4wd vs. 2WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PhantomVirus, Aug 13, 2012.
  1. Aug 13, 2012 at 7:48 PM
    PhantomVirus
    PhantomVirus [OP] Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    So I have been reading the info on the differences between 2 and 4Wd (all wheel vs on demand) http://www.4x4abc.com/4WD101/def_turnfull.html
    According to the Owners Manual Toyota recommends that you engage the 4wd HIGH once a month. Assuming that you don't offroad the vehicle and it's not snowing - what are your options?
    Would appreciate any thoughts on what you are doing to run your Taco's 4x4 monthly.
    Thx
    R
  2. Aug 13, 2012 at 7:50 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    find a field once a month & drop it in 4wd for a bit. Or just go wheeling as often as you can... Done. ;)
  3. Aug 13, 2012 at 7:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    as long as you dont turn on pavement, you'll be fine
  4. Aug 13, 2012 at 8:08 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i know turning in 4x4 on pavement is bad news and yada yada yada, but if this is such a serious problem, what good are these trucks in rocks? just curious, if my truck wont scrub a tire before breaking hardware, i'll freakin sell it.
    op, toyota recomends, 10 miles per month as you stated. these trucks, to me are designed mostly for street use. i dont think they planned on us destroying somebody's farm-land to keep up with the manual
  5. Aug 13, 2012 at 8:20 PM
    Fury
    Fury Well-Known Member
    Hi all.
    I drive to work once a month in H4. You can turn on dry pavement - your tires will scrub. I don't put much power down while turning and do long shallow arcs.
    The problem with turning on dry pavement only occurs when you are going very slow and try to turn sharp - as in more than 1/2 turn on the steering wheel - or put the hammer down while turning at speed.
    I tested my truck to make sure the 4WD worked when it was new in a parking lot. When in H4 you can feel the tension in the steering wheel when moving slow and turning. This told me I was actually in 4WD long before there was any actual tire scrubbing or anywhere near enough binding in the drive line to hurt anything. Again, I was using very little throttle and only turned the steering wheel until I could feel a tension that wasn't there in 2H (less than 1/2 turn).
    Cheers
    Ray.
  6. Aug 13, 2012 at 8:33 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  7. Aug 13, 2012 at 8:36 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This will end well
  8. Aug 14, 2012 at 12:47 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Yay another thread on this! :mad:
  9. Aug 14, 2012 at 12:55 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    Simple solution Go Four Wheelin Once A Month!!!
  10. Aug 25, 2014 at 11:48 AM
    Ben550
    Ben550 Well-Known Member
    2012 TRD OFF ROAD
    I've been looking a long time and can't find a straight 10 mile road. I almost found one in kansas but it had a turn in it at 9.3 miles...
    haha
  11. Aug 25, 2014 at 11:52 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    That sucks man let us all know if you ever find a 10 mile road in Kansas, I feel your pain I hurt with you...
  12. Aug 25, 2014 at 1:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don't drive 10 miles per month in 4x4.
    I try to at least put it in 4x4 every month, but some times I miss a month.
    I use the local gravel parking lot at the boat ramp.
    But you can just go back and forth a few times in your drive way if that is all you have to work with.
    The most important thing that need to be done is that trucks with the TRD OFF-ROAD with Rear Locker *NEED* to be LOCKED at least once a month.
    You don't even have to drive it far. 50' will do if that is all you have.
    Failure to do so can result in the Locker Actuator sticking. I've seen this issue more than once.
    Do not turn the the wheel on pavement or an hard surface with the locker engaged. You can an will cause damage.
    IMO, which isn't much, I don't think by NOT dropping in to 4x4 once a month will hurt the truck.
    I've seen way to many truck that never get used in 4x4 but MAYBE once a year. Never seen one with an issue yet.
    The Locker Actuator is the problem I found.
  13. Aug 25, 2014 at 1:09 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    The only reason they recommend doing this is so the motor that engages the front drive doesn't stick due to not being used. All you have to do is switch into 4WD, then switch back. You can do this on any pavement- just don't do it while trying to park or make a tight turn. Ditto for the rear locker. Hell, you probably don't even need to be driving- all you need to do is to make that motor switch in and out.
  14. Aug 25, 2014 at 2:34 PM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    you can drive around in the backyard too if you want or find a dirt or gravel road.
