4x4 conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by II PaCMaN x3, Mar 15, 2011.
  1. Mar 17, 2011 at 8:00 AM
    Cmatt1605
    Cmatt1605 Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    *which*** lol my bad
  2. Mar 17, 2011 at 8:12 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Just to be clear - those prices are *already* wrecking yard prices. New prices from dealer - the transfer case alone is over $3K.
    http://www.trademotion.com/partloca...coma&year=2006&catalogid=1&displayCatalogid=0
    This is why most folks will say the best course is to have a "donor truck" sitting next to yours, from which you can pull all the needed parts. That way, nothing turns out to be missing, and you don't need to make extra back-and-forth trips for various small parts that got left behind but turn out to be necessary.
    Final word: more trouble than it's worth.
  3. Sep 12, 2011 at 11:51 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    Forgive the necro... But starting another fucking prerunner to 4x4 thread will prob make me a walking target...
    Selling my truck is not an option. I've invested too much into it and it has been too reliable for me to take chances on another one that may be a POS. Also I can't get a Double Cab Off Road with a Long Bed, and I need lockers.
    I'm thinking on doing the conversion and I have done some numbers, and I don't think it'll be too bad.
    My questions however are:
    I want to use a FJ Manual Case. There are tons of wrecked FJs here, so thats a plus. What mods will I have to do by using the Manual case vs the Electric case. Apart from cutting, will the 4x4 computer that gets installed take case of knowing whats happening where and turn the right indicator lights on? Or will I have problems setting up the 4x4 hi/lo indicator signs and such.
    This will be coupled with ARB lockers BTW. Since I am already using OBA for AirBags, might as well use it for the lockers I want. :D
    I'm not trying to create a "beast" with SAS and all that because I do not need it, however I do find myself needing 4x4 and lockers.
    I have a relative list of the parts and that looks ok on paper. Installing should not be too hard, I'm just worried about electrical stuff.
  4. Sep 13, 2011 at 12:04 AM
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    there is a bigger headache with the newer tacoma for a 4wd conversion.
    the 1st gen tacomas are relatively not as complicated as compared to a 2nd with all the electronics and such
    ill probably end up 4wd swapping 1st gen when im outta college and its not my DD
  5. Sep 13, 2011 at 8:55 AM
    I Liquid I
    Puerto Rico
  6. Sep 13, 2011 at 3:19 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
  7. Jul 21, 2015 at 9:40 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
  8. Jul 21, 2015 at 9:59 PM
    jerent66
    jerent66 Well-Known Member
    Santa Cruz County
    TRD OFFROAD 6SPD MT 4x4
    :oops:I have w 4x4 TRD OR DCSB, can I convert it into a 2WD Prerunner? Is it possible
    Mast3rSkywalk3r and mahaloTaco like this.
  9. Jul 21, 2015 at 10:08 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    I had to post to this zombie thread lol. Yes, it can be done, but if you're not going to SAS your truck, then don't bother with it. Trade it in for a 4x4, much less hassle and time. You could be enjoying a 4x4 faster than you can find the parts and do the swap.
  10. Jul 21, 2015 at 10:33 PM
    mahaloTaco
    Max
    Los Angeles
    If you are serious, then lets talk. But I am 99.9% sure you are jokingo_O
  11. Jul 21, 2015 at 10:50 PM
    jerent66
    Santa Cruz County
    Guilty as charged:D
    mahaloTaco[QUOTED] likes this.
  12. Jul 21, 2015 at 11:44 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Read here, Luka's build
    https://www.tacomaworld.com/threads/lukas-build.281512/
    Mast3rSkywalk3r likes this.
  13. Jul 22, 2015 at 6:42 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Anything can be done with enough money. Anything. Look at Jay Leno's garage. Guy has bikes and cars powered by GE Turbine engines.
    Because you are asking how much it costs, that tells me you are likely a poor candidate for this project.
    ManBeast likes this.
  14. Jul 22, 2015 at 11:00 AM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Greasy
    It's not that hard, I do have my conversion crossmember sitting around it would make things easier. Find a good trany and tcase. Fronts end all bolt in easy peasy, just sourcing every bolt and nut takes a bit of work. It could be done for less then $3k if get the right deal on parts.
  15. Jul 22, 2015 at 11:32 AM
    #35
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I'm almost done converting my 2 gen. I even used the electronic shift t-case. I finally got the wiring figured out for the t-case and front diff. Let me know if you need info. I've spent the last year figuring out all the details.
    Edit: I didn't use the 4x4 ECU. All wiring and controls is done with relay logic. Simple and reliable. I will eventually post the wiring diagrams after I have time to test it all.
    nj636 and mahaloTaco like this.
  16. Jul 30, 2015 at 5:13 PM
    #36
    mahaloTaco
    Max
    Los Angeles
    Man I would pay someone a grand to do it for me... Im lazy and not experienced
  17. Jul 30, 2015 at 5:59 PM
    #37
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I'm curious if the transmissions are the same between the 2wd and 4x4. :drevil:
    I helped a buddy convert a couple Ford vans to 4x4 years ago. Apples and oranges as far the conversion, but it's a LOT of work no matter the iron.
    Lots of little things will not go as planned. It will never be as tight as a truck from the factory unless you're already a bad-ass mechanic or hire one at considerable cost. I vote trade it in.
    Great troll for a lazy Thursday evening :anonymous:
  18. Jul 30, 2015 at 6:12 PM
    #38
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    You are all so mean
    Well not all hahah
  19. Jul 30, 2015 at 6:13 PM
    #39
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
  20. Aug 5, 2015 at 7:25 AM
    #40
    jowybyo
    Joe
    Baltimore, MD
    The transmissions are similar but not the same. The 4-speed auto in the 2.7L needed the output shaft, speed sensor rotor and tail housing swapped. I believe the 5-speed auto in the 4.0L needs similar changes. It's way easier to just get a donor trans and bolt it up. I chose the hard route because I wanted to keep my transmission. It was low mileage and I knew it's history. In the end it cost me the same as buying a donor but was more work to do the conversion. Most of the conversions I've seen on 4.0L have done a straight swap of the transmission.
    The hardest part of the conversion is finding all the parts. Mechanically the conversion isn't too bad. With a couple knowledgeable buddies and a decent garage to work in, it's pretty easy. I did the majority of my conversion by myself, laying in my driveway (which is a damn wind tunnel) in the middle of January. I just recently figured out how to wire up the transfer case to shift without the 4wd ECU.
