4400lbs dry? Help
Discussion in 'Towing' started by Jbart13, Jun 24, 2020.
  1. Jun 24, 2020 at 2:44 PM
    Jbart13
    Jbart13 [OP] Member
    Hey guys I know this is kinda repeated over and over BUT here’s my dilemma.....
    I am currently looking at a purchasing a Passport 239ML, going into it I thought it weighed 4189lbs at 25ft long. Turns out it’s 4420lbs, I know this is not drastically different however I thought the 4189 was truly the max for this truck and wanted some advice.
    Taking the truck on a 4 week roadtrip, Glacier NP, Rocky NP so mountains will be part of my trip(For some of it). Is 4420 too much to do SAFELY? I know the truck will be working, I will not be hauling any water I won’t be traveling past speed limit and I will have a WDH with anti sway, brake controller, and possibly Sumo Springs (are these needed you think?). Even with all the precautions is this realistic? I know a Tundra would be easier but not in the market for a new truck UNFORTUNATELY. Has anyone done similar with their truck? Anyone running similar set up / weight? Can I make this safe!!!!
    thanks in advance
  2. Jun 24, 2020 at 8:34 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Can’t answer your questions without knowing about your truck. What year, what model, what engine, any mods, tow package??? What is the max tow capacity of your truck?
    I can tell you though when you load that trailer up , and it will be loaded if you are going on a 4 week trip, you’ll be around 5000 to about 5400lbs. No matter what Taco you have it’s going to be unpleasant and a real hassle towing that around the Rockys.
  3. Jun 24, 2020 at 8:41 PM
    tcjacado
    tcjacado Well-Known Member
  4. Jun 25, 2020 at 1:57 AM
    Jbart13
    Jbart13 [OP] Member
    Sprig I have a 18’ TRD Sport double cab short bed. 6400lbs towing / 640 tongue / 1150ish in payload. I’m thinking as long as I pack light I should be able to keep it to 600lbs, 700lbs max. That puts me right around the 5000-5100lb range.
    I have read on many sites other then Tacoma that there is an unwritten rule of towing should not exceed 80% which for me is 5120#. While people say this is ok I think this may be a little stretch. But I see people on here towing even bigger, while others tow 2500#s and say it’s too much.
    I’ve read so many contradictions and people arguing how much this truck can actually tow, that I think I’m more confused then before I started reading
  5. Jun 25, 2020 at 7:14 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    What's the tongue weight of your camper? Definitely something to consider.
    With other numbers listed, It's doable, but it wont be pleasant. You'd have to drive cautiously. The sumo springs will help level you out too so your nose isn't pointed to the stars.
    Tacoma's just aren't great towing trucks. Unfortunately.
    OneGiraffe likes this.
  6. Jun 25, 2020 at 7:22 AM
    Jaypown
    Justin
    NE Ohio
  7. Jun 25, 2020 at 7:26 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If you have some experience towing, you will be fine.
  8. Jun 25, 2020 at 7:39 AM
    skeighter
    skeighter Well-Known Member
    With the right equipment (trailer brake controller, sway bars, etc.) and being careful I'm sure you'll be fine. Will it be a pleasant experience? Absolutely NOT, given the type of terrain you'll be driving through. We pull a trailer that's 1k pounds lighter than yours and it's a PITA. You also need to consider the profile of the trailer, which can be more of a problem than weight. Ours is pretty tall, which might account for some of the difficulty towing. Wished I'd kept our popup.
  9. Jun 25, 2020 at 7:50 AM
    Bad@Nicknames
    Bad@Nicknames Well-Known Member
    Bruce
    Greenville SC
    2008 TRD Sport AC
    Bilstein 5100's set at 1.75 Gunmetal Ray 10's
    I agree with skeighter. You will 'probably' be 'fine', but it's more than I would be comfortable with. But you may have more towing experience than me. We tow just around 3200 loaded. Would I do more. Sure. 2000 lbs more. No way. Some of our roads are completely jacked up around here which is also some of the problem.
  10. Jun 25, 2020 at 7:54 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    +1 on yes you can,
    also +1 on it won't be anywhere near fun doing it.
    I towed a 26 ft, 4500 lbs Travel trailer thru the Smokeys, and that was all the Taco wanted.....
  11. Jun 25, 2020 at 8:15 AM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    I never go past 75% of my tow capacity. Heck, I try and cap it at 50% most of the time. It "can" do it, but the closer you get to max capacity, the more severe the wear and tear you're putting on the truck (suspension, driveline, etc.). If you're towing near your limits, then your truck is also working near its limits.
    Then consider braking and safety, and this goes for any truck, HD or mid-size, can you and the truck and the trailer combination together handle an emergency maneuver or emergency stop out on the highway or on a mountain road in a controlled and safe manner? Not as easy when you're at your limits, on up and down mountain passes, trailer brake or no. Which is where the enjoyability of the drive really starts going away.
