4LO-Trac & ABS Kill Switch - Why/Why Not?
Discussion in 'Technical Chat' started by Benson X, Jan 10, 2013.
  1. Dec 5, 2013 at 11:14 PM
    #121
    Broseph Stalin
    Broseph Stalin Well-Known Member
    Justin
    Santa Barbara
    '10 white dbl cab LB trd sport
    15% tint , Bak Flip G2 tonneau cover, poplock WeatherTech mats, FX-R retrofit, BHLM, eyelids, smoke Lamin-X, daystar leveling kit, studded snow tires and a shitload of sand bags
  2. Dec 6, 2013 at 7:04 PM
    #122
    Broseph Stalin
    Justin
    Santa Barbara
    my truck got hit by an uninsured driver today FML :(
    Grounded the switch and it worked! however i wanted to switch the way the plug sat and undid the connection w/o disabling battery and now have the abs and ebrake light on constantly, ideas?
  3. Dec 7, 2013 at 10:01 AM
    #123
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    This thread and exchange is getting some sidebars and loss of understanding of the levels of traction control... Let me try and visualize it to help. This is for 2009 and newer Tacomas:
    2WD
    1) TRAC in 2WD (standard mode at startup): Limited slip using ABS, with engine regulation. Light traction control.
    2) Quick Press of VSC button: AUTO LSD ON/TRAC OFF: Limited slip but no engine regulation, ie. strong traction control. Helps to get unstuck if 1 tire is spinning. VSC is off under 30 mph.
    3) Stop moving, press and hold down VSC button until light comes on: VSC OFF/TRAC OFF: No traction control, no limited slip.
    4WD-HIGH:
    1) TRAC (standard mode at start up), 2009-2011: Limited slip with no engine regulation/ strong traction control. 2012+: Limited slip with engine regulation/ light traction control.
    2) 2012+ Quick Press of VSC button: TRAC OFF: Limited slip with no engine regulation/ strong traction control.
    4WD-LOW:
    1) Standard Mode is no traction control/ no limited slip.
    2) A-TRAC Button pressed (Off Road TRD only): Near locker-like traction control on front and rear tires. Works anytime sensors detect tire spin/ traction loss. Matches rotation on each side of axle using ABS.
    3) Rear Locker on (Off Road TRD only): Locks rear axle, suggested for emergency only and not over 5 mph as steering is affected. ABS is disabled.
    4) Rear Locker + A-TRAC (Off Road TRD only): Locks rear axle + A-TRAC on the front axle, but only when vehicle speed drops below 3 mph.
    jsev likes this.
  4. Dec 7, 2013 at 10:06 AM
    #124
    BradyT88
    BradyT88 Well-Known Member
    What of I don't have VSC button?:stirthepot: haha I also don't have an Atrac button...
  5. Dec 7, 2013 at 10:42 AM
    #125
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Thanks for the detailed explanation David. There's also the diagrams/flow-charts on Page 1 as well.
  6. Dec 7, 2013 at 10:56 AM
    #126
    David K
    Then I guess none of this applies to you?! :rolleyes: LOL, have a nice day!
  7. Dec 7, 2013 at 10:58 AM
    #127
    David K
    Yes, I saw that... from my Photobucket album, too... Happy to be of service!
    Our Tacomas are such great vehicles, it is important that we all understand how to use them to their fullest potential.
  8. Dec 7, 2013 at 12:31 PM
    #128
    BradyT88
    But I still have Trac, VSC and Atrac. Just no buttons. Haha
    I think there might be some more differences between the pre-09 and post 09 systems than we think or the naming system is slightly different. Although maybe there is even more tol it than that since 06 was when the added the VSC off button. 05's don't have one.
    One example is you listed no Trac is standard mode in 4Lo. For me Trac is always on in every mode until I turn it off using one of my kill switches I wired in or I lock my rear locker.
  9. Dec 7, 2013 at 9:18 PM
    #129
    Broseph Stalin
    Justin
    Santa Barbara
    got my switch all working. for 2 wheel drive trucks you must ground out the switch. Use a 3 pronged switch.
    now off to call the bitch that ran into my parked truck :(
  10. Dec 7, 2013 at 9:40 PM
    #130
    BradyT88
    Nice man! Glad it works finally!
    And sucks man... good luck man!!!
  11. Dec 7, 2013 at 11:11 PM
    #131
    David K
    Yes, I should qualify that I am talking about 2009 + models only with the details. Thank you!
  12. Dec 7, 2013 at 11:17 PM
    #132
    BDBSoCal
    BDBSoCal The Safety Guy
    Brad
    SoCal
    Silver 2008 SR5 V6 4x4 TRD Sport
    Just starting...
    When I search for things, like limited slip differentials, I regularly find your excellent posts for the newer models. So far, I haven't been able to locate anything similar for the 2005-2008 years. Is there anything you can point me to?
    I am trying to fully understand the LSD on my Sport, and what it can and shouldn't do. My biggest concern is that Toyota went to the electronic LSD because there was a problem with our mechanical ones. I haven't found any evidence of that anywhere yet. But if there are situations where they fail, I'd like to know so I can avoid them.
  13. Dec 8, 2013 at 4:35 AM
    #133
    BradyT88
    I don't know of anywhere to point you but in 09+ models the full traction control system became standard instead of optional. They already knew how to make the traction control work as an LSD so there was no point in putting a mechanical one in because it would then have two LSD in the rear and neither would probably work quite right because the two might interfere with each other.
  14. Dec 8, 2013 at 9:02 AM
    #134
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Lol, I forgot I grabbed those from your "Explanation" thread. :D
    +1
  15. Dec 8, 2013 at 9:36 AM
    #135
    David K
    GP3 covered them in this thread:
    http://www.tacomaworld.com/forum/te...ds-vsc-trac-hac-dac-alsd-atrac-explained.html
    As for the issues with mechanical limited slip (2005-2008 Sport TRD rear differentials): The LSD clutch pads will wear out someday. Brake pads are easier to change and cheaper, too.
  16. Dec 8, 2013 at 9:58 AM
    #136
    tjbfoot89
    tjbfoot89 New Member
    tanner
    broken arrow, oklahoma
    06 sport taco
    2.5 lift, arb front bumper, leer camper. detroit trutrack locker,
    ok guys im a new member to the forum, but i have been visiting tacoma world since i have had my truck. im trying to do the abs kill switch and it is not working . the truck is an 06 double cab 4x4 sport with no LSD or TRAC but it does have a detroit true track locker in the rear . my harness has the light green wire. the abs light does not come on and i have cut the wire what do i need to check
  17. Dec 8, 2013 at 7:15 PM
    #137
    Broseph Stalin
    Justin
    Santa Barbara
    try running a 3 pronged switch with a ground, worked for me :/
  18. Dec 8, 2013 at 8:07 PM
    #138
    BradyT88
    Pretty sure you want this write up right here.
    http://www.tacomaworld.com/forum/2n...easy-caveman-can-do-abs-disable-mod-pics.html
  19. Dec 9, 2013 at 12:25 PM
    #139
    1strongone1
    1strongone1 Well-Known Member
    Jeff
    Iowa
    12 TRD Sport Supercharged
    Lifted, 33's, Supercharged, Volant Ram air CAI, Walbro fuel pump, 2.85 pulley, TRD exhaust, Bully Dog GT-T
    Thanks for posting up this tutorial. I just did it to my 2012 TRD Sport and it was easy and worked perfectly.
    Thanks Again.
  20. Dec 9, 2013 at 3:14 PM
    #140
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    I did yellow wire mod only and the abs and vsc lights are on. Normal?
