4WD actuator not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by 043RZ, Apr 22, 2014.
  1. Apr 22, 2014 at 9:43 PM
    043RZ
    043RZ [OP] Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Well guys.... when it rains it pours :facepalm:I was heading into work today and i usually engage 4WD for about 10 miles every month. While driving i engage 4WD and everything engaged smoothly. When i went to disengage it the 4WD light stayed on. I finally got it to go out by constantly shifting the lever in and out of 4WD. Now when i shift into 4WD the light wont come on at all and will not fully engage into 4WD??? So when i got home i jacked one of the front wheels up off the ground and shifted it in to 4WD. I hear a click under the dash on the passenger side, the transfer case engages, but the front ADD will not actuate and the 4WD light will not come on. Everything looks ok and everything is connected and in place. I even unplugged the 6 pin connector from the actuator and plugged it back in and still nothing. I also tried taking a wrench and tapping the actuator, still nothing.
    So my theory is that my actuator motor took a shit on me... cuss everything else seems to be working except the actuator. Where can i find one at a reasonable price and PLEASE dont tell me that i have to go to the dealership. Also what causes these to stop working? I only have 101000 miles on my truck.
    I should also add that i have the shift type 4WD lever (no button). And i only have one vacuum line which is only a breather tube going to the actuator. The rest is electronic.
  2. Apr 22, 2014 at 9:50 PM
    gearcruncher
    Canadain bumper technician
  3. Apr 22, 2014 at 10:01 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    The only thing is i have no actuator on my transfer case. If i still have this switch on my transfer case but no actuator, where would this switch or sensor be located. Also i have no vacuum lines on my front diff actuator, just a breather hose to the actuator and then the 6 pin electrical connector.
  4. Apr 22, 2014 at 10:16 PM
    arkansasman5
    arkansasman5 Well-Known Member
    James
    Fort Bragg, NC
    I had the same actuator go out on me. The breather tube that you are talking about was cut off some how and the actuator became full of water and mud. Kinda a small hole so I'm surprised that so much gathered in there.
    The only difference with when my actuator went out, the 4wd indicator light would blink because it was detecting an error. If you are not getting any light, you might have more wrong. Granted I'm not a mechanic so my word shouldn't hold much weight.
    If you wanna compare, I would switch my truck from 2hi to 4hi and I would get the blinking light. The transfer case engaged judging by the front drive shaft spinning then it would just keep trying. Sometimes I could trick it into engaging by turning my truck on and off.
    (Edit: Mine is a 2007 so that may be the reason for the light difference. I can tell you that the actuator is stupid easy to change out. Breath tube, plug, 4 bolts and some RTV. Just be ready to catch some diff fluid and make sure you check your diff fluid afterward.)
  5. Apr 22, 2014 at 10:52 PM
    arigoni24
    arigoni24 Well-Known Member
    Tyler
    Holloway Ohio
    2003 Tacoma Extracab SR5 4x4
    Grey wire mod, 3 inch level/lift kit from Truxx, 3 inch body lift, 285-70-17 (33's) on pro comp xtremes, custom rear tube bumper, cold air intake by Spectra, corner turn signal mod/ fog light where old turn signals were, hid headlights by vvme, smoke headlights and taillights by spyder, flow master muffler, tinted windows, red led turn signals and brake lights, brushguard and taillight guards yet to put on, MORE TO COME: relocate rear diff breather, black front bumper filler, shackles on front end, IF ANYONE HAS ANYMORE IDEAS PLEASE LET ME KNOW!
    I have one for sale if anyone needs one? Pm me
  6. Apr 27, 2014 at 6:00 AM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Just a thought hear... Is it possible to possibly disassemble the unit and clean the contacts? Or is the actuator a unit that once its done its done?
  7. Apr 27, 2014 at 7:02 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    There's a thread somewhere on here that talks about taking apart the actuator and soldering the contacts.
  8. Apr 27, 2014 at 8:05 AM
    gearcruncher
  9. May 9, 2014 at 5:45 AM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Ok.... So i purchased the actuator at a wopping $316.00 :eek:, not happy about that. I opened the actuator up the other day and everything look clean??? Theres no water or mud and theres still electrical grease in there. I did do some minor diagnostics the other day. When i shift the 4WD lever i hear a clicking noise behind the passenger side kick panel, which im assuming is the 4wd relay. So the relay is getting juice to tell the actuator to engage. To confirm this i got under the truck and with the lever still in 4WD i unplugged the 6 pin connector from the actuator and i could hear the relay click off, i reconnected it and i herd the relay click again.... So my theory is that the actuator is getting juice. I also did the same thing on the transfer case switch that screws to the upper passenger side of the case and when i unplugged and plugged it back in i could hear the relay click on and off.
    After reading my diagnosis would you agree that it is in fact the actuator not engaging???
    Taco on 20’s likes this.
  10. May 13, 2014 at 7:16 AM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Just an update.... i got the new actuator in yesterday and everything is back to normal. Still mind blowing that the old actuator went out like that, but im going to keep it and mess around with it to see if i can get it working again.
    Thanks for all the help!!!
  11. Jan 12, 2018 at 11:21 AM
    SPIN Offroad
    SPIN Offroad Well-Known Member
    SPIN
    Asheville NC
    Black 2014 DCSB TRD Off-Road "TAKEESHA"
    3" toytec suspension lift/1" Toytec body lift, In-channel AVS vent shades, tinted front windows, OEM color matched grill surround, plastidipped front badge & rear bumper, Debadged emblems + All LED interior+vanity& tag lights. Third tail light TRD black matte overlay, Aftermarket 6K HID projector headlights, Smittybilt D-shackle in receiver hitch slot, 17" FUEL Vapor wheels 285/70/17 Nitto Trail Grapplers, Weathertech floorliners w/TRD OFFROAD decals, 3" NFAB textured nerf bars, DEPO black tail lights. black on black perforated leather Clazzio seat covers with custom TRD headrests. TO BE CONTINUED...
    My 4wd went out on me the other day wheels were slipping when turned on didnt think about it and turned dial to 4H. Big No-No! Now its eff'd up and wont go in 4Hi or 4Lo and when its in 2Hi green light still blinks saying its in 4wd. Took it to dealership because they said was prob actuator over phone and was covered in power train warranty (I'm at 44K milage) but dropped off they said it was actuator and its electrical so its not under powertrain and im passed bumper to bumper 36K warranty! Said be $2,200+ to fix cause gotta drop transfer case and actuator is over $1,100 for part. Im gonna pick it up and drive in 2WD till find better(cheaper) place to fix-im not very handy with the steel if ya know what i mean
