4x4 Actuator not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma Ride Days, Jun 19, 2020.
  1. Jun 19, 2020 at 12:30 AM
    Tacoma Ride Days
    Tacoma Ride Days [OP] TonI the Tacoma
    Brad
    2004Tacoma
    Hello all,
    I finally got off the couch today to start working on the truck to fix the four wheel drive and have one quick question
    Is the 2004 Toyota Tacoma ADD have a vacuum hose or does it not use one?
    From the picture I have, it has one but I’ve heard these models don’t “need” them and wanted to confirm this. Here are some photos I took
    Thank you all!
  2. Jun 19, 2020 at 6:04 AM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    I think that is a vent hose.
  3. Jun 19, 2020 at 6:45 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I looked in the 2003 FSM (latest I have), and saw this comment. I also thought it would only be a vent, and if there is just the one port, I'd say vent, and the FSM has a mistake, but,...:notsure:. The position and the fact that it has no clamp makes me think only a vent.
    0xDEADBEEF likes this.
  4. Jun 19, 2020 at 6:50 AM
    Wsidr1
    Indiana
    BTW, here is the troubleshoot from 2003. It says the actuator can be confirmed "by sound" when applying 12V and it never mentions having the engine running. So, I am thinking no vacuum is required.
  5. Jul 1, 2020 at 8:03 PM
    Tacoma Ride Days
    Brad
    2004Tacoma
    So would this cause the 4 wheel drive not to engage if the hose was off or broken?
  6. Jul 2, 2020 at 5:48 AM
    Wsidr1
    Indiana
    This is just a guess on my part: I'd say it would not cause it to fail IF it is just a vent. The other vents on the FR/RR diffs are just to prevent pressure build up (when gears are turning) so your seals don't blow out. In this case, a vent may be needed to allow for pressure release when the actuator moves. So, as long as it's not clogged, it would still function as a vent.
    Good luck.
  7. Jul 2, 2020 at 6:04 AM
    0xDEADBEEF
    Maybe have a go at this, its instructions for inspecting the actuator.
  8. Jul 2, 2020 at 6:10 AM
    Wsidr1
    Indiana
    This guy on TTORA repaired his 2001. He mentions removing the "vent hose".
