4wd Lo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eximius2286, Feb 11, 2019.
  1. Feb 11, 2019 at 11:41 AM
    Eximius2286
    Eximius2286 [OP] Beauvais - Attleboro
    Josh
    Attleboro
    2016 Tacoma SR5 V6
    Can someone confirm the procedure to engage 4wd Lo? Shift to neutral then turn the knob to Lo to engage... And shift back into neutral to disengage?
  2. Feb 11, 2019 at 11:44 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
  3. Feb 11, 2019 at 12:32 PM
    Eximius2286
    Josh
    Attleboro
    2016 Tacoma SR5 V6
  4. Feb 11, 2019 at 12:35 PM
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    If you are in pinch it’s all listed on your visor too:)
    Kheiron, Joe23 and friendlywithbears like this.
  5. Feb 11, 2019 at 1:59 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I found that when my truck was new (or maybe I was just new to the truck) 4LO was a little difficult to engage. Part of the problem might just be doing it on pavement (in general you should avoid, but driving in a straight line to test shouldn't be an issue). Anyhow, if 4LO not engaging after you've done it properly (from neutral), try cocking the wheel to the side a bit and driving forward slowly and it will usually catch.
    It's pretty clear when it engages and doesn't (flashing vs not).
    I didn't watch the video, but maybe it says all this.
  6. Feb 11, 2019 at 2:04 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Does anyone know how fast you can drive in 4lo? I checked the owners manual and nothing. Just curious more than anything...
  7. Feb 11, 2019 at 2:04 PM
    Taco_Craig
    Craig
    Watch your RPMs. They'll tell you. Pretty slow, though. Parking lot slow.
  8. Feb 11, 2019 at 2:11 PM
    BSFord
    2018 TRD Sport 4x4
    Well it'll still shift through the gears no?
  9. Feb 11, 2019 at 2:26 PM
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    Pretty sure the owners manual does show the max speed in 2wd, 4 hi, and 4 low. Page 208. 107mph in hi(obviously governed), 58mph in low.
    tonered, BSFord[QUOTED] and Paul631 like this.
  10. Feb 11, 2019 at 2:34 PM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    Really? I am going to have a look once I get off work.
  11. Feb 11, 2019 at 2:40 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I think 30-40 is about all you want to do or you'll be at 5,000 rpm
    BSFord[QUOTED] likes this.
  12. Feb 11, 2019 at 2:43 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    *107mph with the dif lock engaged, 121mph without.
  13. Feb 11, 2019 at 2:59 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I find it better if I shift into 4hi while on the move. Once in 4hi stop, place truck in neutral, or depress clutch all the way to floor, then shift into 4lo. You have about 50/50 odds that the gears will line up and it will effortlessly shift into 4lo. It is not unusual for the truck to have to roll slightly to let the gears in the transfer case to align properly to engage. Usually just letting off the brake pedal will allow the truck to move enough. If not you may have to put it back in gear and move 1-2'. That is also why it is better to shift into 4hi while moving. It is possible to go straight from 2hi to 4lo, but you are asking the transfer case to do 2 things at once. I just have fewer issues doing it in 2 steps.
    Getting back to 2hi is the same process in reverse. Stop, shift to neutral then shift the transfer case to 4hi. It is very common to have issues getting out of 4lo with any 4X4. If it doesn't want to make the shift putting it back in gear and driving in reverse 10-15' then forward 10-15' will help. But I've had to do that little dance several times before it would shift. Once in 4hi simply start driving then shift to 2hi on the move. Once again doing it in 2 steps isn't necessarily required. I just find it works better.
    If you're driving in double digits speeds you don't need to be in lo range. Around 5 mph is as fast as you need to be going. The point of low range is to be able to drive slowly over rugged terrain without using the brakes.
    royceferris and Eximius2286[OP] like this.
  14. Feb 11, 2019 at 3:03 PM
    Eximius2286
    Josh
    Attleboro
    2016 Tacoma SR5 V6
    The reason I asked is because I was testing the 4wd Lo and got some grinding, it was an error on my end I assumed it shifted out as soon as I shifted the knob to hi. 4wd hi gave me some difficulties turning the wheel when moving though...
  15. Feb 11, 2019 at 3:05 PM
    Eximius2286
    Josh
    Attleboro
    2016 Tacoma SR5 V6
    That's what I was looking for.
  16. Feb 11, 2019 at 3:14 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Ford F350, Lexus RX450h, FZJ80, Jeep YJ
    Interesting comments. I've always had less issue going in and out of 4L than I have going in and out of 4H
    abhamber likes this.
  17. Feb 11, 2019 at 3:24 PM
    royceferris
    royceferris Well-Known Member
    Roy
    Nashville TN
    2019 OR DCSB 6MT
    If you can feel it in the steering wheel or feel "skipping" when turning you probably should be in two wheel drive. Anyone hooked up a steering wheel button for 4 Hi yet? haha. Personally, I'd prefer having a proper stick for 4wd instead of the button. It feels like another climate control knob.
    helix66 likes this.
  18. Feb 11, 2019 at 3:32 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Glad I read this. I haven’t had the opportunity to use 4LO, only 4HI. Good stuff guys.
  19. Feb 11, 2019 at 3:52 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI full AL skids, KDmaxPro tune, Demello stealth bumper, Warn evo10s, BD s8 & squadrons
    Funny, because in the ram 1500 work truck I have it's a similar situation, and at times I've grabbed the 4x4 knob by mistake.....thankfully not moving!
    royceferris[QUOTED] likes this.
  20. Feb 11, 2019 at 3:59 PM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I've put mine in 4 HI once when I thought I was turning the AC fan on. Glad I wasn't going too fast. Damn button should be somewhere else, or a lever by the emergency brake like my old Jeep had.
