4WD issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lvasquez93, Nov 10, 2018.
  1. Nov 10, 2018 at 5:36 PM
    lvasquez93
    lvasquez93 [OP] Well-Known Member
    2017 Tacoma TRD Off Road
    My 4 wheel drive light flashes randomly when I drive now. When I start my truck on 2wd I can hear the clicking 4x4 trying to engage. The times I try to engage my 4H it doesn't engage. I have tried to get it set on all the gears. The mechanics at toyota are trying to say that I have to be moving in drive or reverse for it to engage. anyone else have this problem.
  2. Nov 10, 2018 at 5:39 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    It helps to be moving,slowly. Manual stated you can shift into 4HI up to 60mph, but personally I wound say not more than 10mph
    You need to drive a few miles in each one at least once a month to keep everything oiled and moving.
    Nunya Bizness likes this.
  3. Nov 10, 2018 at 5:40 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Have you been driving your truck in 4HI every month for 10 miles?
  4. Nov 10, 2018 at 5:41 PM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    You dont HAVE to be moving. Atleast not in my experience, although it is easier for the truck to do so while moving. The manual doesn’t state you have to be moving
    tonered, Kilokato and shakerhood like this.
  5. Nov 10, 2018 at 5:49 PM
    lvasquez93
    thanks. No I havent driven it in 4H for like 2 months but I've been driving in 4LO for the past 2 months every time I go to the desert
  6. Nov 10, 2018 at 5:50 PM
    lvasquez93
    no I haven't used it since I've started going to the desert more often. been using more 4LO
  7. Nov 10, 2018 at 5:51 PM
    lvasquez93
    I've always had no problem when I had it in neutral to engage. all of a sudden it stopped engaging about 2 weeks ago
  8. Nov 10, 2018 at 5:52 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I switch into 4h going 40-45 mph a all the time on straight stretches of road to keep it oiled never had a problem.
  9. Nov 10, 2018 at 6:00 PM
    phsycle
    phsycle Well-Known Member
    CA
    A truck that new, shouldn’t be an issue even if haven’t been using it every month. Time for the dealer, I think.
  10. Nov 10, 2018 at 6:03 PM
    su.b.rat
    su.b.rat broken truck
    totally safe to engage at speed as per the manual. the ECU won't let you beyond 60 (or 58 or something?), but up to that speed just be gentle on the throttle and it's smooth as silk.
    tonered, DavesTaco68 and REDNECKTEX like this.
  11. Nov 11, 2018 at 7:00 AM
    lvasquez93
    I was telling them so is it normal when I start my truck and the 4wd tries to engage when it's in 2wd. they're saying that nothing is happened since I've taken it to the dealership.
  12. Nov 11, 2018 at 7:12 AM
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    I'm thinking you 4 wheel drive control switch is bad, even though you have the selector in 2wd, a part of the switch might be trying to switch it. just my opinion, try to disconnect it or pull the fuse?
  13. Nov 11, 2018 at 7:26 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    No, it is not normal for your 4WD to attempt to engage during startup if your selector is set to 2H. If they are telling you different at the dealership, take it to another dealership. If you are stuck with no other nearby dealerships, call Toyota Corporate and start a case before you return to the dealership. They will advocate somewhat on your behalf. Further, with such a bad start of a relationship with this dealer, get everything in writing and keep all service papers/ documentation - you never know when you will have to refer or use it to defend your case or to insure your warranty coverage.
  14. Nov 11, 2018 at 7:49 AM
    REDNECKTEX
    REDNECKTEX Well-Known Member
    TX
    2017 Inferno TRD Sport
    Kevlar seat covers Fox Shocks.
    4 high you can be moving.... 4 low MUST stopped and in neutral.
    Kilokato likes this.
  15. Nov 11, 2018 at 11:18 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    As NoOne said. Truck will check the feedback position sensors on startup and at each detected mode change request (2hi switch to 4hi, etc). If position sensor on the actuators show the actuator isnt in desired position on startup or at mode change request, you will hear the relays click, commanding actuator movement.
    If you were in 2hi when you shut down, and selector was in 2hi on startup, and you hear the actuator relays clicking, there is almost certainly a problem in the actuator or the actuator wiring. (Could be add or transfer case, cant tell.) Chances are (in my opinion) it's the add or transfer case position sensors
    Generally shouldn't be too hard to diagnose with techstream, or some ohmmeter work....
  16. Nov 11, 2018 at 1:50 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Pretty sure you can go up to 3 MPH and go into 4 lo
    Flash1034 likes this.
  17. Nov 11, 2018 at 2:36 PM
    phsycle
    CA
    I’ve always come to a complete stop, neutral, shift to 4lo.
    In my old Taco, shifting to 4lo while moving = gear crunch.
    Kilokato and johntoyota like this.
  18. Nov 11, 2018 at 2:45 PM
    styk
    styk Well-Known Member
    Greg
    New Brunswick
    Inferno 17 TRD Sport DCLB 4x4
    in-channel vent visors
    On;y thing I have noticed, if your stopped with your foot still on the brake in "D", it usually won't go into 4x4. Moving slightly seems to be no issue but not always an option. 4Lo is another mater, that can be quite finicky at times and at others times, no problem.
  19. Nov 11, 2018 at 4:04 PM
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I had this issue and it was the front diff 4wd actuator. It has a metal contact that isnt soldered and in time with offroading it can get less continuity resulting in 4wd failures, you still hear the click from the transfer case but you get failures. Toyota would not work on my truck because of aftermarket lockers. Luckily It was an easy fix, just soldered the connector instead of the regular contact that toyota thought would work.
    DC92T, tonered and El Latigo like this.
  20. Nov 11, 2018 at 4:09 PM
    ajsabra
    Sin city
