4WD problems 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by d9lowe, Dec 8, 2019.
  1. Dec 8, 2019 at 8:25 AM
    d9lowe
    d9lowe [OP] Active Member
    '13 DC V6 4x4 TRD-OR
    Hey guys,
    Im having an issue with my 2013 TRD OR with 25k miles. Bone stock truck, never has given me any issues.
    A few months ago I put the truck in 4H right before I pulled my boat out of the lake. It engaged fine and the truck ran back to the boat storage just fine. As I was backing the truck up at the storage unit (still in 4WD) I could hear some squiling and screeching coming from the rear end. Also some resistance feeling as I hit the gas. I disengaged the 4wd, and the problem went away.
    Last night, a few months later, I was thinking about the problem and was running up to the store and decided to run my truck in 4wd just to get it moving and test it out. It engaged fine and as I was backing out of my driveway and started to turn, the truck completely bound up. I would give it gas but it would just act like it was trying to go. If I gave it more gas, it would start to move, but with a screeching sound. Almost like a wheel was slipping. I took it out of 4wd and it started to work just fine.
    On my way back, I was at a stop sign, I engaged the 4wd to test going forwrd, and it would run but with a lot of resistance. Almost like the feeling of trying to drive with E-bake partially on, it goes but just feels rough. Disengaged and got back to the house with the green 4x4 light flashing. When I went to pull into the driveway, as soon as I turned, the truck bound up again.
    I went in and out of park, N, reverse, turn off truck, 4WD switch on and off. Was able to get the truck into the garage, but now the green light flashes. It will go solid if I put it into 4WD, but if I go back to 2WD, it just flashes.
    I have read about the actuator that goes bad and need to be removed and tested, but what is causing the binding?
    Thanks for any response!!
  2. Dec 8, 2019 at 8:28 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Do not use 4wd on pavement! That is your problem. Try it in dirt or gravel and see if it works properly.
  3. Dec 8, 2019 at 8:34 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    This ^^^^^^
    dirt......gravel.....snow.......
    remember.......use it or lose it.......
    Keep 'er lubed & moving.....Warn's old saying......'mile a month'
  4. Dec 8, 2019 at 8:40 AM
    d9lowe
    im sorry, but my truck should be able to back up at 1mph in my driveway in 4WD without problems
    Sugar Silva likes this.
  5. Dec 8, 2019 at 8:43 AM
    nasaengr
    Red15 DC OR
    It should as long as you are going in a straight line. Your own statement says: "as soon as I turned, the truck bound up again"
    Kolter45 and outlawtacoma like this.
  6. Dec 8, 2019 at 8:43 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    It's 4wd, not AWD, google it.
    12TRDTacoma and YamaDirtrider like this.
  7. Dec 8, 2019 at 8:45 AM
    Armed in Utah
    2003 Lexus LX 470
    very true.....as far as the dash lights flashing.......
    Take it in the dirt and switch back & forth.....they can be a real PIA sometimes
    Shut motor off.....in & out of 4x4....hi & low...etc.....use it or...................:thumbsup:
  8. Dec 8, 2019 at 8:46 AM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Deffently sounds like the transfer case is the problem. I have never had a problem with a Toyota t-case but I had a similar issue with a Jeep. It was particularly engaging in 4hi and 4low causing it to lock up, as soon as I would put it into 4hi it was fine. Also had a t-case go bad in a Raptor locked up and then grenaded, put it into 2hi and was able to drive it over 300 miles home.
  9. Dec 8, 2019 at 8:46 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Your actuator most likely has moisture in it, you will need to remove it and shift fork manually to get back into 2WD. It's a common issue with Toyota.
    As for a strong binding while being in 4wd on dry pavement... It is putting a lot of stress on a components. You need to familiarize yourself how 4WD system works.
  10. Dec 8, 2019 at 8:48 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    But they do not. In 4wd the wheels are pretty much locked together. Turning on dry pavement (or any dry surface)forces one wheel to turn more revolutions than the other causing the mechanical system to bind. Not good for 4wd. That's why it's only to be used on slippery surfaces.
  11. Dec 8, 2019 at 8:53 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Is this your opinion, or something that you learned from toyota? I think Toyota might have a different thought on this matter.
    Rick's 2012 likes this.
  12. Dec 8, 2019 at 8:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    4x4 is allowable for use on the pavement, as long as you stay mostly straight and don't turn the wheels very much.
    The way our 4x4 system works it is designed to see slippage in order to work properly while turning. Loose stuff like rocks, gravel, dirt, sand, mud. If you use it while there is no slippage present while turning the way you have been you will bind up and can cause some ugly damage to the 4x4 system or potentially your drive axles.
    Chalk it up to a rookie mistake. Don't do that again unless you are going mostly straight on pavement.
    The system is part time 4x4 not AWD as previously mentioned. There is a prime difference between the two.
    ace96 likes this.
  13. Dec 8, 2019 at 8:56 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    you cannot turn in 4wd in dry conditions. The truck is going to bind...ALL 4wds will bind
    Muddinfun likes this.
  14. Dec 8, 2019 at 8:59 AM
    d9lowe
    ok, a lot of what you guys are saying makes scene. But what if I need to use 4WD to pull my boat up a steep ramp and its a paved ramp?
  15. Dec 8, 2019 at 9:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Keep it mostly straight. No extreme turning angles as that will cause the binding.
    Rick's 2012 and Muddinfun like this.
  16. Dec 8, 2019 at 9:03 AM
    Norilsk
    Eugene
  17. Dec 8, 2019 at 11:09 AM
    d9lowe
    Thanks guys! it amazes me that the manual says the truck should be under 62 MPH when shifting into 4H. Who would ever be on a dirt road going that fast?
  18. Dec 8, 2019 at 11:10 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You can use 4H or 4L in a straight line on a boat ramp. You shouldn’t turn the wheels much in those conditions because the ground doesn’t allow slipping, hence the bind.
    You can use 4H at any speed you want if the ground allows slipping and the truck can sustain the terrain at speed.
    I’d do some reading, not for the experience but you seem really unfamiliar with 4x4.
    12TRDTacoma and outlawtacoma like this.
  19. Dec 8, 2019 at 12:37 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    check out these links....
  20. Dec 8, 2019 at 12:48 PM
    Tacoma Mike
    Southern Maine
