4wd electrical failure when wet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kjones405, Nov 15, 2021.
  1. Nov 15, 2021 at 7:11 AM
    kjones405
    kjones405 [OP] Member
    2014 dclb sr5 4x4
    I was driving dirt road in 4H and came to a water crossering. Was deeper than i thought, came up to door panels. Mid way through my 4wd and 4L lights on dash started blinking. When i got to dry land again i sat for a minute and tried to switch to 2H and nothing happened. I ended up being stuck in 4H for about 3hrs until finally i heard a lot of clicking from ECU and the lights went out on dash and i was back in 2H. Anyone had this happen or know what might have messed up when wet that i should look to fix?
  2. Nov 15, 2021 at 7:16 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You likely have gotten some water ingress into the unit or knocked something loose on the connector. My 05 Tacoma had some similar behavior after a water crossing. I recommend looking around at your connections underneath after everything dries off, and then if you're still having trouble considering going down this rabbit hole. Did the repair on mine. Wasn't bad.
    https://www.tacomaworld.com/threads/how-to-trouble-shoot-4x4-actuator.263525/
    kjones405[OP] likes this.
  3. Nov 15, 2021 at 10:23 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You likely have a vent hose that is cracked or disconnected on the Transfer Case Actuator or ADD Actuator and allowed water inside, if your inclined they can be taken apart and cleaned.
    If nothing is obvious you can test the limit switch voltages at the 4wd ECU behind the glovebox when the 4wd is acting up and see which one(s) are out of range.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    kjones405[OP] and TnShooter like this.
  4. Nov 15, 2021 at 12:21 PM
    kjones405
    great link! thanks
  5. Nov 16, 2021 at 6:39 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    for future reference . . . water crossings are always deeper than they look!
  6. Nov 16, 2021 at 7:31 AM
    kjones405
    that was the case this time… but the actuator is meant to get submerged though right? now that i understand and see where that thing is does anyone add extra weather protection to theirs?
  7. Nov 16, 2021 at 7:35 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    My actuator failed ~4 yrs ago. Disassembled and discovered corrosion on the wiper tracks. Sanded down a bit, refilled with solder. No issues since.
  8. Nov 16, 2021 at 7:42 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They are fairly well sealed but the vent hoses tend to crack with age and allow dirt and moisture inside.
