4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. May 10, 2011 at 2:27 PM
    #261
    JimmyBuckets
    JimmyBuckets Well-Known Member
    Access Cab 6 speed V-6 sr-5
    Yeah I understand there are differences between TRAC and A-TRAC but for my purposes it seems this mod gets you 90% of the way there minus the e-locker. And from my understanding people with the Off Road package are generally using A-TRAC and not the locker most of the time. So for me this is like TRD Off Road package lite without having to pay for it.
  2. May 10, 2011 at 2:36 PM
    #262
    JimmyBuckets
    If I could have afforded it, I surely would have went with the OR package.
  3. May 10, 2011 at 3:01 PM
    #263
    iJDub
    iJDub Well-Known Member
    For offroading.
  4. May 10, 2011 at 3:29 PM
    #264
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    yes...05-08 OR. 09+ OR would be even better in their stock forms.
  5. May 10, 2011 at 6:42 PM
    #265
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    A spinning tire is wasted energy, and doesn't move the truck forward... as only when there is traction between the tire and the earth is there movement (on level or uphill ground).
    TRAC limits the amount of slip so some energy can transfer to the traction tire, that otherwise does nothing.
    A-TRAC and Locking differentials match tire rotation across the axle so one tire can't spin free, it will rotate with the other tire so the max. amount of driving power can be given to the tire(s) that actually move your truck.
    Levels of Tacoma traction:
    1) 2WD Open Differential and no traction control
    2) 2WD Limited Slip Diff. (incl. TRAC & AUTO LSD)
    3) 2WD Locking Diff.
    4) 4WD Open Differentials
    5) 4WD Limited Slip Rear Diff.
    6) 4WD Limited Slip Front & Rear Diff. (TRAC in H4 and Yellow Wire Mod non Off Roads in L4)
    7) 4WD Locking Rear Diff.
    8) 4WD A-TRAC
    9) 4WD Locking Front and Rear Diff. (not available from Toyota)
  6. May 10, 2011 at 10:45 PM
    #266
    iJDub
    David K, thanks for the good info. That said, would ATRAC or TRAC be safer than locking the front and rear for things such as driving in snow?
  7. May 10, 2011 at 10:55 PM
    #267
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  8. May 10, 2011 at 11:24 PM
    #268
    iJDub
    So, ideally, one would get a 09+ TRD OR and put an ARB front locker...
    That said, since I'm working on somewhat of a budget, I'm going to try to get a 05-08 TRD OR and add a front locker in the future.
  9. May 10, 2011 at 11:30 PM
    #269
    OZ-T
    Peter North
    British Columbia
    x2 If you are just worried about driving in snow , just get a 4x4 SR5 .
  10. May 11, 2011 at 8:12 AM
    #270
    David K
    You do not 'need' an after-market front locker if you have a '09+ Off Road 4WD... Unless, you are some serious rock crawler and want all the traction controls possible. An A-TRAC rig will go anywhere a front locker rig can go (with equal tires and body height).
    A-TRAC automatically matches rotation (or 'locks') both tires per axle on the front and rear (in L4) anytime one tire begins to spin.
    TRAC (in H4) limits spin on the front and rear... and if an Off Road TRD, has the hydraulic brake booster which improves the strength of the limited slip systems.
  11. Jul 24, 2011 at 5:05 AM
    #271
    phatdrew
    phatdrew Well-Known Member
    drew
    dover, de
    2" lift, 17" pro comp wheels, 285x70x17 micky t's, billet grill
    will be looking into this further when im awake and can comprehend if this will work on my 06 4x4 sr5 4banger.
    EDIT: finally after reading 4 pages, i found this is for 09+
  12. Jul 25, 2011 at 1:17 PM
    #272
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Sub'd for later..
  13. Aug 4, 2011 at 8:47 PM
    #273
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I have to say, I did this mod a few weeks ago and I love it. Not as quick to kick in as A-Trac but it works none the less. It has gotten my truck out of spots that I otherwise would have been doing the 2 wheel boogie!!!
  14. Aug 26, 2011 at 3:25 PM
    #274
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    anyone know if it works on 2011's?
  15. Aug 26, 2011 at 3:27 PM
    #275
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    try it! worst case you need to solder it back together
  16. Aug 26, 2011 at 3:28 PM
    #276
    650H1
    Michael
    VA
    no way to really try it until snow flies
  17. Aug 26, 2011 at 3:32 PM
    #277
    Yoytoda
    Roland
    completely stock
    well if it works the 4lo light will flash, no beep and it will engage in 4lo and continue to flash
  18. Aug 30, 2011 at 9:14 PM
    #278
    650H1
    Michael
    VA
    ok, so if for some fucked up reason it doesnt engage into four low it will still beep correct?
  19. Aug 30, 2011 at 10:15 PM
    #279
    Yoytoda
    Roland
    completely stock
    yes the beep will work if you dont go into 4lo. if the beep isnt going and the light is flashing and you move and its obvious your in 4lo, you did it right
  20. Sep 2, 2011 at 7:04 AM
    #280
    tbkfan
    tbkfan Active Member
    2011 Tacoma TRD Sport 4X4 Double Cab 5A
    This mod really has me interested. I am almost decided to go ahead and do it on my 2011 TRD but in the back of my mind I still wonder if there is a valid reason that Toyota did not make TRAC available in 4L. Were they just trying to add value to the OR package, or is there a real good reason that TRAC automatically turns off when switching to 4L in a truck not equipped with A-TRAC?
    Also, I have read about 50 of the 240 replies to the thread and wondered if someone can spare me the other 190 and fill me in on whether a consensus was reached about which yellow wire it is. One said the top-most, others said it was the lower one down. It sounded like PIN 25 was the definitive answer but there didn't seem to be any explanation of how to identify PIN 25.
