45-65 mph shake / shimmy
Discussion in 'Wheels & Tires' started by brutalguyracing, Apr 13, 2010.
  1. Apr 13, 2010 at 7:29 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    ok just got my new tires 285/75/16 m/t had a shake between 45-65mph brought it back to the tire shop had them re balance the tires but shake is still there....
    i have 5100's at 2.5 --l.r. uca's & 2" aal..
    my alingment is not perfect but it drives straight....on going alingment issues here with the lr uca's " no one knows or is willing to adjust them"
    but does this shaking sound like an balance issue or and alingment issue...
    i can feel it in the wheel and the gas pedal
  2. Apr 13, 2010 at 7:51 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Check your air pressure, you have changed quite a bit from stock and Air pressure needs to change too. Also, those retards at tire shops always put in way to much air. Also check the torque on your lug nuts.
  3. Apr 13, 2010 at 10:50 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Are your wheels hub centric or lug centric? Lug centric wheels can cause vibes if not properly seated.
  4. Apr 13, 2010 at 10:55 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    do all tires take the same air pressure??? if so what 30-35psi
    and all is seated properly....
  5. Apr 13, 2010 at 11:56 AM
    RideFast
    Jesse
    Tacoma
    Well for instance my 1st gen has a sticker on the door jam that says 26psi front and 29psi rear. I have 31 10.50 15 inch tires and I put 28 psi all of the way around.
    Actually I had the same problem with shaking in the cab, I kept taking my truck back to the tire shop for a re balance. They ended up replacing my wheels and changing the offset back to stock (on a 1st gen its 7). The problem got better but not right. So Then I started playing with my psi. They had it at 34psi and that was not even close to oem. So I set my psi to oem and it was a little better so I set all four tires at 28psi and it was perfect.
    So all in all I think it was a combination of them selling me the wrong offset wheel and putting way to much air in the tires. Tacomas and Ford Rangers for some reason are really sensitive to offset.
  6. Apr 13, 2010 at 11:58 AM
    RideFast
    Jesse
    Tacoma
    look at your door jam it will say the tire pressure, use a digital gage and check them in the morning while still cold.
  7. Apr 13, 2010 at 11:58 AM
    TacoSupreem
    Hayden
    Kentucky
    Depends on alot of variables^^^ Lt tires can go up to 65psi! Depends on what type of tires you have and how much weight your gvw is or how much your haulin.
  8. Apr 13, 2010 at 12:00 PM
    TacoSupreem
    Hayden
    Kentucky
    Search for the chalk line test, it'll explain how to find the correct tire pressure.
  9. Apr 13, 2010 at 12:04 PM
    TacoSupreem
    Hayden
    Kentucky
    Edit: check the sticky on "what tire pressure should I run".
  10. Apr 13, 2010 at 12:17 PM
    Trauma85
    Trauma85 Well-Known Member
    Tyler
    Idaho
    2014 Tundra
    Some tires especially M/T tires are just impossible to balance. With the big lugs, and hard spots in the tires. I dunno what kind of equipment they have or if they did, but sometimes with heavy tires if the heavy spots arnt so spread out rotating the tire on the wheel correctly will fix the problem. If it cannot be done this way, your going to have a shake until your tread gets low and most of the heavy spots are gone. I got km2's and they do the exact same thing, Ive even gone as afar as putting a sand called "equal" in them, which static balances the tire as it rolls, which works really good on most smaller tires. So basicly, make sure they atleast tryed to "optamize" the wheel to the tire before they balanced it.
  11. Apr 13, 2010 at 2:03 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    they are 285/75/16 definity dakotas "made by cooper tire co."
    so you guys are saying it is more of a balancing problem then an alingment one???
    i headed out on a road trip for like 4000 miles on thursday and want this resolved....
  12. Apr 13, 2010 at 5:11 PM
    Trauma85
    Tyler
    Idaho
    2014 Tundra
    Yea your alignment has nothing to do with this at all.
  13. Apr 13, 2010 at 5:26 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    Alignment problems normally cause the vehicle to pull left or right, not shake. Shaking could also be caused by problems in the steering rack. I had that with my last Taco.
  14. Apr 13, 2010 at 5:36 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Road force balance... NOW!
  15. Apr 13, 2010 at 5:42 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i belive thats how they balanced them.....^^^^^^^^^^^^^
  16. Apr 13, 2010 at 5:46 PM
    SamSter0077
    Katy, TX
    Be sure dude, I had the same problem.. watched over the shoulder.. everything came up "0.00" and it still shook! Did it over again with Road Force balance.. it was all out of whack.. rebalanced, haven't had the shake since.
    I had another Front shake because the front was lifted too high.. doubt that is your problem though.
