest 4.0 turbo build, with tuning.
    Was it worth it, at first no. As my thirst for knowledge grew, my turbo build evolved, I made good power, and gained invaluable experience. Now I use my truck on a road course. Absolutely worth it.
    Biscuits, stevotivo12, Brice and 3 others like this.
  9. Jan 5, 2018 at 10:14 AM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If I were to do a Chevy swap, I'd still have to spend the coin to overcome the known failing points of that engine.
    People whom haven't delved into the 1GR, have little knowledge on its true capability as a performer.
    There is a guy with a twin turbo 1GR, pushing around 650 whp. With a T56 Magnum behind it.
  10. Jan 5, 2018 at 10:17 AM
    #70
    Frenchfrylover69
    Chad
    Toyota tacoma
    Lift n stuffs
    This sounds very intriguing I will check into this. Thanks for the info. I figured the 4.0 might be able to hit 400 but not without alot of time and money lol
  11. Jan 5, 2018 at 10:20 AM
    #71
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    2jz
  12. Jan 5, 2018 at 10:20 AM
    #72
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD, or Turbo.
  13. Jan 5, 2018 at 10:39 AM
    #73
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    1FZ and 3RZ/2TR don't carry the JZ "tax". And can make more power. :D
    I know. Blasphemy, right?! :anonymous:
    MadTaco461 likes this.
  14. Jan 5, 2018 at 10:46 AM
    #74
    uurx
    '12 t|x pro
    how about a 1j?
    valid point with the parts being taxed
    stevotivo12 likes this.
  15. Jan 5, 2018 at 10:48 AM
    #75
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not too sure on the 1JZ.
  16. Jan 5, 2018 at 5:37 PM
    #76
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Do i know that guy?
    MadTaco461 and buyobuyo like this.
  17. Jan 6, 2018 at 10:53 AM
    #77
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There may be a correlation.
    yota243[QUOTED] likes this.
  18. Jan 11, 2018 at 5:10 AM
    #78
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need to get yours on the rollers, and see the numbers that it is putting down.
  19. Jan 11, 2018 at 5:22 AM
    #79
    yota243
    E.J.
    north Alabama
    Need to get my vacuum leaks fixed so i make more than 4 psi:anonymous:
    One day it will warm up enough to do somethin to it
  20. Jan 11, 2018 at 5:28 AM
    #80
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    I have a 99 c5 for sale. you'll be happy with a Ls swap:rofl:
