43202-35071
Discussion in '1st Gen. Tacomas (1995-2004)' started by TragicBronson, Jan 18, 2023.
  1. Jan 18, 2023 at 10:07 AM
    TragicBronson
    TragicBronson [OP] Well-Known Member
    Eddie
    Pflugerville TX
    2003 Tacoma Dbl cab SR5 4WD
    Hi Folks,
    I stumbled across a new driver side Spindle for my 03' Double Cab 4WD w/ABS for sale. The part number is listed as 43202-35071. Will this part # work for my Tacoma?
    https://www.ebay.com/itm/195529099650
    I meandered and found the following old post but the OP didn't mention 03's:
    https://www.tacomaworld.com/threads/useful-4wd-conversion-info.413901/#post-11722172
    I'm thinking the RWD and 4WD driver side spindles are identical unless there is something special about the 03's I'm not reading up on.
    thanks!
  2. Jan 18, 2023 at 11:53 AM
    Michaelzg
    Michaelzg Well-Known Member
    Michael
    2002 Tacoma Flatbed
    Looks like you should be good. The non abs ones have don't have the hole for the sensor in the casting. Why purchase this though, unless yours are bent?
  3. Jan 18, 2023 at 12:41 PM
    TragicBronson
    Eddie
    Pflugerville TX
    During Brake/Rotor service both brake caliper bolts sheared off in the spindle and after I drilled the bolts out the spindle threads are garbage. Go figure the passenger side service was as easy as you'd expect it to be. I also tried a drill out the the lower caliper hole to 31/64 to accommodate a M12 Helicoil but %$@^$#% my drill doesn't have the beans.
    I don't have a drill press to open up these holes up for an M12 helicoil any further, so a new spindle is the next best thing. I got fresh new tie rods and LBJ's sitting on the floor waiting for what comes next.
    TIA,
    Edgar
  4. Jan 18, 2023 at 12:57 PM
    Michaelzg
    Michael
    2002 Tacoma Flatbed
    Dang that sucks, probably better to find one off a Junker. All the 3rd gen 4runners have the abs spindles.
  5. Jan 18, 2023 at 1:03 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    No friends that could help drill your holes?
    Getting a few holes drilled has to be cheaper then a new steering knuckle .
  6. Jan 18, 2023 at 1:09 PM
    Michaelzg
    Michael
    2002 Tacoma Flatbed
    I picked up a set for like $60 last year. Gotta make sure ones with a good bearings though
  7. Jan 18, 2023 at 11:02 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    The part# for the ABS knuckle is - 4320235071, so yes the one you came across will fit.
    If you still have a tough time locating, try -
    check http://www.car-part.com
    Also touch base with @zippsub9 - https://www.tacomaworld.com/threads/for-sale-4x4-manual-hubs-spindles-knuckles-and-cvs.709082/
    Toyotadilly, zippsub9 and Bivouac like this.
  8. Jan 19, 2023 at 12:55 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
