4Runner 4Link Build thread
Discussion in 'Long Travel Suspension' started by 4Running Daily, Oct 7, 2014.
  1. Oct 7, 2014 at 10:01 AM
    4Running Daily
    4Running Daily [OP] Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Alright so I'm going to attempt to link the back of my 4Runner next year and research has started. With the little amount of experience I have, it would definitely be nice to have someone review this to make sure I don' fuck shit up haha.
    I'll be running a 16" or 18" King Coilover
    So here's what I have so far:
    Coils
    Spring Rate 250/150
    150 is the primary or lower coil
    250 is the secondary coil
    Links
    Lower links should be 2.00” by .25 DOM
    Uppers/Wishbone 1.75” by .120 DOM
    Bed Cage 1.75” by .120 DOM
    Joints
    -Lower Link Axle Side: (RuffStuff.com)
    Right hand thread
    7/8” x 3/4” Rod End Set ID 1.5”
    P/N: 78X34SET15
    - Lower Link Frame Side:
    Ballistic Poly Bushing 2.63” Weldable Housing
    P/N: BUS-664-43
    -Upper Link Frame and Axle Side: (ruffstuff.com)
    2- 1.25" Rod End Set 1.5" Tube Id P/N: 125RESET
    Mounts
    -Frame mounts from Ballistic P/N: BRK-1082-13 and BRK-1082-11
    1-Lower Link Axle Mounts Ballistic P/N BRK-1007-1
    1-Upper Link Axle Mount Ballistic P/N *BRK-1011-1
    2- Coilover mounts Axle Side Ballistic P/N: RK-1037-2
    2- Shock Tabs Bed Cage Side Ballistic P/N: BRK-1018-13
    The Plans:
    [​IMG]Screen Shot 2014-10-07 at 9.54.59 AM by 4Running Daily, on Flickr
    [​IMG]Screen Shot 2014-10-06 at 1.07.16 PM by 4Running Daily, on Flickr
    4Runner currently:
    [​IMG]DSC_0004 by 4Running Daily, on Flickr
  2. Oct 7, 2014 at 1:33 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    First things first, move that gas tank out of the way with an F150 tank swap
    [​IMG]IMG_2789 by 4Running Daily, on Flickr
  3. Oct 7, 2014 at 1:55 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    :popcorn:
    Not really sure what you are going with here, you are already linked. Also, a coilver vs a spring and shock setup is very different, which are you going for, you mention coilver, but the drawing is coils and shocks?
    On the links, you should go bigger on the heims, I blew out my 7/8 on the lower links in just a few months, I am going to redo with the 1.25 on the lowers with the 2" DOM, and use the 7/8" on the uppers with the 1.75" DOM, all .25" wall. Here is what I would do
    Joints
    Right hand thread
    1.25" Rod End Set 1.5" Tube ID
    P/N: 125reset
    -Upper Link Frame Side: (ruffstuff.com)
    7/8" X 3/4" Rod End Set
    P/N: 78X34SET15
    Bushed DOM Sleeve for both sets of links
    There is a LOT that goes into a link design if you are moving the mounts to have longer links, which I assume is the plan if you are going coilovers. Don't want to dissuade you from going for this, but what are you trying to get out of the truck? Will you SAS it too? Are you doing the Rubicon, or dez mobbing? There is only so much you can do to the rear while still having IFS to improve the capability, my rear setup is about at that point, any more droop and the drive shaft starts hitting shit and getting some bad pinion angles.
  4. Oct 7, 2014 at 1:59 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    subd for the outcome :woot:
  5. Oct 7, 2014 at 2:04 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    The drawing was something I found online haha. It'll be a coil over setup.
    Good to know on the Links and Heims. I just started all this research last week and hope to be purchasing a welder in the coming months.
    Edit- Just saw your edit, desert mobbing for days.
  6. Oct 7, 2014 at 2:05 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
  7. Oct 7, 2014 at 2:11 PM
    JuansTaco
    Juan
    gilbert az
    that list!! haha you can definetly cut down the cost if you buy used. full LT and doing the work myself im in 6gs.
  8. Oct 7, 2014 at 2:29 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Yepp I'm excited. Planning on doing all the work myself.
  9. Oct 15, 2014 at 9:28 AM
    974rnr
    974rnr Active Member
    matt kelly
    steamboat colorado
    97 4runner long travel
    front long travel, camburg, dual shocks, pre runner front bumper, swing out rear tire,
    hey saw the thread couldn't help but post haha
    here is how she sits as of now plus the bags i made to deal with the noise/exhause smell and heat loss( i live in the rockies ) don't let these " pros" tell you it won't work my truck rips man videos coming this weekend!! and if your wondering how ifs does for crawling it does great but don't just take my word for it check out this guys vids o and remember more and more ifs rigs in the ultra4 class (https://www.youtube.com/watch?v=DwXURxTI6gE&index=5&list=LLeQEl2HNEncggcI_etsS9vg)
  10. Oct 15, 2014 at 2:52 PM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Where can we find some specs ok that white lt double cab? That thing is bad ass and what my truck dreams to be lol
  11. Oct 15, 2014 at 4:29 PM
    974rnr
    matt kelly
    steamboat colorado
    its in the new issue of toyota 4wd owner with full build specs
