4WD not working, 1st gen manual hubs
Discussion in '1st Gen. Tacomas (1995-2004)' started by MountainGoat, Mar 4, 2014.
  1. Mar 4, 2014 at 8:33 AM
    MountainGoat
    MountainGoat [OP] Member
    Corbin
    Western North Carolina
    97 Taco 2.7L, single cab, Manual, 3" lift
    3 inch suspension lift
    Hello Tacoma World! This is my first post, but I've been lurking for a while. If this post is in the wrong section please redirect me.
    Last month the 4WD stopped working, i.e. I lock hubs and engage transfer case but no power to front wheels.
    I don't think it's the transfer case because if I crawl along in 4lo and hang out the door to look under the truck (haha), the front drive shaft is still spinning. So is it the hubs? the axle? How do I diagnose it?
  2. Mar 4, 2014 at 8:58 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'm assuming the DS does not spin, while in 2wd.
    Hopefully, its just a bad hub. If either hub does not engage, then due to the open differential, 4WD won't work at all (no pulling with front tires)
    If it were my truck, I'd diagnose a bad hub this way:
    - park on level ground, parking brake engaged
    - leave tranny in park (if AT), or in 1st gear (if manual)
    - block the rear wheels
    - put the TC in 4wd-hi
    - jack up one front corner
    - turn the lifted wheel (hub in free wheel)
    - attempt to spin the wheel (wheel should spin freely)
    - put hub into 'LOCK' position
    - attempt to spin the wheel (wheel should NOT spin freely, if it does, then the hub is not engaging)
    Repeat with other side.
  3. Mar 4, 2014 at 9:19 AM
    BamaToy1997
    Bill
    Navarre, FL
    Very good recommendations for testing there! ^^^^^^
    A good simple test also would also be to lift the front wheels off the ground, securing the truck with jack stands, and engage both manual hubs. Have a friend hold the front drive shaft in place, and turn either front wheels. If the hubs are in good shape then the opposite wheel should turn in the opposite direction, and some resistance should be felt by the person holding the drive shaft. If the wheel spins freely, and there is NO resistance on the drive shaft, and no turning of the opposing wheel, then you have a probable hub problem. If you DO feel resistance in the drive shaft, but the opposing wheel does not spin, then THAT hub may be suspect.
  4. Mar 4, 2014 at 9:26 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    My 89 had a vacuum solenoid on the passenger side fender that actuated the front diff. I believe these are the same. Mine crapped out and I had no 4wd. I bypassed it and had 4wd again. I would bet that to be your problem.
    Why there are locking hubs, a manual xfer case and a vacuum actuator is beyond me.
  5. Mar 4, 2014 at 12:51 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Maybe yours was converted to manual and all the vacuums was left intact. That's what I did to my 93 4runner. Converted when vacuum actuator failed. Otherwise I don't think the manual hubs should also have an actuator, but I could be wrong.
    The manual hubs on OP's truck could also be gunked up with grease and it's not engaging.
  6. Mar 4, 2014 at 12:59 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Thats very possible. It had warn hubs on it when I got it. But even with the hubs locked, when that actuator crapped out, I didnt have 4wd.
  7. Mar 4, 2014 at 1:02 PM
    BamaToy1997
    Bill
    Navarre, FL
    The 1st gen Tacoma trucks were all direct drive with no vacuum actuators for the front axle. Once the shifter was engaged on the TC, and the hubs were locked in, you were golden. No need for vacuum.
  8. Mar 4, 2014 at 1:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well...for manual hubs...
    ADD has vacuum operated actuators for the front diff drive tube on the passenger side unless it is a push button 4wd system then its an electronic tube.
  9. Mar 4, 2014 at 1:28 PM
    MountainGoat
    Corbin
    Thanks for all the replies! I used tan4x4's method and discovered that both the front hubs are not engaging. This is probably my fault; a few months ago I had the right hub of because... well, it's a long story that involves offroading, a lower BJ failure and a wheel rolling beside my truck haha. After a new LBJ, tie rod end, brake line, and alignment, the truck is back on the road. Anyways, while I had the right hub off I found that it was super gunky. So, I removed the left hub intending to clean it because I thought it would be dirty like the right one. But it was extremely clean.
    I must have resembled them incorrectly. Is there a thread about the right way to instal hubs? Do I need to buy new ones? Thanks again!
  10. Mar 4, 2014 at 1:33 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    No need to buy new ones.
    http://www.4x4wire.com/toyota/maintenance/front_end/hub_rebuild/
  11. Mar 4, 2014 at 1:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Mar 4, 2014 at 2:32 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Lol gotta love the timing. :)
    Yeah. I've been in and out of the aisin hubs numerous times.
    I could probably rebuild one with my eyes close.
    They're simple creatures, you just have to make sure they're put together properly.
  13. Mar 4, 2014 at 3:48 PM
    tan4x4
    Rick
    Folsom, CA
    Easier said, than done. Helps to have a properly working one in your hand so you can see how it is supposed to go together. It took me some trial and error to figure it out (many years ago).
    This video might help even though the hub is from an old solid axle:
    http://www.youtube.com/watch?v=-jd4KjXI5VU
  14. Mar 5, 2014 at 8:54 AM
    MountainGoat
    Corbin
    Update: after taking the ASIN's off and looking at them/the way they work, I'm almost positive I put them back on correctly. I'm also positive I found the real problem haha...
    Would the right terminology here be, "the axle is disconnected from the hub."?
    This is surely my fault b/c this is the side that had the LBJ failure, and therefore the semi-rebuild.
    What did I do wrong? How do I fix it?
    Thanks again!
  15. Mar 5, 2014 at 9:12 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    There should be a snap ring that goes over the axle that holds it into the hub. There should also be an 8mm bolt that threads into the very outside end of the CV, with a large washer, that is an extra fail-safe for that snap ring.
    Head to the dealer and pick up those parts.
  16. Mar 5, 2014 at 3:25 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    One day I locked hubs in and 4 wheel drive didn't work. I pulled the outside off to look and the bolt and washer were rolling around inside. Had to buy new bolt and washer. Fixed!! One of those good days.
  17. Mar 31, 2014 at 10:08 AM
    MountainGoat
    Corbin
    Ok, I've run into a small problem that I can't find the solution to. I can't seem to get the axle end into the hub far enough, by a couple millimeters. I can fit the snap ring into the groove, but there's not enough room for the splined washer to fit behind it. I've read every step by step guide to cv axle/bearing replacement, but this issue is never mentioned in them.
    Thanks for any help!
  18. Mar 31, 2014 at 10:54 AM
    tan4x4
    Rick
    Folsom, CA
    Have the CV axles been replaced? If so, its possible that the wrong axles may have been used. The ABS axle assemblies are slightly different from the non-ABS axles.
  19. Mar 31, 2014 at 12:37 PM
    MountainGoat
    Corbin
    No, it's the original cv axle.
    I tried making it work with the LBJ on and off. I'm still just a hair short of having enough room for the washer and the snap ring.
