45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Aug 6, 2014 at 7:03 PM
    #2461
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No straight up and down is good
    Seems a bit inboard. But I'm sure it would work good
  2. Aug 6, 2014 at 7:06 PM
    #2462
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    The coils will clear the truss like that? Newb question but... I am a newb :eek:
    It would certainly give you more room from the brakes at full flex and some more uptravel which I'd think you'd want at KOH speeds :notsure:
    I've been lurking in here drooling over your truck for a while, I can't wait to see when you're done cutting ;)
  3. Aug 6, 2014 at 7:50 PM
    #2463
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i think thats a good idea considering your space concerns and short shocks. :thumbsup:
  4. Aug 6, 2014 at 8:56 PM
    #2464
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    For some actual official numbers for once -
    Full bump to full droop, the pinion angle changes 10 degrees. Driveshaft slip is a total of 2 inches. I'm happy with that. :)
    I'm trying to keep them as perpendicular to the axle as possible considering that they're set closer to the center. I might move the top mounts in an inch or so but that's about it.
    Would being 2.5"s and add bypasses make up for it? :notsure:
    Ahh F it. I'm gonna run with this. I think it's just a matter of proper valving. Hell, LT guys deal with extra leverage all the time with trailing arms.
    I can't wait either. Yes the coils will clear the truss. :p
    I can't even use all the shock (only when flexed) because the lower link will hit near where the tubing meets the original frame. It's nothing I can't cut... I mean fix, though. [​IMG]
  5. Aug 6, 2014 at 9:45 PM
    #2465
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea some valve tweaking and bypasses will make it run great I'm sure.
  6. Aug 7, 2014 at 4:33 PM
    #2466
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    No straight up and down shocks are fucking stupid. Look at any KoH rig... They are all /\... If you have straight up and down shocks under articulation the shock will invert and becomes / looks retarded.
  7. Aug 7, 2014 at 5:47 PM
    #2467
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    How's that possible with links?
    Not being a dick, just curious!
  8. Aug 7, 2014 at 6:22 PM
    #2468
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well better get cutting then
    X2. At what point can the shock invert? Probably just need to angle them forward or back a bit
  9. Aug 7, 2014 at 7:38 PM
    #2469
    Blackdawg
    Monte
    Wyoming/St. Louis
    Straight up and down is the best dampening.
    Physically impossible to invert a coil over haha
    You could slant them in no doubt though. Just have to valve it right
  10. Aug 8, 2014 at 4:05 AM
    #2470
    Supra TT
    Eric
    Indiana
    Right, straight up and down is the best dampening, however... For jumping... desert racing and such. Not Ultra 4 racing.
    Yeah I meant slanting them in, wrong usage of wording :eek:
    But, I'd still angle them to the point when full droop on one side and full bump on another the shock does not go past vertical (towards the inner of the truck).
  11. Aug 8, 2014 at 5:50 AM
    #2471
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    This. With a three link, the axle shifts laterally based on the swing of the panhard. If the shocks were mounted vertically like this || at ride height, when flexed out completely in one direction, due to the lateral shift, the shocks would be like // and are no longer properly supporting the vehicle. This allows for extreme body roll and usually rollovers.
    Compare that to what Eric and I are saying...mounted like this /\ flexed and axle shifted becomes this /| and things are still supported and stable.
    It only takes a few inches slant over the length of the shock to accomplish this. We're not talking how people slant them to stuff 14" shocks under the bed of a first gen.
  12. Aug 8, 2014 at 8:04 AM
    #2472
    Blackdawg
    Monte
    Wyoming/St. Louis
    3-4" I bet is all it'll take to do that.
  13. Aug 8, 2014 at 8:31 AM
    #2473
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    It didn't even take that much for me. I leaned them back using the same principle. Axle swings back and rotates based on the links so I leaned it back like / so when flexed it never goes past this | . Just enough to accomplish what I needed to do.
  14. Aug 8, 2014 at 9:19 AM
    #2474
    Blackdawg
    Monte
    Wyoming/St. Louis
    That makes sense. I'd agree with that
    What about for word for axle movement?
  15. Aug 8, 2014 at 9:25 AM
    #2475
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    You set them up at bump, at bump the axle is all the way forward.
  16. Aug 8, 2014 at 9:32 AM
    #2476
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Hit the nail on the head ^ you want a little angle on the shocks just enough to have the coil overs like so / l when fully flexed out.
  17. Aug 8, 2014 at 10:20 AM
    #2477
    Supra TT
    Eric
    Indiana
    This and this ^^
    I just didn't explain it well enough haha. :D
  18. Aug 8, 2014 at 12:37 PM
    #2478
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Hm, I never considered this when I was building mine. They are angled in a little, guess I'll have to check that :D
  19. Aug 8, 2014 at 6:49 PM
    #2479
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you were talking crazy :p
  20. Aug 9, 2014 at 9:22 AM
    #2480
    Supra TT
    Eric
    Indiana
    :eek:
