45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Jan 7, 2016 at 2:00 PM
    #3761
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Just saved $100 wooo! :rolleyes:
    I was close to spending the $100 on the LCE balance shaft delete kit, but after looking over everything I realized it wasn't necessary. Aside from plugging the passenger side oil pressure port, all that is needed is to remove the balance shaft bearings and re-orient them to block off the oil gallery passages. I'm not sure if I had to, but I also disassembled the No.2 timing chain tensioner and plug welded the hole on the backside that feeds the mechanism. That way oil flow wouldn't be diverted out of the channel that supplies the No.1 timing chain with oil. Quite literally everything else gets thrown out. Murphy would approve.
    [​IMG]DSC00150 by Jonathan K, on Flickr
  2. Jan 7, 2016 at 5:16 PM
    #3762
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The thermostat that URD sells is also available on Amazon for about $20 less, FYI.
    Here is the V6 one but I think it can be used in the 2.4/2.7L (???) - not sure.
    http://www.amazon.com/Stant-14077-T...2215712&sr=8-1&keywords=Tacoma+170+thermostat
  3. Jan 7, 2016 at 5:33 PM
    #3763
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I don't think so. I noticed the Nippon site provided dimensions and so I did a search for the 5VZ counterpart, and the size is indeed different.
    t-stat for the
    3RZ - Dimension (mm): A:56 B:43 C:33 D:28
    5VZ - Dimension (mm): A:56 B:48 C:44 D:30
    I just checked the internal dimensions of the thermostat housing and the one intended for the 5VZ would be too long (C).
    So I guess now I just gotta figure out if I should stick with the 180F or if it's worth bumping down to a 160F.
    Since I'm going to keep the bypass on the back of the cylinder head, I'm going to try to modify it to accept NPT fittings.
  4. Jan 7, 2016 at 5:41 PM
    #3764
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  5. Jan 7, 2016 at 7:57 PM
    #3765
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Same company that makes the 'fail-safe' t-stats. I gotta order a couple OEM Toyota parts anyway so that might be my best route. And this was posted on CT. I guess stock 180F is optimal, regardless of engine.
    http://www.carnut.com/ramblin/_cool3.html
    Edit: FWIW, I just looked at my original t-stat. Seems Nippon is OEM. Old-school 'Taq' logo followed by "NTCL 82'C"
  6. Jan 12, 2016 at 5:15 AM
    #3766
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  7. Jan 12, 2016 at 5:40 AM
    #3767
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Why did you go with flat terminals? Should've gone with screw terminals for vibration and impact resistance.
  8. Jan 12, 2016 at 5:47 AM
    #3768
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'd have more peace of mind by soldering and using heat-shrink tubing to be honest.
    m3bassman likes this.
  9. Jan 12, 2016 at 6:41 AM
    #3769
    ckeene9
    Chesterfield, VA
    See Build Thread
    Understand, difficult for field repairs or changes though.
    45acp[QUOTED][OP] likes this.
  10. Jan 20, 2016 at 10:45 AM
    #3770
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Pulled the cylinder head out of hibernation to dry fit a few things, make sure I have all the bolts, etc.
    I tapped the water bypass/thermostat plate with 1/2 NPT. I removed the tube from the cylinder head rear plate and also tapped for 1/2 NPT. A couple 1/2 NPT to -12 AN adapters and some hose fittings, and I have my water bypass hose setup done. $85 for that alone. :anonymous:
    [​IMG]DSC00153 by Jonathan Krajnak, on Flickr
  11. Jan 20, 2016 at 10:49 AM
    #3771
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Damn Saran wrap threw me off..lol
  12. Jan 20, 2016 at 11:17 AM
    #3772
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    That's the new head gasket. Self-sealing. :luvya:
    Talked with Wes @ LCE yesterday to figure out what compression I need. Looks like I'm going to go with the 8.3:1 rod/piston kit and the .040 MLS head gasket which will bring it to 8.36:1 compression. He said it's what they normally use for turbo setups and should give a bigger tuning window. I like the fact that the set is already balanced and comes with the coated bearings. As soon as I can get the money together, I'm going to get pretty much everything I need to finish the engine (minus the intake and turbo manifolds, and turbo). Get the block honed, crankshaft polished, and get this bish assembled. :cool:
  13. Jan 20, 2016 at 12:14 PM
    #3773
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sick! Gonna be sweet
  14. Jan 20, 2016 at 1:34 PM
    #3774
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    For full disclosure... I was a moron and forgot (more like 'didn't think it was needed') to use some oil while using the tap on the thermostat/bypass plate and snapped the plate at the thinnest part closest to the bypass. I had it bolted down while using the tap, but apparently that wasn't enough. I already ordered a new one from Toyota ($26 :rolleyes:). I'll have to fined a way to properly support the odd shape in the vice next time. Tapping for NPT is a PITA.
  15. Jan 28, 2016 at 6:53 PM
    #3775
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    So I was driving the '81 today and put it in neutral as I was coasting to a stop sign near the house. All of a sudden the RPMs drop and the engine stalls. I restart it, have no trouble applying throttle and as soon as I put it in neutral to cast again, the same thing happens. Get home and decide to pull the carb because the seals were leaking anyway. 'Luckily' I pulled a what looked to be a freshly rebuilt carb from an '82 while I was at a junkyard in Denver last month.
    But... there are several major differences, mostly vac lines. There's also an 'idle up' diaphragm in place of the idle adjustment screw.
    Junkyard '82 carb on the left, my leaky AF '81 on the right.
    [​IMG]DSC00163 by Jonathan Krajnak, on Flickr
    [​IMG]DSC00169 by Jonathan Krajnak, on Flickr
    [​IMG]DSC00170 by Jonathan Krajnak, on Flickr
    [​IMG]DSC00168 by Jonathan Krajnak, on Flickr
    I can't find any diagrams that show the vac line route for the idle up diaphragm. It looks like I can just block the tubes near the top? It appears to be for "Fed only OPT"... whatever that is.
    Anyone care to take a whack at what I'm supposed to do here? :luvya:
    At any rate, this clusterf*#@ of an engine bay is bad enough that I might just do the LCE de-smog kit sooner rather than later. And by later I mean now. :violent:
  16. Jan 28, 2016 at 10:17 PM
    #3776
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  17. Jan 29, 2016 at 8:02 AM
    #3777
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I saw a 4.8l v8 on pirate for pretty cheap, you should just buy that engine and turn your truck into a space ship with it and fly around the earth with it. :stirthepot:
    ckeene9 and Ugly Betty like this.
  18. Jan 29, 2016 at 10:51 AM
    #3778
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Yes it is, has to do it at school a couple of times.
  19. Jan 29, 2016 at 11:35 AM
    #3779
    One_Wicked_Yota
    One_Wicked_Yota New Member
    Trying to cut fenders about 1.5"-2" and roll them. I was wondering if y'all could give me in ideas about what to do when I gut the fender right below the gas cap. I would like to not have to move it but if I cut my desired length the rolled fender would be right with the gas cap.
  20. Jan 29, 2016 at 12:03 PM
    #3780
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    This and call it good... with a bow on it...
