45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Aug 4, 2014 at 11:53 AM
    #2441
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks man, it's slowly getting better.
    Mocking up for rear shocks today. 4 inches of shaft showing at ride height. Fully flexed out equates to roughly 20" at the wheels. Looks like I'm gonna have to weld in some more tubing so the bump stops can reach the axle haha :anonymous:
    [​IMG]P1290696 by wyo_taco45, on Flickr
    [​IMG]P1290699 by wyo_taco45, on Flickr
  2. Aug 4, 2014 at 12:01 PM
    #2442
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    And before anyone says anything- yes I know, "no more cutting!" ([​IMG])
    ...but I'm starting to wonder if I should cut off the axle end shock mounts and put the shock on the opposite (inside) side of the tubing/bed area/whatever. Moar flex? :notsure:
  3. Aug 4, 2014 at 12:31 PM
    #2443
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    :laugh:
    I was expecting Madjik, but you beat him to it.
  4. Aug 4, 2014 at 2:03 PM
    #2444
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Why only 4"? You're definitely going to want about half the shock shaft worth of uptravel to race. Seems like the sky is the limit for where the upper mount can go?
  5. Aug 4, 2014 at 2:33 PM
    #2445
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah, I intentionally made the bed area somewhat of a blank slate to maximize my shock mounting options.
    Talking with Ben @ Filthy Motorsports, he suggested 4" of shaft showing at ride height. So that's what the front shocks are valved for. I mocked up the rears assuming they would also be set to 4" at ride height, but they could be tucked another 2" if I want. I was just about to update the build on pirate and ask about that. :eek:
  6. Aug 4, 2014 at 2:44 PM
    #2446
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    4" of chrome showing on the front of a trail rig (not race truck) would be fine but never 4" on the rear. What length shocks do you have out back? 16s? I would try to double that and shoot for 8" of up, 6" minimum.
  7. Aug 4, 2014 at 2:56 PM
    #2447
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I had a feeling that was the case. I'm going with 14"s in the rear too, so the max I could get is 6" up, 8" down.
  8. Aug 4, 2014 at 3:28 PM
    #2448
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You could move them slightly more inboard. I'd only move them in on the inside of the tube frame just. Too far in and they will loose their dampening.
    But I think where they are at is good for crawling and also go fast.
    Would be checking if they clear the tires though with coils on...
  9. Aug 4, 2014 at 3:30 PM
    #2449
    Blackdawg
    Monte
    Wyoming/St. Louis
    Only 14s out back?!
    Wtf
    You will want the rear to out perform the front in go fast situations..like racing through the whoops in the fast section.
    I'd want 16s or 18s and more up travel too.
    But really boils down to ultimate use of the truck
  10. Aug 4, 2014 at 3:41 PM
    #2450
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    14"s all around for mod class. :eek:
    I don't think you want it to necessarily out perform the front, but even things out as much as possible. Hence the reason I've been trying to move a lot of the weight towards the rear. Most of the videos I see where the truck goes ass-over-teakettle is likely because there's either too much weight in the front, shocks unload too fast in the rear, or probably a combination of both.
  11. Aug 4, 2014 at 4:21 PM
    #2451
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Or split it in half, 7 and 7. A lot of competitive KOH rigs have half chrome showing at ride height. Having uptravel is nice and I only have 5.5" of chrome showing up front.
  12. Aug 4, 2014 at 5:33 PM
    #2452
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah, I'll try to stuff the axle as far up as possible. I just cut 4" off the lower links, so I'm gonna move the upper mounts anyway. Truck now looks like it belongs at ~120".
  13. Aug 4, 2014 at 6:16 PM
    #2453
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm just going off my lt knowledge from all the reading I have done. So..not gonna say I know wtf I'm talking about :p
    But I know in general that is a rule of thumb for the lt guys. A planted ass end is always better.
    I would go for more up travel either way. Even if it's just 5-6" chrome
  14. Aug 4, 2014 at 8:58 PM
    #2454
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I can say if you have 4" of uptravel front and rear, you won't get to a speed fast enough to notice which end out performs the other LOL
  15. Aug 4, 2014 at 9:08 PM
    #2455
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Any thoughts on moving the shocks to the inside of the frame/toobing?
  16. Aug 4, 2014 at 9:20 PM
    #2456
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    More pics of where the upper mounts will/could end up!
  17. Aug 4, 2014 at 9:30 PM
    #2457
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  18. Aug 4, 2014 at 9:51 PM
    #2458
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    This is one of the things I didn't add to the equation earlier on. At full flex, the caliper bracket comes too close to the spring retainer plate.
    [​IMG]DSC09828 by wyo_taco45, on Flickr
    Where it's sitting now. With the 4" up travel :)anon:) and with the wheelbase set to approximately 120".
    [​IMG]DSC09829 by wyo_taco45, on Flickr
    [​IMG]DSC09830 by wyo_taco45, on Flickr
    Basically I'm thinking of moving it quite literally on the opposite side of the tubing
    [​IMG]DSC09831 by wyo_taco45, on Flickr
    [​IMG]DSC09832 by wyo_taco45, on Flickr
  19. Aug 6, 2014 at 6:49 PM
    #2459
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  20. Aug 6, 2014 at 7:01 PM
    #2460
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Need more /\
