****42 DRAFT DESIGNS OIL CATCH CAN GROUP BUY****
Discussion in 'Group Buys' started by Justus, Jun 27, 2013.
Thread Status:
Not open for further replies.
  1. Jul 5, 2013 at 9:53 PM
    #81
    scocar
    scocar Patron of the Farts
    Oh blarg. One of the easiest, most accessible place to mount it is to screw it to one end of plastic radiator shroud, but of course I'd be worried about weight and flexing.
  2. Jul 5, 2013 at 10:02 PM
    #82
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Jul 5, 2013 at 10:10 PM
    #83
    scocar
    Yeah, I've seen those. I would use some sort of reinforcement and use nuts and bolts (not screws) if I went near the shroud, or build a bracket over it. On the VW installs, they are going right into some plastic trim around the inside edge of the engine bay. That's what made me start wondering about weight.
    There's also space over behind the airbox and cruise control on the passenger side, but I have Redline hood struts that sort of interfere over there (plus I'd like to save room for a compressor there), blah blah blah. I also just need to look for other existing bolts and perhaps piggyback on them with an aluminum extension. I just need to stare and poke for a while.
  4. Jul 7, 2013 at 5:46 AM
    #84
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    bumpski.................looking good but we are not there yet
  5. Jul 8, 2013 at 8:31 AM
    #85
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    :playball:
    Monday bump.
  6. Jul 8, 2013 at 9:40 AM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Info emailed to the yahoo account. :thumbsup:
    What is the count now?
  7. Jul 8, 2013 at 3:12 PM
    #87
    telum01
    telum01 Active Member
    Hi everyone, found this group buy while doing some research on this catch can. I'm putting a kit together for a couple people. Looks like I've got 3 total committed (myself +2) so far, more might follow.
    Joined the forum to post, so I'm sure I won't have the post count to message. But you can add 3 to your catch can count :)
  8. Jul 8, 2013 at 3:18 PM
    #88
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Welcome!
    3 of which type & which fittings?
  9. Jul 8, 2013 at 3:38 PM
    #89
    telum01
    Still gathering info from them. The kit I'm working on isn't for a Toyota. I just posted this thread's group buy info in the thread I started on another forum.
    http://www.6speedonline.com/forums/aston-martin/311828-aos-catch-can.html
    BTW, I've got a 4.0L 4Runner... can you point me at the info I need to decide on a catch can for that? (Fitting sizes, mounting options and locations, etc.) I haven't looked into tinkering with it but now's as good a time as any!
  10. Jul 8, 2013 at 4:27 PM
    #90
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    im in just not sure on which one is better to get... whats the differece between the 2 stealth models. please keep in mind that i have very little experience with oil catch cans.
    only want to buy one because after taking off my intake mainfold i found some oil on the top of the runners and a friend told me this catch can will eliminate that issue (is it really even an issue???)
  11. Jul 8, 2013 at 4:33 PM
    #91
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Keeps your engine cleaner longer. :thumbsup:
    On a performance engine, it helps also helps prevent knock. As well as other things.
  12. Jul 8, 2013 at 5:20 PM
    #92
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    since im just a N/A engine do i really need to put 100+ dollars into an oil catch can or will the ebay ones be fine. i honestly dont understand the difference between the two and such high price fluctuations.
    #92
  13. Jul 8, 2013 at 5:23 PM
    #93
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you buy other parts that are junk? Or do you buy quality parts?
    You don't have to buy these. Buy whichever one you want. But when it starts leaking, you have hose fitment problems, cheap parts crack or don't seal, then you'll come to the realization that you get what you pay for.
  14. Jul 8, 2013 at 5:32 PM
    #94
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    im gunna do some more research then maybe ill put my cash on the table
  15. Jul 8, 2013 at 5:36 PM
    #95
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I've known plenty of people to have purchased the eBay ones. They are usually made in China, and are junk. They end up saying that they had to do this and that to get it to work properly. Some just leak regardless.
    You take a chance of buying the part twice, if it (the eBay one) doesn't work the first time.
    #95
  16. Jul 8, 2013 at 6:13 PM
    #96
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    you know it's good when i'm in for 2 :p
  17. Jul 8, 2013 at 6:22 PM
    #97
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    yeah im probably going to buy. im putting half my attention on this while at work is all haha :D i figured the eaby stuff was chinese crap.... just by reading their descriptions. I could read the F.O.B. accents (fresh off the boat for those who are unaware)
    wait... r u putting 2 on ur truck mike???
  18. Jul 8, 2013 at 6:40 PM
    #98
    telum01
    The info I posted in this link (quoted below) is for another car, but the basics are all the same. Covers some basics about oil catch cans.
  19. Jul 8, 2013 at 6:41 PM
    #99
    luka
    Kailua, HI
    one for my truck and the other into a GT-4 i'm finally gonna start building
  20. Jul 8, 2013 at 6:51 PM
    #100
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    thanks telum :D
    oh sick haha
    edit..... so i went on ahead and emailed the OP... im in for a Stealth. thanks guys for the clerification
Thread Status:
