4LO won't engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by concrete jedi, Feb 13, 2008.
  1. Feb 13, 2008 at 3:48 PM
    concrete jedi
    concrete jedi [OP] Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    My 4 HI works fine but no matter how I try 4 LO won't go ? :(
  2. Feb 13, 2008 at 3:57 PM
    Dutch
    Dutch Well-Known Member
    Wilmington, NC
    07 4x4 Taco
    Jedi, Can u hear relay pull in when you push and turn to 4 low?
  3. Feb 13, 2008 at 4:23 PM
    news8000
    news8000 Active Member
    Southeast Manitoba, Canada
    06 Tacoma 4X4 Access Cab Stock
    ON STOCK UNIT: Rear Leaf TSB, Leer Cap w/ Windoors, Michelin LTX M/S on ION 133s, K&N Filter, Cruise, Python Command Start/Alarm, Toyota Class 5 Hitch, Metra IPod Adapter
    Make sure that 4HI has engaged (4X dash light ON) and then come to stop. Put the tranny in neutral and rotate switch to 4LO. It should engage then!
    Neil
  4. Feb 13, 2008 at 6:50 PM
    VIPER131
    VIPER131 Active Member
    Tucson, AZ
    4wd Sport Package
    Leer M180 Canopy w/ Browning Kit, Front & Rear Wet Okele Seat Covers, ScanGuage w/ Blendmount, Warn Trans4mer winch/brushguard, Westin Sliders, Toyota Bed Mat
    ^^^^^^^ EXACTLY.....
    I was in Flagstaff last week in a blizzard and couldn't get into 4WD Lo. In addition I had beeping sound going on. I knew that it was a Toyota and would work -- had I read the friggin' manual. I luckily was able to get out of the snow in 4WD Hi.
    Now being in sunny 75 degree Tucson -- I read the manual and then checked it out. Worked like a champ.
  5. Feb 13, 2008 at 7:46 PM
    rallyandbosox
    rallyandbosox Member
    Tempe, AZ
    07 DC 4x4 SR5 TRD Sport Speedway Blue Debaged
    3" Revtek Spacers, Toytec AALs, CB Radio, Grille Guard, Fog Light, BFG ATs
    Just make sure you are stopped and in neutral when you want to switch in. I've tried at 2-5mph and it won't work.
  6. Feb 14, 2008 at 12:54 PM
    concrete jedi
    Rochester N.Y
    Thanks guys, I think it's going to see the dealer, I tried all your suggestions, but to no avail, I hear the relay for 4HI, but as soon as I try 4LO all I get is the beeping sound, what about RPM's ? idle or reving a little ?
