4LO and 5SPD automatic transmission question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by supralight, Oct 11, 2010.
  1. Oct 11, 2010 at 7:20 PM
    supralight
    supralight [OP] Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Anybody else noticed that in 4LO, you have only 4 speed with the 6cyl 5spd transmission? I even tried with manually selecting every single speed, and 5th does not load in. Why would they have done it like that... is that a normal behavior of automatic trucks with 4X4 4LO?
    I hope it's not just to limit speed in 4LO.
  2. Oct 11, 2010 at 7:21 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Its normal. In 4L you have no need for overdrive.
  3. Oct 11, 2010 at 7:23 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    How fast would you want to go in 4 low? I can't imagine ever needing 5th gear....
  4. Oct 11, 2010 at 7:24 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Never tried to go in 5th while in 4lo
    If you need to go faster it should be in 4hi
  5. Oct 11, 2010 at 7:30 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I probably never go over 15 in 4lo. If I need/ want to go faster thats why I have 4hi and 2hi.
  6. Oct 11, 2010 at 7:32 PM
    supralight
    Dan
    Earth
    Could be of use, when you get in a small stretch between 2 crawling areas... no need to switch out of 4LO. That would be well over 100KPH top speed, engine would not be over-reving, and yes I like to go fast. Had lot of fun with my manual in 4LO for that reason.
    Point of the thread is ''why they did that'', EX: overheating of bearings... This is not a moral/ethical thread.
  7. Oct 11, 2010 at 7:51 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    How would you know? How fast in the world did you go in L4? Red Line City!!!
  8. Oct 11, 2010 at 7:56 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    At fast speeds why would you need 4L? 4H would be more than acceptable I mean damn 65mph in 4H! I assume they didn't incorporate OD into the equation because you will never get 4L up to a speed where you could utilize it, 4L is not for racing or crusing, its a crawling gear. To me it would be like wanting to drive on the interstate in 1st gear, why don't the let you do that?.....because it will pop first.
  9. Dec 9, 2010 at 5:56 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :rofl:
  10. Dec 9, 2010 at 6:04 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Maybe the OP doesn't want to stop, put it in neutral, shift to 4HI, put it back in gear, and start driving again every time he gets out of a small section of trail that needs the slower 4LO power? :notsure:
    I know I rarely use 4LO on trails for that simple fact. It's annoying to not be able to shift between 4HI and 4LO on-the-fly. Manual says it's supposed to be possible at 5mph or less, but I've NEVER been able to do that in my 6spd. I ALWAYS have to stop, shift to neutral, clutch to the floor, THEN move into/out of 4LO. Makes it annoying when you're trying to keep up or keep from holding up wheeling buddies.
    Although, if you leave it in 4LO all the time and get stuck the only real option left is a winch. Unless you have a locker and that's enough to get you out.
  11. Dec 9, 2010 at 6:04 PM
    Hibby
    Hibby Well-Known Member
    Luke
    Central Pa
    2008 Trd Sport 4x4
    tires, shocks and a sticker!
    The taller gears are weaker! You think about it, your torque multiplication is increased by two and a half times that is likely enough stress to cause trouble.
  12. Dec 9, 2010 at 6:25 PM
    Hibby
    Luke
    Central Pa
    2008 Trd Sport 4x4
    No i mean in general the taller gears are weaker. I don't think anybody out there is going to be bashing around wot in 4Lo in the upper gears. Just saying when I take my jeep out and am playing hard I don't like goin above 3rd gear in low range granted i have a 4 to 1 low range. But anyways back on topic...
  13. Dec 9, 2010 at 6:45 PM
    piercedtiger
    Jon
    Southern Tier, NY
    That makes sense. Last time I wheeled was with a buddy who had a jeep cherokee he didn't care if he beat the snot out of. He just left it in 4HI and used more skinny pedal. :rolleyes: I wasn't about to bounce my truck off the rocks. He also had an auto whereas I had to shift gears if I needed more power. On some parts that meant 4LO to get going again as I lost too much momentum downshifting. (And being gentle on the skinny pedal.) If I had sliders and skids I may have been more brave. :D In the end though I had to jump start him twice and tow it for a bit because he sucked in water, and drained his battery trying to get it started again. :laugh:
  14. Dec 9, 2010 at 6:59 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ^^ this
  15. Dec 9, 2010 at 7:10 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Does no one read the manual?
    :facepalm:
  16. Dec 9, 2010 at 7:11 PM
    supralight
    Dan
    Earth
    I am no Off-Road expert, and never implied so. But I DO LIKE Off-Road, and I also do like to HAVE FUN with my truck, in gravel, snow, in both 4HI and in 4LO.
    Also, I may be too lazy to shift out of 4LO for the stretches...
    But at least, I bought a truck I like, and I don't sink down threads because others have what I don't (and would like).
    But funny one still hehehe thumbs up on bringing this up :)
  17. Dec 9, 2010 at 7:56 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Haha
    Seriously OP are you just stupid or something?
  18. Dec 10, 2010 at 2:00 PM
    Ninja14
    Ninja14 Well-Known Member
    Arkansas
    02 Tacoma DC 4x4 TRD OffRoad - 96 4runner 4x4
    isnt it in japanese :rolleyes:
  19. Dec 10, 2010 at 2:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    lol, maybe his version is.
  20. Dec 10, 2010 at 3:38 PM
    David K
    Maybe if they added the words (most of us know, I hope): "OVER DRIVE" for 5th gear... and all LOW RANGE is "under drive"
    Yes, not bird nor plane or even frog...