    So consider how hard you want your truck to work, how hard your driveline and suspension will be working and the toll that takes on longevity. And please consider the rest of us on the highway when you drive - drive slow and leave a LOT of braking space.
  12. Jun 25, 2020 at 8:40 AM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    Just get a smaller trailer. You're going on this trip to explore, not to sit around inside.
    Something like the R-Pod RP-179(https://forestriverinc.com/rvs/travel-trailers/r-pod/RP-179/974) has pretty much everything that Passport has but weighs 1500 pounds less. Using that R-Pod as an example because I know someone who tows one very comfortably with a Taco(3rd gen TRD Sport) but there's a lot of other trailers around that size. Why endure a stressful driving experience for a little bit more floor space? I've been to all those places you're going and trust me, even on the interstate driving legs you want to be able to relax and enjoy the ridiculous views on the way down mountain passes instead of spending the descent worrying about your brakes.
    wiljayhi likes this.
  13. Jun 25, 2020 at 8:47 AM
    vsekvsek
    vsekvsek Well-Known Member
    Hey thats my thread lol.
    I have a 4800lb i towed over continental divide. You add two adults and all the extra camping crap and you looking at around 5500 lbs. i would say my taco towed it just fine. Coming down hills...different story.
    To OP..But you better have brake controller and brakes in good cond. my brakes where smoking when i came down the continental divide. I had to dial trailer brakes to full on to get down hill. So just spent $1200+ on new top notch after market brakes and was honestly hoping for better braking. So i started the thread asking if a Tundra would make a difference. Then the thread promtly turned comical.
  14. Jun 25, 2020 at 10:13 AM
    Bad@Nicknames
    Bruce
    Greenville SC
    2008 TRD Sport AC
    Agree. Geopro / EPro is in the same category as the Rpod. Give those a look. Seven wide, tacoma comfortable towable, and not lacking in a thing.
  15. Jun 25, 2020 at 10:37 AM
    jasmits1
    Ooh I hadn't seen the E-Pros before, I like. Especially that mini toyhauler.
    My philosophy as a 70+ night/year camper is that if I find myself outgrowing a midsize I need to bring less shit, not buy a bigger truck. Gear is there to enhance the experience, not dominate it. Buying a trailer that strains your Tacoma is a slippery slope. After a few years you'll bump up to a half ton that'll be much happier towing your trailer. But then you can get a bigger trailer too, after all you've got 10,000lbs of towing capacity. Next thing you know you'll be dragging a fifth wheel around between KOAs hardly having time to see the stuff you're supposedly traveling to see because you're spending all of it screwing around with the studio apartment you've decided to bring along.
  16. Jun 25, 2020 at 10:44 AM
    Big_Red_Taco
    SoCal
    Look at the Forest River No Boundaries line too - nice build quality, off-roady bent, with surprisingly lightweight trailers. I like the 16.6 bunkhouse.
  17. Jun 25, 2020 at 10:49 AM
    Bad@Nicknames
    Bruce
    Greenville SC
    2008 TRD Sport AC
    Ha so true my friend! It's just the wife and I, and we decided we wanted the smallest thing that we could still stand in. Pulled the trigger on a Geopro 15tb and couldn't be happier.
    Edit. It has an offroad package option. Small lift, bigger tires. Does it really do much? Eh.. not sure, but it looks cool.
    ryanhealy likes this.
  18. Jun 25, 2020 at 12:13 PM
    jasmits1
    I'm fine with pretty spartan accommodations but I totally get why people would want some more creature comforts like a toilet, shower, proper kitchen and someplace nice to hang out when it's crappy out. I don't see why you'd want to drag around anything more. My parents like to travel a lot and have some money so they've been thinking about getting an RV to still get some travels in during covid. I successfully steered them to looking at Sprinter vans from full on RVs with the simple argument "well what happens when you want to spend a few days in a city? A short wheelbase Sprinter's no bigger than an F150 and cities are still designed around vehicles that size. Have fun street parking even a small Class C in Seattle."
    For just camping the most I'd really want is a wedge camper(like GoFastCamper and similar). I like camping off uninproved roads and IMO any trailer would just be more of a pain than it's worth for that. But a friend's trying to get me into dirt bikes(successfully, he has a spare bike I get to use if I transport it myself, fuck is it fun) and that mini-toyhauler sure looks pretty nice for dirt bike trips, it's not like I'm going up sketchy roads with a motorbike hanging off the back of my truck on a hitch carrier anyway. Plus it'd be quite the upgrade from my RTT for ski camping.
  19. Jun 25, 2020 at 12:31 PM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    To add to this, I towed a 1500 lbs teardrop through the smokies and it was fun ripping around corners and enjoying the scenery. I'm 100% in agreement with everyone who says you can, but it will suck.
  20. Jun 25, 2020 at 12:38 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
