4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Jan 13, 2016 at 4:06 PM
    #281
    imageomega
    imageomega Well-Known Member
    Jarrod
    You've got me stumped. Time for the voltage meter.
    Does the abs light come on when you first turn on the truck? Could be that the indicator light is dead.
  2. Jan 13, 2016 at 9:40 PM
    #282
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Yeah it does turn on and then quickly off when I start the truck
  3. Jan 16, 2016 at 6:18 PM
    #283
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    My 08 sport was done today used the caveman method and grounded worked perfect. Both abs light and rear locker light come on when switch is enabled
    pudge151 likes this.
  4. Jan 16, 2016 at 6:23 PM
    #284
    pudge151
    Sean
    Connecticut
    Back to the drawing board I guess
  5. Jan 16, 2016 at 6:58 PM
    #285
    303tacoma
    Rebecca
  6. Jan 16, 2016 at 7:37 PM
    #286
    pudge151
    Sean
    Connecticut
    Sounds good man. I'll try it. Did you by chance notice if the abs light came on when the wore was cut before you hooked up the switch? Or would you be willing to disconnect the switch and see if the light comes on? In my case the light never came on
  7. Jan 16, 2016 at 7:45 PM
    #287
    303tacoma
    Rebecca
    No I didn't notice the truck wasn't started until we were done hooking the switch up, and the wires are soldered to the switch so i really don't want to unhook it. Try hooking up a switch and grounding and then start the truck.
  8. Jan 16, 2016 at 7:46 PM
    #288
    pudge151
    Sean
    Connecticut
    Will do. Thanks
  9. Jan 16, 2016 at 7:48 PM
    #289
    303tacoma
    Rebecca
  10. Jan 20, 2016 at 10:11 PM
    #290
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I am wanting to try the ABS mod on my Trd sport 2wd prerunner, just to conform will this work on my truck even though I am not 4wd? And would it disable my vsc and trac (auto lsd) as well? Or would those be still functioning? Thanks! I'm a bit confused as to what all the ABS mod effects.
  11. Jan 21, 2016 at 3:13 PM
    #291
    imageomega
    Jarrod
    I dont know if the wiring is the same on a 2wd prerunner, though I would assume so...
    Regarding what it affects; Disabling ABS will effectively disable VSC and Trac/LSD. The Tacoma LSD is an open-diff, brake assisted LSD, so turning off ABS functionality means this goes offline with it (I think its 07/08 when they switched from a mechanical LSD but I dont remember exactly). Similar with VSC; it uses ABS as its primary mechanism to stabilize, so no ABS = no VSC.
  12. Jan 21, 2016 at 3:15 PM
    #292
    imageomega
    Jarrod
    @pudge151 Any news on your situation? No new ideas out of me, but curious if you've learned anything while diagnosing.
  13. Feb 17, 2016 at 9:01 PM
    #293
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Watching this for later when wife isn't out in truck and I have time to play
  14. May 18, 2016 at 2:45 AM
    #294
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    I'll be doing this later when I get a nice oem looking switch etched for it.
  15. Aug 1, 2016 at 2:06 PM
    #295
    DrFunker
    DrFunker Well-Known Member
    Anyone do this mod on a 2015 Sport yet?
  16. Aug 1, 2016 at 4:13 PM
    #296
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    Mine is a 14 sport and I did the mod.
    DrFunker[QUOTED] likes this.
  17. Aug 1, 2016 at 6:49 PM
    #297
    DrFunker
    Thanks @Ridgeline001
    Is it as straightforward as it sounds? Cut the green wire, install switch.
  18. Aug 1, 2016 at 8:10 PM
    #298
    Ridgeline001
    Oregon
    2014 DCLB Sport 4wd
    It was that simple. Kinda a pain in the ass for getting under the dash with broad shoulders but the write up is spot on. And well worth it in my opinion.
  19. Aug 2, 2016 at 3:27 AM
    #299
    DrFunker
    Good to hear.
    @Unchained 5150 @Tractorman
    This is the one!
    Unchained 5150 likes this.
  20. Aug 2, 2016 at 4:29 AM
    #300
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
