4500 miles on my '12... Maint' Req' on... oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoJersey, Jan 12, 2012.
  1. Jan 12, 2012 at 7:18 PM
    SoJersey
    SoJersey [OP] South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    as title says.. guessing this means oil change time?
  2. Jan 12, 2012 at 7:20 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yep...I would have never left the "break in" oil in there that long tho. Get it changed ASAP
  3. Jan 12, 2012 at 7:21 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    will do! curiosity... how many quarts of what weight oil? I'm used to my caddy... easier to ask then look it up. I'll grab a 'yoga filter tomorrow at the dealer..
  4. Jan 12, 2012 at 7:24 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    yea i've looked that up on the light reset..
    what weight oil are you guys running? or what does oem call for?
  5. Jan 12, 2012 at 7:29 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    gotcha!
  6. Jan 12, 2012 at 7:29 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    5 - 5.5 QTS
    Mobile 1 Synthetic with OEM Oil filter
  7. Jan 12, 2012 at 7:31 PM
    MurfsTacoma
    MurfsTacoma Active Member
    Jordan
    Riverside
    05 Double Cab 4x4 TRD
    Grill, PushBar, BHLM, K&N, Delta 50 Flowmaster, A.R.E cover, 5100's
    On top of the refill cap it says 5w-30
  8. Jan 12, 2012 at 7:32 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    ^ good deal, haven't "snooped" around too much on this yet..
  9. Jan 12, 2012 at 7:35 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Most guys here run 5w-30 Mobile 1 Fully Synthetic Extended performance from the 5 quart jug you get from walmart for $26. The engine requires 5.5 quarts so add an extra quart to the cart for $7.
    Most guys here run an OEM Toyota filter you get for $5 from the dealership. You can get them for cheaper if you have a coupon from the circular.
    Don't forget to change the crush washer on the drain bolt. Some dealerships charge $1 sometimes you get it for free.
    When you fill the engine with 5.5 quarts, its going to read overfull from the dipstick, which is OK as long as you make sure you added 5.5 quarts only. The dipstick reads a little lower than it should.
    If you are new to changing the oil on a second gen tacoma, follow this write up:
    https://sites.google.com/site/tacomamaintenance/oilchange
  10. Jan 12, 2012 at 7:40 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    This
  11. Jan 12, 2012 at 7:51 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Don't do like some and make the mistake of draining the tranny fluid. Hint...the engine oil drains from under the engine. To get the best dip stick reading pull the stick out and wait 10 minutes for the oil to drain down the tube. 5 1/4 qt should read right to the top fill dot.
  12. Jan 12, 2012 at 8:19 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    good deal... my caddy called for 6 quarts, really took 6.5q... the ls6 burnt off .5 every 3k miles so always kept a quart with... :rolleyes:
  13. Jan 12, 2012 at 8:22 PM
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    do you guys add oil to the filter before you put it on? Also, is it bette to run the M1 0-30 FE oil?
  14. Jan 12, 2012 at 8:25 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I pour a little oil around the top of the filter mainly to lube the gasket.
  15. Jan 12, 2012 at 8:27 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Alamogordo, New Mexico
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Only to the gasket on the filter. It sits upside down so I guess you could fill it if you are part ninja... Otherwise just screw it on and let the truck fill it for you.
  16. Jan 12, 2012 at 8:33 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    Its free to get it changed at the dealer for the first 2 years, why not let them do it :confused:
  17. Jan 12, 2012 at 8:52 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    They're not qualified to work on MY truck.
  18. Jan 12, 2012 at 8:58 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    Guess urs is more specialler than mine :rolleyes:
  19. Jan 12, 2012 at 8:58 PM
    OffroadToy
    Your better off doing it yourself and knowing it got done right. In my opinion the 2 years free oil change is nothing more than a sales gimmick.
  20. Jan 12, 2012 at 9:01 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    I'd agree to some degree, I don't know how they could mess up an oil change though. I change mine on my own at the 2500 mile marks and let them change it on the 5000's if that makes sense
