45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Oct 21, 2014 at 6:04 PM
    #2821
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Oops, this is a 4 banger... only one deck :facepalm:. $300 isnt bad.
  2. Oct 21, 2014 at 6:45 PM
    #2822
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Did you tell them oversize or no? Seems about right. Make sure it's a good reputable shop.
  3. Oct 21, 2014 at 7:06 PM
    #2823
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Price is spot on like everyone said but see if you can find some reviews on them
  4. Oct 21, 2014 at 10:19 PM
    #2824
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah (I guess) it sounds like they know what they're doing, here's part of his reply to my email
    http://delusionh.com/
    They get a full 5 stars on their FB page, but honestly I don't know how legit a FB rating really is.:rolleyes:
  5. Oct 21, 2014 at 10:25 PM
    #2825
    Blackdawg
    Monte
    Wyoming/St. Louis
    So much for the block assembled...ha
  6. Oct 21, 2014 at 10:35 PM
    #2826
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Haha email them back, "Yeah, about that...."
  7. Oct 21, 2014 at 10:55 PM
    #2827
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Just throw the old headgasket back on, semi-tighten a couple bolts and call it good.... right? :anonymous:
    Been working on a lot of reading up, especially on the math thanks to the tech section on Garrett's site. Also talked briefly with LCE. I'm gonna try working out some spreadsheets to get an idea of the minumum and maximum parameters necessary in order to reach a target 500hp. I figure in actuality it'll be lower then 500, I just wanted to base it on that to give this setup some breathing room.
    So far the updated tentative list for the engine includes
    (Mostly LCE parts)
    Forged rods & pistons with an 8.3:1 compression
    Stage 3 cams
    HD valve springs
    Paradise intake manifold
    Think I can make do with OE valves, or should I really go balls out and have the cylinder head modified for 1mm oversized valves and get a stage 3 valve train kit?
  8. Oct 21, 2014 at 11:11 PM
    #2828
    Blackdawg
    Monte
    Wyoming/St. Louis
    :eek:
    500hp?!...wow. haha okay then..
    yes do the valves. It'll help head flow a lot..and if your shooting even for 450ish..you'll want the over built.
  9. Oct 21, 2014 at 11:38 PM
    #2829
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Holy crap 500hp! Thats a freaking ton for a 4cyl!
    Can the transmission/clutch/transfer case handle that?
  10. Oct 21, 2014 at 11:41 PM
    #2830
    Blackdawg
    Monte
    Wyoming/St. Louis
    be pushing the w58 i think..But thats the horsepower game. Just break shit and replace it as you go ha
  11. Oct 21, 2014 at 11:45 PM
    #2831
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    True true...
    Seems to relate to you and Frank's relationship ;)
  12. Oct 22, 2014 at 5:14 AM
    #2832
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    :eek:
    Damn, so much for just slapping a turbo on it. Def gonna want to raise your RPM's and you need to add a tuner on that list. For 500 hp I would consider stand alone. 90% of not blowing your engine is having a proper tune.
  13. Oct 22, 2014 at 6:23 AM
    #2833
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah you'll have to rev to 9 grand to get that kind of power lol.
    Your build looks good, should make a comfortable 300 or so if you keep the boost reasonable.
  14. Oct 22, 2014 at 6:37 AM
    #2834
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah, based on some of the calculations, it was looking to be around 8k rpms which is why I knew I should be getting the HD valve springs since they're rated for 10k. :eek:
    I knew from the get-go a stand alone was likely gonna be implemented. :anonymous: It also looks like the 6758 or the 7163 turbos are better suited for the job.
  15. Oct 22, 2014 at 6:54 AM
    #2835
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    8k would be very impressive with a 95mm stroke. Going to want to look into some light weight, high strength rods. If you have the $$$ to drop, check these guys out:
    http://www.rrconnectingrods.com/steel-connecting-rods/steel-connecting-rods.html
    Their Alu rods are sick and their Ti rods are redonculous. Ti and Alu do fatigue over time but my neighbor had some custom alu rods in his +600 hp turbo miata with over 10k racing miles on them (upwards of 11k rpms). He's had to replace EVERYTHING but the rods :p
    Otherwise, I think 6500-7000 would be good for +400hp easy depending on the turbo.
  16. Oct 22, 2014 at 11:40 AM
    #2836
    Blackdawg
    Monte
    Wyoming/St. Louis
    Jesus. Going off the deep end now
  17. Oct 22, 2014 at 11:50 AM
    #2837
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Shoulda just SAC'd the front end and been done with it. :D
  18. Oct 22, 2014 at 12:09 PM
    #2838
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    To put 8k RPM's into perspective, this is a list of the fastest piston speeds (production engines):
    1. Jon's 3rz
    Engine Code: BAMF
    Bore/Stroke: 3.74" X 3.74"
    Redline: 8000rpm
    Piston Speed: 4987 Ft/min :eek:
  19. Oct 22, 2014 at 5:16 PM
    #2839
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  20. Oct 22, 2014 at 5:33 PM
    #2840
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Lol take this thing to the drag strip in about 3 years when it's all done haha you'll be getting some funny looks until you lift a 40 off the ground coming off the line.
