45's vs. Recommended 65's
Discussion in 'Wheels & Tires' started by AZarchitect, Jan 22, 2013.
  1. Jan 22, 2013 at 8:49 PM
    AZarchitect
    AZarchitect [OP] Well-Known Member
    Mesa
    01 PreRunner TRD SR5 2x4
    Stock
    New to TW,,,Had LT245/75/R16 AT's installed tonight. The previous owner had the same size on there but they were cupping and had un-even wear, so I had them replace to match the same size. Anyone see problems with this tire size down the road?
  2. Jan 22, 2013 at 8:55 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Uneven wear can be caused by many things and I'll venture to say with most people it could be driving aggressively/turning sharply, improper tire inflation, not rotating tires. Could also be the alignment too, might want to have that checked so you didn't waste your money on brand new tires because they can be ruined quickly.
  3. Jan 22, 2013 at 9:18 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    245/75r16 is what came from on my Tacoma (brand new). Many like wider and or taler tires for that agressive look. But your size tire weighs less and will give you the best gas mileage id properly inflated. Best traction and more ground clearance beg for more tire, but then you gt into buying longer shocks, taller springs, cab mount chop, and the list goes on, and on.
    I think you can go to 265/75R16 without mods, or 235/85R16 if you like the tall & Skinny look without mods, but bigger than this and you need to start triming stuff to avoid rubbing.
  4. Jan 23, 2013 at 3:31 AM
    AZarchitect
    Mesa
    Stock
    Thanks! That puts my mind at ease. I was really hoping that others had done this also. I really do like the look of the 45 tire size as opposed to 65, which was a little beafier. Like you said the 45 seems to have more clearance.
    As for the alignment, I will have that done asap to avoid any unnecessary wear and tear. I'm also thinking there may be a bearing going out up front since there is a faint grinding noise (or what have you) as im rolling down the street. I can only hear it once per rotation on passenger side...That may also be part of the un-even wear on the last set of tires.
  5. Jan 24, 2013 at 2:54 PM
    modmike
    modmike Member
    mike
    Bay Area
    06 TRD Off Road 4x4 DC
    AZ, I'm happy to see that someone else likes the look of the 245's (with a stock suspension). I'm looking at the Duratracks and they don't come in my stock size of 265/70/16. The closest size is the 245/75/16, which is a bit smaller. Most guys here, from what I've read, much prefer the bigger option of the 265/75/16 because "it fills the wheel well better". To me though, they look a little too big with the stock suspension.
  6. Jan 24, 2013 at 3:05 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mine came with 245/75R16 from the factory as did many other base model 4x4s.
  7. Jan 24, 2013 at 4:20 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I am running 245/75-16 as three season tires and 245/70-75 for winter tires...nothing wrong with the 245 size...might go with 265/75-16 for three season when I need to replace.
    Howard
  8. Jan 24, 2013 at 4:23 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    smaller size should give more low end power, and might throw your speedometer off a little.
  9. Jan 24, 2013 at 4:37 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Basically the same size as 265/70/16 which is stock.
    Current Tire Size: / R
    New Tire Size: / R
    Your Calcs (x): Previous Tire Calculations
    Side by side Overlay
    Current TireNew TireDifferenceDiameter inches (mm)30.47 (773.9)30.61 (777.4)0.14 (3.5) 0.5%Width inches (mm)9.65 (245)10.43 (265)0.79 (20) 8.2%Circum. inches (mm)95.72 (2431.28)96.15 (2442.27)0.43 (11) 0.5%Sidewall Height inches (mm)7.23 (183.75)7.3 (185.5)0.07 (1.75) 1%Revolutions per mile (km)661.93 (411.31)658.95 (409.45)-2.98 (-1.85) -0.5%
  10. Jan 30, 2013 at 8:37 PM
    AZarchitect
    Mesa
    Stock
    Awesome! Ya, I'm definately happy w/ the 45 skinny goodyear wranglers(walmart). A buddy of mine out here has the larger 65's and he has had some rubbing here n there when he runs it hard in some terrain.
  11. Jan 30, 2013 at 8:41 PM
    AZarchitect
    Mesa
    Stock
    Thanks all for the feedback. I don't drive a lot, but I'm checking the fuel economy. I will post once I get down to 1/2 tank along with the tire spec.
  12. Jan 31, 2013 at 6:00 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Nothing wrong with the 245s, the biggest complaint is the Dunlop AT20s.
  13. Mar 13, 2013 at 9:18 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Yeah I'm looking to go 245/75/16 BFG AT's when I use up my Dunlop AT20's some more - probably will run them through summer and put on the BFG's for start of winter. It is good to see that you guys actually like this tire.
    I was starting to get a freaking complex from reading all these damn posts of everyone basically shunning the 245 tire size.
    MPG's are a big deal to me as well, just want a better tire.
  14. Mar 14, 2013 at 2:45 PM
    choyt
    choyt Well-Known Member
    wayne
    new york
    2015 tacoma
    I run the 245 steelies in the winter and now 265-70's on TRD OR wheels in the summer I like the smaller skinny tire for snow.
  15. Mar 16, 2013 at 6:24 PM
    AZarchitect
    Mesa
    Stock
    I really like the tires. They are the Goodyear Wranglers from walmart, aggressive look but soft as any on pavement. No vibration, no noise.
    As far as size, haven't had any weird problems at all. I guess I was just excited to have a new truck. Worried at every turn, especially when they are expensive decisions.
    I have had two people ask me if the truck was lifted. The smaller tire gives the illusion of a really small lift I guess since it doesn't fill up the wheel well as much. No complaints. Thanks for the comments.
  16. Mar 16, 2013 at 7:05 PM
    TexasCub
    TexasCub Well-Known Member
    2013 PreRunner
    Mine came with the 45's couldn't help but think it looked like a parts delivery truck with the smaller tires. Upgraded to 265/75-16's and not only does it look better but my speedo is now accurate!
  17. Mar 16, 2013 at 7:18 PM
    EatMyTacomaDust
    How did they affect your odometer? I'm hearing the odo's are off from the factory too.
  18. Mar 16, 2013 at 7:22 PM
    AZarchitect
    Mesa
    Stock
    These are the tires in the image. In terms of $$, I suppose the 265 is an upgrade, more tire/more money.
    These are E rated, soft on pavement and I would say an upgrade maybe from delivery truck style P rated tires, since they are A/T/aggressive.
    Like I said, no complaints. Depends on what you like and what you want to spend. Balance-no pun intended
  19. Mar 17, 2013 at 6:38 AM
    TexasCub
    2013 PreRunner
  20. Mar 17, 2013 at 6:41 AM
    TexasCub
    2013 PreRunner
    Its not the design of the tire, its the size of the tire. Your E-rated 245's are harder on fuel mileage and performance than the larger P rated 265 AT tire IMO, just cuz they weigh more. I personally dont care for the way the trucks look with the smaller tire configuration. And if you leave the black top for trail riding or rough roads more ground clearance is never bad.
