45acp’s DIVORCED build!
Discussion in '1st Gen. Builds (1995-2004)' started by 45acp, Jan 15, 2012.
  1. Feb 24, 2014 at 7:10 PM
    #1861
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  2. Feb 24, 2014 at 7:18 PM
    #1862
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    least something freaking happened...jesus..
    you gonna fill the boat sides with UHMW?
  3. Feb 24, 2014 at 7:24 PM
    #1863
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yeah, uhmw. Gotta read up more in regards to mounting, but that's the 'plan' anyway. :D I'll probably gusset the crap out of it.
  4. Feb 24, 2014 at 7:42 PM
    #1864
    Blackdawg
    Monte
    Wyoming/St. Louis
    Naturally..of course..
  5. Feb 24, 2014 at 7:50 PM
    #1865
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Wow something actually happens in the thread :eek: it's ok 45 you can post more don't be afraid we're not here to judge you on how slow it's going :D
  6. Feb 24, 2014 at 8:08 PM
    #1866
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I sure as hell am!
    :p
  7. Feb 24, 2014 at 8:25 PM
    #1867
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Im just glad he actually started to fix something instead of tearing more down!
  8. Feb 24, 2014 at 8:43 PM
    #1868
    Madjik_Man
    Colorado Front Range
    Boat sides? How fucking deep a water crossing are you planning?
  9. Feb 24, 2014 at 8:45 PM
    #1869
    Blackdawg
    Monte
    Wyoming/St. Louis
    6' boulder and 10' rock cliff high "water"
  10. Feb 24, 2014 at 8:49 PM
    #1870
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Stap a out board to the tail gate like top gear did their old hilux! lol
  11. Feb 24, 2014 at 9:52 PM
    #1871
    Slodgetto
    Slodgetto Über Posre
    Silas
  12. Feb 25, 2014 at 6:32 AM
    #1872
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Usually the uhmw is a skin, meaning it goes over the plate. The stuff isn't really strong enough on its own to bridge any gaps. I would go minimum 3/16" on the boatsides, then skin them with 1/4" or 3/8" uhmw. Prolly 3/8" that gives you enough thickness to work with so you can countersink the fasteners into it.
  13. Feb 25, 2014 at 7:00 AM
    #1873
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    That sounds doable. I had initially thought gusseted 1/8" plate backing with 1/2" uhmw. I can always dimple die the hell out of the backing plate to reduce weight, right? :D
  14. Feb 25, 2014 at 7:05 AM
    #1874
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I think you have done enough weight reduction :rolleyes: go 3/16th . The way you guys wheel out there you will need it :cool:
  15. Feb 25, 2014 at 7:28 AM
    #1875
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Haha yeah, doesn't hurt though, right? Looking for that low COG. :eek:
  16. Feb 25, 2014 at 7:49 AM
    #1876
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Just think about it this way.
    You'll save about 2.5# per sq. ft. using 1/8" over 3/16"...not much total for the area you are plating for the boatsides.
    Then consider the amount of work it would be do redo those boat sides if they turn into a raisin after a year. Is it worth it for the 20# you might save?
    Also the boat sides will basically be your sliders, do you think 3/8" plastic and 1/8" plate will hold up the weight of your vehicle/hits?
    Don't skimp where it counts the most.
  17. Feb 25, 2014 at 7:53 AM
    #1877
    Blackdawg
    Monte
    Wyoming/St. Louis
    1/2" UHMW would be totally fine..the stuff is stronger and more durable then your giving it credit for. It's not abs shit.
    Will it hurt to do 3/16s..nah. Might as well. Already going big so why stop now haha
  18. Feb 25, 2014 at 8:40 AM
    #1878
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    really uhmw isn't abs, maybe that's why they have different names :rolleyes:
    It still isn't strong enough to span between the legs for his supports.
    3.1 ksi yield for uhmw, 36ksi yield for shit steel
    Lets do some math. Look at a 6" strip of material for loading purposes.
    Max stress=wL/4z
    w say 2,000# (truck side held up on boatside)
    L=(length between supports)
    z=section modulus=(bd^2)/2
    b=6" (width of strip analyzed)
    d=1/2" material (for uhmw
    d=1/4" for steel
    so z=.25 in^2 for UHMW
    z=.0625in^2 for steel
    back solving using the yield for max stress and solving for L the span its good for....
    1/2" UHMW would be good for a span of 1.55" without yielding and 1/4" steel would be good for 4.5" span without yielding.
    Simple math tells you 1/4" plate is good for 3x the span the uhmw is.
    Now if you really want things to get interesting, I suggest you take a look at the deflection incurred by those max stresses allowable, and you will quickly see why you need to have UHMW backed by steel. Especially for something critical to cab structure like boatsides.
    I suugest he use 3/16" and add a little more (not much) structure behind it, and maybe get a decent grade of steel like 1045 which has a yield of 65 ksi, anything but A36. He will pick up a tiny bit of strength from the UHMW backing, but negligible in the grand scheme.
    Hell the yield strength of UHMW is comparable to most woods, lol.
  19. Feb 25, 2014 at 8:50 AM
    #1879
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Now there will be some other things he has going for him like the tensile properties working to help since the plate/uhmw will be attached at all sides, and not simply a 6" strip being loaded arbitrarily, but I was just trying to show that UHMW has no usable structural properties when building a truck.
    It makes things slick and slides nice, that's it.
  20. Feb 25, 2014 at 9:00 AM
    #1880
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    UMMMMMMMM I need a translator... Im just here for the pictures! :eek:
