4wd gone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garrettski, Oct 3, 2008.
  1. Oct 3, 2008 at 7:43 PM
    garrettski
    garrettski [OP] Well-Known Member
    Truckee CA
    07 Tacoma 2 ten in JL, 5100s, flowmaster 40.
    BFG allterrains, 2 ten inch JL w3,alpine v power amp,alpine cda-9886, bilstein 5100, flowmaster 40.
    Im a new to this site but find it very interesting...i have a 07 tacoma access cab v6...was driving up a dirt road yesterday so i flicked it into 4wd. i herd a lot of grinding from the front axle so i put it back into 2wd. Now im stuck in 2wd and my 4wd lite wont stop blinking......
    WHAT HAPPENED?
  2. Oct 3, 2008 at 7:47 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    how fast were you driving?
  3. Oct 3, 2008 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like something broke. Is it under waranty?
  4. Oct 3, 2008 at 7:48 PM
    garrettski
    Truckee CA
    i was going like 3 mph up a little hill
  5. Oct 3, 2008 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sounds like the front drive actuator broke on ya.
  6. Oct 3, 2008 at 7:49 PM
    garrettski
    Truckee CA
    Ya i think so...
  7. Oct 3, 2008 at 7:50 PM
    garrettski
    Truckee CA
    is that an easy fix or no?
  8. Oct 3, 2008 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Without seeing it in person, its hard to make an oline call on it. If its just the actuator, then no. Its easy. If you messed up some gears, or something, then its more involved
  9. Oct 3, 2008 at 8:09 PM
    Mace
    Mace Member
    New York
    08 SR5 Access Cab 4x4
    TRD Rims
    do you have acsess to a lift if you do its not bad
    it should be located bihind the front diff. Basically there is a box bolted kinda next to the front diff on the back side with a wire harness. Once you unbolt it(4 bolts i believe) there will be this C shaped armature that fits on a slider ring inside just take the actuator off and replace it and make sure you line the C shaped armature up right with the slider ring or your 4wd wont work. Also when replaceing the acuator put some RTV around the edge to seal it. And while your doing that you might want to drain your front diff and look for big chunks of metal just in case.
  10. Oct 3, 2008 at 8:12 PM
    garrettski
    Truckee CA
    thanks mace!
  11. Oct 4, 2008 at 4:48 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    It's a $330 part. I had mine replaced under warranty, same thing happened @ 18k.
  12. Oct 5, 2008 at 1:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    WARRANTEE work!!
  13. Oct 6, 2008 at 8:14 PM
    Wood
    Wood Well-Known Member
    Sorry about your luck, sucks. That's why I NEVER shift into 4wd with any kind of load on the drivetrain.
  14. Oct 11, 2008 at 8:21 AM
    garrettski
    Truckee CA
    Just an update....toyota has had my truck since wednesday. tryed a 4wd acctuater and that wasnt it so know theyve got a fron diff acctuater on order.
  15. Sep 14, 2010 at 12:52 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    It is really easy to tell if it the actuator for the t-case or the front diff. If the front driveshaft spins when you engage the 4h feature then your t-case 4x4 actuator is good if you still have no front drive when the front shaft is spinning then its the front diff actuator. I know this as I spent the entire last weekend doing a front diff carrier replacement and the actuator failed while we had it out (what a bummer). We did alot of work only to find out we had to pull the actuator, crazy!! Good luck though, I am just waiting until my back heals from all the work last week before I fix the new break! JOE>
  16. Sep 14, 2010 at 1:58 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
