4wd lo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JasonT5001, May 28, 2023.
  1. May 29, 2023 at 10:47 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Assuming you successfully shift in/out of 4Lo ... and assuming you have Crawl Mode (not all do) I will answer a question you will have about Crawl Mode ... yes it DOES sound and feel like 10 lbs of random nuts and bolts were dumped into the transmission, but you still move in Crawl Mode regardless.
  2. May 29, 2023 at 10:53 AM
    JasonT5001
    JasonT5001 [OP] New Member
    2022 Tacoma TRD Sport 4WD
    Thanks to all for the great advice. I ran the drill on the garage floor and it transitioned like it was supposed to. I’ll give it another try on the boat ramp soon. It’s possible I rushed it before. Guess I’ll have to check the visor.
  3. May 29, 2023 at 10:55 AM
    JasonT5001
    Sport model, no crawl mode. Not a big off-roader so didn’t get that feature. Thx
  4. May 29, 2023 at 10:57 AM
    NewWheeler
    NewWheeler Well-Known Member
    Gus
    Fort Worth, TX
    2017 Quicksand DCSB TRDOR 6MT
    It’s good insurance on the boat ramp, but remember two things 1. Get it in the right configuration before you need it and 2. Only drive / back it in a straight line if you have it in 4Hi or 4Lo on dry pavement.
    JasonT5001[OP] and Chew like this.
  5. May 29, 2023 at 11:03 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    exactly! Don't wait until there is a load on the drivetrain, you need it unloaded. A load can come from downshifting, speeding up, and difference in tire speeds through turning or slipping/spinning.
    The only thing the old school levers did, was allow folks to force the transfer case while under load,,, still not a good idea regardless of shift method. Many people are clueless and folks wonder why they automate things.
    Speedfreak likes this.
  6. May 29, 2023 at 11:04 AM
    RichochetRabbit
    Anyhoo ...
    Here are two interesting articles explaining 4WD behaviors. Page 3, post 59, in the snow thread shows how 4WD tries to push all wheels at the same speed. Also some advice ... run 4 WD at least 10 miles a month just to keep the gears lubricated. That time can be in a straight line on a wet road after a rain ... as long as there isa little bit of slipping to not stress the 4WD gearing. Happy wheeling' !
    https://www.tacomaworld.com/threads/4x4-best-practices-for-snow-covered-roads.753009/
    https://www.tacomaworld.com/threads/3rd-gen-traction-control-modes-explained.530695/
    JasonT5001[OP] likes this.
  7. May 29, 2023 at 12:08 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Part out ? :anonymous:
  8. May 29, 2023 at 12:44 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    You should invest in a Harrop rear E-locker if you feel like you need extra traction. However, the ALSD for the non OR’s works very well. I wouldn’t be surprised if you don’t ever have any issues. A front locker for the ramp would be more ideal, but more expensive.
  9. May 29, 2023 at 3:23 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why does anyone need 4lo? 4hi can take you anywhere
  10. May 29, 2023 at 11:58 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Jason on the boat ramp (been there) often if you engage 4Hi or 4Lo to climb out on a slippery ramp the traction control will fire off also making lots of noise.
    Push that dash button to turn it off and try driving up and feel/hear the difference.
