4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Oct 9, 2015 at 9:39 AM
    #241
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    My only issues are when driving on snow packed roads. I can't stop as well as I could without abs
  2. Oct 9, 2015 at 9:42 AM
    #242
    pudge151
    Sean
    Connecticut
    My tires are and always have been fine. It's the abs. I agree that I'd rather have a switch so I can turn it off when roads are snow covered and on the rest of the time
  3. Oct 9, 2015 at 9:42 AM
    #243
    pudge151
    Sean
    Connecticut
    I have only had issues when it kicks in. Which has only been in packed snow
  4. Oct 9, 2015 at 9:57 AM
    #244
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    10-4... is not the first page of this thread have the how to, or do you fear the 2011 is different than your 2008?
  5. Oct 9, 2015 at 10:03 AM
    #245
    pudge151
    Sean
    Connecticut
    Correct I know the 2008 is different because it has no vsc and has the old mechanical lsd. No fancy electronics. I guess I need to go out to truck and see what my wires look like. There are 3 different how to's posted here and all are different methods and use different wires
  6. Oct 14, 2015 at 12:07 PM
    #246
    pudge151
    Sean
    Connecticut
    So I did the 2 position switch. Light green wire. Turn car on flip switch and nothing happens. No ABS light at all
  7. Oct 14, 2015 at 1:01 PM
    #247
    pudge151
    Sean
    Connecticut
    i even tried just turning on the truck with the wire cut, no ABS night comes on. shouldnt it come on and stay on?
  8. Oct 14, 2015 at 1:54 PM
    #248
    pudge151
    Sean
    Connecticut
    I used this on/off interruptor switch. Has 2 connections on the back.
    But like I said even if I disconnect the wires leaving an open circuit the abs light does not come on
  9. Oct 14, 2015 at 3:00 PM
    #249
    ATLien
    ATLien Well-Known Member
    Portland
    2013 DCSB SR5
    Money Pit
    sounds like you have the wrong wire then - all the switch would be doing is 'cutting' the wire
  10. Oct 14, 2015 at 3:03 PM
    #250
    pudge151
    Sean
    Connecticut
    I tried 2 different ways to do it from write ups here. I cut the wire specified in the write ups. Light green on both accounts
  11. Oct 14, 2015 at 5:30 PM
    #251
    pudge151
    Sean
    Connecticut
    Anyone have this issue ?
  12. Oct 14, 2015 at 6:02 PM
    #252
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  13. Oct 14, 2015 at 6:31 PM
    #253
    pudge151
    Sean
    Connecticut
  14. Oct 14, 2015 at 6:45 PM
    #254
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I'm guessing this (Caveman Method) will work for you, the major difference between the 2 is grounding the switch.
    I originally tried the caveman mod, but after popping 3 fuses and getting frustrated, I used a simple spst (2-pole) switch without the ground and problem solved.
  15. Oct 14, 2015 at 6:57 PM
    #255
    pudge151
    Sean
    Connecticut
    Nope I tried the caveman thread method first. Didn't work. I thought you were referring to a different thread. I tried it with a on off 2 pole switch too. The abs light didn't even come on when I cut the wire.
  16. Oct 14, 2015 at 6:58 PM
    #256
    pudge151
    Sean
    Connecticut
    Only thing I can think is for some reason the 2008 has different wiring. Makes zero sense but what else could it be
  17. Oct 14, 2015 at 7:22 PM
    #257
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Can you post pics of your plugs/harnesses next time you're down there?
    And just to confirm, when your ABS does kick-in (packed snow example), does the light come on?
  18. Oct 14, 2015 at 7:26 PM
    #258
    pudge151
    Sean
    Connecticut
    I can't say that I have ever seen the light go on when the abs kicks in.
    When I turn the truck on I do see it flash on then go off
  19. Oct 14, 2015 at 7:35 PM
    #259
    pudge151
    Sean
    Connecticut
    I cut that light green wire that I taped up wit u blue tape when doing the caveman mod
  20. Oct 15, 2015 at 3:14 PM
    #260
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    That is the correct wire for the Caveman mod, for sure. Did you use a 3-pole grounded switch when you tried it?
