4x4 conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by II PaCMaN x3, Mar 15, 2011.
  1. Mar 15, 2011 at 11:44 PM
    II PaCMaN x3
    II PaCMaN x3 [OP] Member
    David
    Palmdale, CA
    Hello everyone I know this has been posted before but if anyone could help with everything I need to do this or anyone that has done it before could you please help thank you. I have a 2006 double cab 2wd sport it's all stock
    gf1473 likes this.
  2. Mar 15, 2011 at 11:54 PM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    uummm........buy a new truck with 4x4......
    adamv22 and mahaloTaco like this.
  3. Mar 15, 2011 at 11:59 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OP , everytime this topic comes up , the general concensus is that it can be done , but is not worth it .
    Trade in or private sale , and buy a 4x4.
    mahaloTaco likes this.
  4. Mar 16, 2011 at 12:03 AM
    OZ-T
    Peter North
    British Columbia
    Check the sig
  5. Mar 16, 2011 at 12:04 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    x1,000,000
  6. Mar 16, 2011 at 5:03 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Good business opportunity in south, 4wd conversions for people who went 2wd and regret it :D
    Mast3rSkywalk3r likes this.
  7. Mar 16, 2011 at 5:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    http://www.tacomaworld.com/forum/solid-axle-suspension/138316-sas-quick-guide-cost.html
    I'm going to guide you through my SAS, my cost, and my frustration. I will probably convince you to SAS, because it is so utterly amazing. However, it is not easy, and it is NOT cheap.
    Most people should stay with IFS. SAS is intended for the extreme off roader. IFS can handle most courses of the SAS, just not as easy, or as well.
    Here is a pricing guide that I made so I knew how much money I would be out. I'm giving you the part, where I bought it from, and how much it costed me shipped.
    Parts Needed,.....Part Location,.......and Prices
    OIL PAN
    12101-75060 Pan, Toyota Dealer, $100.00
    15104-75020 Strainer, Toyota Dealer, $80.00
    15147-75020 Gasket, Oil Strainer, Toyota Dealer, $30.00
    11494-75010 Plate, Oil Hole, Toyota Dealer, $30.00
    91651-60614 Bolts (Oil Hole plate) (QTY: 4), Toyota Dealer, $15.00
    00295-00103 FIPG (Form in Place Gasket material), Toyota Dealer, $15.00
    STEERING
    Reid Racing Ford Knuckles, Parts Mike, $460.00
    Hi Steer Arms w/ studs, Parts Mike, $220.00
    Tie Rod and Draglink, Sidco 4x4, $155.00
    IFS Steering Box 1989-1995 4x4, Ebay, $125.00
    Borgeson Steering Shaft 450036, Summit Racing, $75.00
    Borgeson 013452 and 014909, Summit Racing, $160.00
    Pitman Arm, Parts Mike, $50.00
    Kartek 11/32" 29 Spline U-joint, Kartek, $110.00
    SUSPENSION
    Front Leaf Springs 5", Marlin Crawler,$342.00
    FOA Emulsion Shocks (4), FOA Shocks,$552.00
    FOA Shocks Charged, Sidco 4x4, $100.00
    F/R Ubolt Flip Kits, Parts Mike,$100.00
    9/16" Spring Hanger (2), Parts Mike, $34.00
    9/16" Shackle Bracket, Parts Mike, $42.00
    Shock Bracket Pair (2), Parts Mike,$36.00
    Shackle Hanger Kit Front, Parts Mike, $50.00
    Shackle Hanger Kit Rear, Parts Mike, $35.00
    Spring Perch Set (2), Parts Mike, $30.00
    Shock Tower Set, Parts Mike, $36.00
    AXLE
    Chromoly Right Side Axles, Superior Axle and Gear, $296.00
    Chromoly Left Side Axles, Superior Axle and Gear, $267.00
    Warn Premium Locking Hubs, Ebay, $80.00
    CTM U-Joints, Longfield, $315.00
    Front Gears 5.38, Superior Axle and Gear, $176.00
    Powertrax No-Slip Front, Just Differentials, $450.00
    Powertrax No-Slip Rear, Just Differentials, $450.00
    Rear Gears 5.43, Superior Axle and Gear, $208.00
    Frame Plating, Ballistic Fabrication, $112.00
    Front Bearing Kit, Superior Axle and Gear, $122.00
