4th Gen Oil Change Interval
Discussion in '4th Gen. Tacomas (2024+)' started by Sharpish, May 24, 2023.
How long should you wait to change the Oil?
  1. 3000 miles
    7 vote(s)
    13.0%
  2. 5000 miles
    24 vote(s)
    44.4%
  3. 8000 miles
    3 vote(s)
    5.6%
  4. 10000 miles
    20 vote(s)
    37.0%
  1. May 25, 2023 at 7:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Verified by an independent lab test?
    Or visual, sniff and taste testing?
    StayinStock and snickers like this.
  2. May 25, 2023 at 7:06 PM
    Tacospike
    Two Trucks
    I mean, maybe. I’ve gotten in a habit cause I’m always in the garage to check it every 2k. (Dipstick) I’ve checked it at 7k before a still seen an amber color. Granted I don’t tow or anything crazy.
    I still change it often and I think that one 7k was just a busy time for me but i usually change it around 6kish if maybe not before due to a free 30 mins I have to spare.
    but never gone to a 10k change. Just a preference for me and my trucks
  3. May 25, 2023 at 7:11 PM
    Master_Yota
    Master_Yota Well-Known Member
    Northeastern U.S.
    2017 Toyota Tacoma OR
    If you don’t mind I am not going to assume someone is unless they say so.
    My point was if someone just skims the manual for instance it says every 10K. Small print says 10K only under certain conditions. Someone might miss that.
    Also the dealership I bought my Gen3 from said 10K.
    I like 5-6K on average.
  4. May 25, 2023 at 7:14 PM
    Tacospike
    Two Trucks
    I AM
    not
  5. May 26, 2023 at 3:18 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    When's your delivery, 2026? You think a solid bushing will be available for the front diff right away?
    If the truck goes to an electric fan, aux cooling fan may not be necessary, though you'd want to wire in a kill switch for water crossings.
  6. May 26, 2023 at 6:09 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    :rolleyes:
  7. May 26, 2023 at 6:12 AM
    snickers
    Curious how some people need someone to follow. Carryon following your leader.
  8. May 26, 2023 at 7:34 AM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Good advice, thank you... Care to offer an actual helpful reply or say why you think I may be wrong?
  9. May 26, 2023 at 7:36 AM
    JDKred
    JD
    16 MT KDMax Tuned
    A master Toyota mechanic.
    Has no one seen that video?
  10. May 26, 2023 at 7:37 AM
    JDKred
    JD
    16 MT KDMax Tuned
  11. May 26, 2023 at 7:38 AM
    JDKred
    JD
    16 MT KDMax Tuned
    cbr600 likes this.
  12. May 26, 2023 at 7:42 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    if its still the same 8" front clamshell, no reason it shouldnt already have one ready. dont know if anyone has said what size the front diff is.
  13. May 26, 2023 at 8:11 AM
    snickers
    After my 4th Blackstone test at every 10K, I quit caring. 10K for me. You follow your leader.
  14. May 26, 2023 at 9:51 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The rear I heard is 9.5" to handle the hybrid's 465 lb-ft. The front diff is probably larger too. All Toyota has to do is to increase the CV axle's spline count for the existing ECGS bushing to be unusable.
    Soon we'll see how much of the front drivetrain is carried over or scaled down from the Tundra. The Tundra's may be overbuilt because the LC300 is available with a front locker.
  15. May 26, 2023 at 12:22 PM
    #35
    Master_Yota
    Northeastern U.S.
    If you read a little further in the thread you would see I like 5-6K. Been doing that 30 years. My comment was because someone said just read the manual which can be a bit misleading if you skim through. I will always change at 5-6K.I have had very good luck with my Toyotas over a long amount of time doing this so why change. Has nothing to do with someone on the internet.
  16. May 26, 2023 at 12:42 PM
    #36
    AspektZA
    AspektZA Member
    2017 BMW 340i
    3,000mi intervals are wasteful, 5,000mi similarly so.
    I'm stuck in the euro car world until the '24 Tacoma releases, and 10k mi is totally fine with the right oil.
    My B58 engined 340i doesn't burn a drop of oil, returns 28mpg+, and is driven spiritedly. Whether I'm using 0w-20 like the Supra does, or 5w-30 "diesel" oil; however, I use oil that meets various manufacturer approvals from BMW, M-B, etc.
    North America went to 10ppm low sulphur fuel in the last few years, which has lead to auto makers going to thinner low SAPS types of oil in the pursuit of efficiency, emissions reduction, and interval longevity.
    Car owners in Central Europe run 18,500mi / 2yr intervals, if anyone is curious.
    Lord Helmet, snickers and Jeff Lange like this.
  17. May 26, 2023 at 3:17 PM
    #37
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Even Toyota used to run 10k mile oil change intervals back in the 80's.
    I've got about 250k miles on a 2GR that's run 10k intervals on 0W-20. Never had a hiccup.
    Jeff
    snickers likes this.
  18. May 26, 2023 at 3:28 PM
    #38
    Jeff Lange
    Calgary, Canada
    Every vehicle released so far on the TNGA-F platform uses the same size 8.9" front differential, including the GRJ300 with the 4.0L 1GR V6, so I would be pretty surprised if the Tacoma doesn't also get the same front diff. It's possible of course, but... I'd probably be surprised.
    The new diff's ADD uses an electromagnetic coupling and there is no needle bearing. Even if the Tacoma did use a smaller version of this differential, I wouldn't expect there to be a needle bearing.
    Jeff
  19. May 26, 2023 at 4:18 PM
    #39
    Jeff Lange
    Calgary, Canada
    10,000 miles.
    Jeff
  20. May 26, 2023 at 4:22 PM
    #40
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I still don’t get the big deal
    I change mine at 5 k and 6 months no matter what . It’s cheap insurance. If it’s a waste oh well. We waste so much other stuff in this country . All my Toyotas have run flawless and I mean flawless . If it ain’t broke then I’m not changing
    JDKred, Johnny919 and pat5000 like this.
