4wd won't dissengage, lights flashing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewfoundlandTaco, Mar 20, 2017.
  1. Mar 20, 2017 at 10:11 AM
    NewfoundlandTaco
    NewfoundlandTaco [OP] Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    Wondering if anyone might have some insight as to my problem. I've searched all the threads and the common problem seems to be the A.D.D. for most people but my symptoms seem unique. Past 6 months about every second time I switch to 4HI the green light and 4LO light flashes indicating a problem, but the truck actually goes into 4HI. Then the truck won't come out of 4HI or go into 4 LO. After a while of driving or sitting it'll eventually make a connection again and come out. Seems like a loose connection somewhere or maybe bad switch?
  2. Mar 20, 2017 at 10:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Actuator on back of transfer case. Contacts might need cleaning.
  3. Mar 20, 2017 at 10:22 AM
    NewfoundlandTaco
    Also worth noting I had my chassis replaced August 2016 and I've had this issue since that. But didn't try 4wd until December. Maybe related?
  4. Mar 20, 2017 at 11:03 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    More likely it is the ADD on the front of the truck.
  5. Mar 20, 2017 at 11:04 AM
    excorcist
    Reno, NV
  6. Mar 20, 2017 at 11:16 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Id get underneath it, unplug the connector at the transfer case actuator make sure contacts are clean n plug it back in good (same with front diff actuator if you can) and see if that solves your issue but....
    very possible. take it to the dealer, site that its been happening since the chassis was replaced and go from there.
  7. Mar 20, 2017 at 12:21 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    are you sure you are using it correctly?
    as i thought you had to shift into natural to get it out of 4x4 l or h
    just a though lol
  8. Mar 20, 2017 at 12:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You don't need to be in neutral to switch between 2HI and 4HI. You can even do it while driving.
  9. Mar 20, 2017 at 5:09 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Seriously?
  10. Mar 20, 2017 at 5:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep! You can be going as fast as ~63mph (give or take a few since I don't remember the exact number) and make the switch.
    REDdawn6[QUOTED] likes this.
  11. Mar 20, 2017 at 5:34 PM
    nd4spdbh
    SoCal
    yup its 60mph when it will usually beep and yell at you.
    Though i have switched it in at 80mph somehow, a lil soft thud and it went right in, took it out then tried again and it beeped... but yeah 2hi to 4hi on the fly no issues. Actually goes in easier than if you were standing still.
    REDdawn6 likes this.
  12. Mar 20, 2017 at 7:24 PM
    chop
    chop Well-Known Member
    byron
    British Columbia
    08 Tacoma 4x4 dclb TRD Sport 4.0L
    3"lift , arb front bumper,ome 886 coils, icon xrt leafs goodyear duratraxs firestone air bags
    Front add actuator , just bought one for my self!
  13. Mar 20, 2017 at 7:29 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Looks like I missed a page in the manual. Thanks guys
    EatSleepTacos likes this.
