45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Apr 4, 2014 at 11:35 AM
    #2121
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    And yeah it ain't no taco any more:p
  2. Apr 4, 2014 at 11:46 AM
    #2122
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Good point on just waiting to paint the outside. Fasteners sounds like a nice idea, not sure how I'd do it though. Would make dent removal easy haha.
  3. Apr 4, 2014 at 12:02 PM
    #2123
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah I wouldn't rattle can the entire thing, but I'd want some for those touch-ups.
  4. Apr 4, 2014 at 12:20 PM
    #2124
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Raptor line it. Get the dye able kind and add the color you want. Spray it on with the gun. And be done.
  5. Apr 4, 2014 at 12:20 PM
    #2125
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Can you substitute clear coat with enamel?
    Bitch to clean though, wouldn't it? I was thinking an enamel/clear coat/gloss/semi gloss based paint would be easier to keep clean/ Keep the mud and rust at bay.
  6. Apr 4, 2014 at 12:23 PM
    #2126
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just Raptor it man!
    also..no paint you put on there will be good unless you prep the whole cab..period. Prep is like 90% of getting a good paint job. So yes, you'll at least have to take a wire wheel or flap disk or something to scuff up the cab so the new paint has something to stick too. Otherwise it'll all just flake off and chip off in like a year and a half of baking in the sun.
  7. Apr 4, 2014 at 12:26 PM
    #2127
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    So off-the-shelf rattle can paint for the inside/cage and then raptor the outside.
  8. Apr 4, 2014 at 12:29 PM
    #2128
    Blackdawg
    Monte
    Wyoming/St. Louis
    sure why not? haha
    although if you raptored the inside..you could just put some plastic over the dash, pull the seats and then hose it all off..
    gonna be a lot of sanding though.
  9. Apr 4, 2014 at 12:38 PM
    #2129
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    just get a couple sanding discs for that handy dandy grinder of yours and go to town!
  10. Apr 4, 2014 at 1:29 PM
    #2130
    nagorb
    Alabama
    2001 dbl cab 4x4
  11. Apr 4, 2014 at 3:04 PM
    #2131
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    This! I just hose the inside of my cab and take a small wheel brush to it then open up the drain hole and hose all the dirt out, dirt and mud doesn't stick to the raptor liner like youd think, a little scrub and it loosens up and rinses off..
    As for the Flap discs if you didn't know already Leigh Valley Abrasives has tehm for $1.80 or so a piece! Good stuff to. Unsure if you saw that in the welding thread or not
  12. Apr 4, 2014 at 3:08 PM
    #2132
    Madjik_Man
    Colorado Front Range
    Raptor Line is my suggestion.
    Easier to get an even looking coat. Far more durable for the stuff you'll be doing to it.
    Not that hard to clean. Pressure washer FTW.
  13. Apr 4, 2014 at 3:20 PM
    #2133
    nagorb
    Alabama
    2001 dbl cab 4x4
    I ordered a few of them, for the price they are decent but in no way compare to these http://solutions.3m.com/wps/portal/...988C-Quick-Change?N=3294179430+7581641&rt=rud
  14. Apr 4, 2014 at 3:28 PM
    #2134
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    What about your wiring harness running in the door jamb? Or did you move your wiring?
  15. Apr 4, 2014 at 3:29 PM
    #2135
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    What about it? haha its still there, I typically take the doors off when I start cleaning anyhow. I don't go full retard with a pressure washer or hose, just get the floor wet then add a little soap and scrub then rinse it out
  16. Apr 4, 2014 at 3:31 PM
    #2136
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Maybe not, I cant say as I haven't used those before.. and I just realized what you linked earlier wasn't even a flap disc :eek: but I do like them and they last just as long as what ive used in other shops, welding school, jobsites etc so im not complaining
  17. Apr 4, 2014 at 3:33 PM
    #2137
    Cr250jumper
    The moon
    50 shades of tan©
    I mean the wiring harness under this piece of trim. There is quite a bit of wiring I would be careful getting too wet too many times. Given they are wrapped up good in a harness but still isnt good for them. I work at a rental place where we used to clean out our vehicles like that until we had a $$$ repair to a vehicle that was denied warranty because of the way we cleaned it, if it can ruin a brand new harness think about a 13 year old harness
  18. Apr 4, 2014 at 3:37 PM
    #2138
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    All the clips that hold the wiring down are shot and my door trim panel as well as kick panel just pop out so I peel that harness back and lay it behind the seat. no one ever sits in the back seat so I rarely ever have to clean the floors back there
  19. Apr 4, 2014 at 3:46 PM
    #2139
    Cr250jumper
    The moon
    50 shades of tan©
    That answers my question :D
  20. Apr 4, 2014 at 4:11 PM
    #2140
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    :cheers:
    I would like to move all the computers right behind the kick panel though
