45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. May 1, 2015 at 11:54 AM
    #3341
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ill have to find the thread, but Ive seen someone use Ford's 6.4L twin turbo assembly before. They can be found pretty cheap.
    More on it:
    http://www.dieselbombers.com/08-201...554-look-borgwarners-6-4l-turbo-assembly.html
    Edit, I could be mistaken, I think the build used the turbo form the 6.7L which was designed by Honeywell with one turbine but two compressor wheels for a single turbo that performed like a twin turbo.
    Here is their diesel option (VTN dual boost):
    http://turbo.honeywell.com/our-technologies/vnt-dualboost-turbochargers/
    This is option may be more your speed though:
    http://turbo.honeywell.com/our-technologies/gasoline-axial-dualboost-turbochargers/
  2. May 1, 2015 at 12:23 PM
    #3342
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    I'd love to see this thing running under its own power before I die :p
    ckeene9 and Supra TT like this.
  3. May 1, 2015 at 12:50 PM
    #3343
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  4. May 7, 2015 at 3:15 PM
    #3344
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  5. May 7, 2015 at 4:26 PM
    #3345
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Wrong......
    Started to build TWO TOYOTAS
  6. May 7, 2015 at 4:37 PM
    #3346
    Supra TT
    Eric
    Indiana
    This looks pretty sweet.
  7. May 7, 2015 at 4:58 PM
    #3347
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Why you gotta be stealing my jokes? :luvya:
  8. May 7, 2015 at 5:13 PM
    #3348
    Supra TT
    Eric
    Indiana
    Problem?
  9. May 7, 2015 at 5:14 PM
    #3349
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Of course not. "Insert penis joke here."
  10. May 7, 2015 at 5:18 PM
    #3350
    Supra TT
    Eric
    Indiana
    Haha, well I used the uncolored version, so technically I didn't steal all your ideas :D
  11. May 14, 2015 at 8:18 PM
    #3351
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Finally got the intercooler, radiator and winch arrangement figured out!
    This was my initial plan
    [​IMG]Untitled by Jonathan K, on Flickr
    Despite all the measuring as best I could prior to getting the parts, it was turning into a huge PITA trying to get it all to fit that way. The radiator would have to be offset at least 4" to the passenger side because of the steering box, the winch mount would've been tricky, and it took up way more space than what I finally ended up with.
    I moved the X forward and positioned at 90 degrees. I added some support for what is left of the OEM radiator bracing and mounted the hood pins.
    [​IMG]DSC09835 by Jonathan K, on Flickr
    [​IMG]DSC09836 by Jonathan K, on Flickr
    I rotated the drive assembly on the winch about 90 degrees so I could have better access, as it would've been completely stuck under the intercooler mount.
    [​IMG]DSC09838 by Jonathan K, on Flickr
    Moving the radiator back allowed my to mount it directly over the frame and it clears the steering box better than I could've hoped.
    [​IMG]DSC09841 by Jonathan K, on Flickr
    The intercooler would've been crammed into the grill had I went the original route.
    [​IMG]DSC09847 by Jonathan K, on Flickr
  12. May 14, 2015 at 8:23 PM
    #3352
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks great man. Glad it all fit.
  13. May 14, 2015 at 8:53 PM
    #3353
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks, bud. It's a larger step out of the way than it may seem. It took waaaay more time to figure this out than I care to admit.
    BTW, I ended up deciding to stick with the standard winch drum. It had more than enough room, so it almost seemed stupid not to.
  14. May 14, 2015 at 8:54 PM
    #3354
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Good fit!
    45acp[OP] likes this.
  15. May 14, 2015 at 8:59 PM
    #3355
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I'm glad you kept the full drum. Be handy with the few extra feet I'm sure at some point.
    Now just needs a motor...lol
    Will the IC piping clear the head lights?
  16. May 14, 2015 at 9:05 PM
    #3356
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That extra 40' of line will be handy to have. :cool:
  17. May 14, 2015 at 9:59 PM
    #3357
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yup, plenty of room.
    Hope I don't have to use it haha
  18. May 15, 2015 at 6:48 AM
    #3358
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    You can fit a steering shaft u joint on that? I know my Borgeson joints are pretty small and probably the smallest ones you can get. Lookin good though!
  19. May 15, 2015 at 8:55 AM
    #3359
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    That was my thought too. Especially with the set screw and lock nut poking out.
    Looking good Jon!
  20. May 15, 2015 at 10:57 AM
    #3360
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
