45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Feb 23, 2015 at 10:04 AM
    #3021
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    You're stupid :luvya:
  2. Feb 23, 2015 at 11:18 AM
    #3022
    Motomax114
    Motomax114 IG - MKearney114
    Max
    Sacramento
    2000 4x4 TRD/SR5
    When you first put on the OME lift kit did it sit level? If not how did you get it to sit level? I have a 2000 4x4 with the ome kit and its not level. I even put 883 coils on the front. Last week I put a 1" spacer on the front and it looks better but now is super stiff and rides bad. I can't figure out how everyone gets their truck level with the OME kit.
  3. Feb 23, 2015 at 11:47 AM
    #3023
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'm running the 2.7L so it's gonna be a bit lighter on the front end. If the rear is stitting too high, I'd first remove the overload leaf and go from there. Some people trim the ends of the leaves so it sits lower.
  4. Feb 24, 2015 at 10:24 AM
    #3024
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    What are ya'lls thoughts on going with a hydraulic release bearing to replace the clutch fork and slave cylinder? I'm seriously thinking about it because now that I moved the engine back 6", it basically puts the slave cylinder right up against where I'd want the firewall/throttle pedal.
    One of these...
    http://tiltonracing.com/product-category/driveline/release-bearing/
    Also
    Got tabs? :D
    [​IMG]DSC00239 by wyo_taco45, on Flickr
    I made a futile attempt at saving money (again) by trying to make my own tabs. I didn't want to pay $1.00-$1.50 EACH. Found a place where if I bulk ordered 100 of them, they came out to $0.55 each.
    http://www.tabzone.com/12027-516-TRICK-TAB-_p_357.html
  5. Feb 24, 2015 at 11:45 PM
    #3025
    skygear
    skygear                    
    What are they for?
  6. Feb 24, 2015 at 11:56 PM
    #3026
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    x2
    his response: For everything
  7. Feb 25, 2015 at 4:00 AM
    #3027
    Supra TT
    Eric
    Indiana
    Jon doesn't even need to speak. Mark answered it for him to a T
  8. Feb 25, 2015 at 5:08 AM
    #3028
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    You're gawdamnned right. That's exactly what I would've said. :D
  9. Feb 28, 2015 at 10:43 PM
    #3029
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    This welding aluminum BS is a PITA. Less forgiving than steel. :eek: First project (fan shroud) done. Didn't turn out too bad but could've been a lot better.
    [​IMG]DSC00246 by wyo_taco45, on Flickr
  10. Mar 1, 2015 at 5:28 PM
    #3030
    Supra TT
    Eric
    Indiana
    Looks like shit, do it over :luvya:
    But, really... Does it have to be perfect? Looks good man, it's just a shroud.
    Also, whats your hard on for about running E85? I kinda forgot and well I aint going back to dig for the answer :luvya:
  11. Mar 1, 2015 at 5:31 PM
    #3031
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Runs cooler, cleaner, and moar power.
  12. Mar 1, 2015 at 5:36 PM
    #3032
    Supra TT
    Eric
    Indiana
    Why not run 110? I bet that shit runs cooler, cleaner, and even MOAR POWA
  13. Mar 1, 2015 at 6:32 PM
    #3033
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    More expensive, probably even harder to find than E85 :luvya:
  14. Mar 1, 2015 at 7:23 PM
    #3034
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Whatever. Just do Meth/Water injection.
    that makes 91 into 105-110 easy.
    Granted, have to have a second tank..but it only every injects the meth/water when under boost. And it helps a lot with detonation..and temps...
    oh yea...
    and MOAR POWER!!!
  15. Mar 1, 2015 at 10:17 PM
    #3035
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :cool:
    That's a nice fan shroud there!
  16. Mar 1, 2015 at 11:20 PM
    #3036
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Sounds ridiculously complicated and unnecessary. :rolleyes:
    Where do I get one? :anonymous:
  17. Mar 1, 2015 at 11:27 PM
    #3037
    Blackdawg
    Monte
    Wyoming/St. Louis
    AEM makes a good kit :cool:
  18. Mar 2, 2015 at 3:57 AM
    #3038
    Supra TT
    Eric
    Indiana
    I thought about buying it :anonymous:
  19. Mar 2, 2015 at 6:04 AM
    #3039
    Blackdawg
    Monte
    Wyoming/St. Louis
    :der:
    Probably wouldn't help you a ton..
  20. Mar 2, 2015 at 7:14 AM
    #3040
    Supra TT
    Eric
    Indiana
    True, but it may help on that low end where I need the power. 1 hp is 1 hp. I mean the truck probably only has 20 ho anyway :D
    Besides, it's cool :luvya:
