4th Gen Oil Change Interval
Discussion in '4th Gen. Tacomas (2024+)' started by Sharpish, May 24, 2023.
How long should you wait to change the Oil?
  1. 3000 miles
    6 vote(s)
    11.3%
  2. 5000 miles
    24 vote(s)
    45.3%
  3. 8000 miles
    3 vote(s)
    5.7%
  4. 10000 miles
    20 vote(s)
    37.7%
  1. May 29, 2023 at 3:02 PM
    #61
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Except the Toyota's right?
  2. May 29, 2023 at 5:37 PM
    #62
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Dick, for sure....
    Just don't sit there as a keyboard warrior saying people are not providing evidence for their view point, when they literally provide evidence for their view.
    You can simply offer your suggestions and evidence, rather then be a dick and attack others.... Thanks for playing... God bless
  3. May 29, 2023 at 5:48 PM
    #63
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    It is certainly true that with the additive packs found in the current family of synthetic oils are protective and durable, the chemical tests after 10k miles will generally show the additives are still present and active. I also suspect that the new oils do preserve the metals from wear far better than the old dino oils. That said, fuel is still contaminating the oil over time, soot is still being created and suspended in the oil. I don't think the oil analysis can truly determine whether or not sludge is gradually building in the engine. If sludge eventually clogs some of the narrow lubrication channels, eventually the bearing surfaces will start to wear. For me, I want to run clean oil in my machine - I change it every 3 to 5k miles.
    Williston likes this.
  4. May 29, 2023 at 6:07 PM
    #64
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Youtuber's opinions are not evidence. They are just exactly that, opinions. You are not rational. I can play all day.
  5. May 29, 2023 at 6:11 PM
    #65
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I would like to see multiple engines torn down side by side. Same specs, same mileage, same oil, same filters, same usage, but different OCI.
    Tearing down one engine doesn’t provide a lot of context, unfortunately.
    I’ve also seen a lot of stuck piston rings on older engines that had 3,000 or 5,000 mile OCI’s during my time at Toyota.
    Jeff
    shakerhood and JDKred like this.
  6. May 29, 2023 at 6:28 PM
    #66
    snickers
    This is more like it. Data point. Just one, but still a data point. Not some youtuber, or that's the way I feel about it.
  7. May 29, 2023 at 6:31 PM
    #67
    JDKred
    JD
    16 MT KDMax Tuned
    You are right, a Toyota mechanic is just a you tube nobody... Wow:thumbsup:
  8. May 29, 2023 at 6:56 PM
    #68
    snickers
    Appeal to authority logic fallacy. Youtubers are just that. You know that they go to Youtube classes. To do what exactly? Toyota is wrong and a youtuber is right. Test engineers are wrong? Millions of miles of data points and I am to dispose of that and my own, because you really, really like some rando?
    Two posts above yours, a member posted a data point. That is more like it. All I am asking is for evidence. Why? Change my mind. This is what rational people do. Youtube guy doesn't hack it. Just because I always done it. Nope. Because I feels... yikes.
  9. May 30, 2023 at 6:05 AM
    #69
    terryhutchinson
    Terry
  10. May 30, 2023 at 6:53 AM
    #70
    JDKred
    JD
    16 MT KDMax Tuned
    Rocko likes this.
  11. May 30, 2023 at 7:38 AM
    #71
    AspektZA
    AspektZA Member
    2017 BMW 340i
    There's plenty of million mile Mercedes taxi cabs all over Europe, let alone delivery vans from Renault or VW or otherwise.
    Similarly, America has scores of 300,000mi F-150s or E-150 vans out there - but you don't hear about them since they're boring and don't have a Toyota hype magnet attached to the tailgate.
    Original point being, fuel quality is better as North America now matches Europe for 10ppm gasoline; which in turn means extended oil intervals aren't questionable as they were in the early 2000s.
  12. May 31, 2023 at 10:36 AM
    #72
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