    Rear Bearing Kit, Superior Axle and Gear, $90.00
    Rear Frame Plates, Domello Offroad, $120.00
    D44 4:10 Carrier, Sidco 4x4, $50.00
    Toy Flange, Sidco 4x4, $50.00
    BRAKES
    Front Rotors, O'Reillys, $70.00
    Front Pads, O'Reillys, $25.00
    Front Calipers, O'Reillys, $25.00
    F/R Steel Braided Hoses, Summit Racing, $50.00
    Brake Adapters, Sidco 4x4, $50.00
    Brake Fittings, Sidco 4x4, $50.00
    MISCELLANIOUS
    4.5" 9/16 Bolts (20), Sidco 4x4, $50.00
    Stuff, Sidco 4x4, $100.00
    Toyota Long Slip Drive Shaft Custom, Sidco 4x4, $100.00
    WHEELS
    Goodyear MT/R 37/12.5/15R, Craigslist, $700.00
    Tire balancing, Sidco 4x4, $50.00
    New 5 on 5.5" RimsSidco 4x4, $125.00
    FABRICATION
    Sidco 4x4 fabrication work, $2,200.00
    TOTAL $9,363.00
  8. Mar 16, 2011 at 5:26 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    In order for anyone to give you any sort of useful information we need more from you. Like what model truck are we talking about here? Anything already done to it?
  9. Mar 16, 2011 at 7:36 AM
    BlueT
    NorthEast
    Ok but you have way too many things here. Those items are "nice to have" and not necessary. Plus this is going to solid axle.
    If OP is converting 2wd pre-runner to 4wd IFS he will need much less. I doubt it would cost him more then $3000 to get 4wd and everything would be bolt on. so potentially with out the installment cost.
    If he goes to one of the "pull yourself" junkyards he can probably walk away with everything he needs in one day.
  10. Mar 16, 2011 at 7:38 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yeah, just open a dealership that sells 4x4's and save yourself money from having to pay a mechanic to do the conversions.
  11. Mar 16, 2011 at 7:53 AM
    Pugga
    Massachusetts
    Not mine, just the first post from that thread. I'm not even going to pretend to know what's involved with a SAS. But, if you're going to go through the hassle of adding 4wd to a 2wd truck, you might as well have a solid axle.
    Otherwise, I think you're much better off buying a truck that came with 4wd to begin with. I think you'd be hard pressed to find Toyota parts for $3,000. Not saying it can't be done but you'd have to be creative where you find your parts. Plus your truck will be laid up in the shop for a long time while the work takes place.
  12. Mar 16, 2011 at 7:56 AM
    Cmatt1605
    Cmatt1605 Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    all of witch can be done cheaper by finding junk yard parts
  13. Mar 16, 2011 at 8:13 AM
    macgyver
    Brad
    Canton, GA
    witch?
  14. Mar 16, 2011 at 8:19 AM
    BlueT
    NorthEast
    Agree when doing Solid axle swap which would be more expensive and requires space/time to get it done.
    If OP just wants factory 4wd (which is enough for most) then he can buy parts and get them swapped in his own garage over the weekend with his buddy.
    I dont think $3000 is low for going from pre-runner to 4wd.
    Biggest ticket items are
    TC - less then $700
    Front Diff - Less then $500
    Cv's - less then $200
    4wd - computer - less then $600
    Hubs for 4wd - less then $200
    Pig tails for front diff and TC - maybe $200
    Miscellaneous - $600 (including six packs of beer )
    If OP goes to "pull yourself" junk yard he can probably score all above for %50 of price.
    Now when trading in vehicle there is usually loss of $3000 right there for dealer to be able to get truck for sale. Then difference in price of 4x4 vehicle.
    Not to mention all your mods on the truck lost, and you buying used vehicle that you are unsure off.
  15. Mar 16, 2011 at 8:28 AM
    franzcars
    franzcars I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    now im a noob, but i'd think u could just go look at a junk yard and fund a taco 4x4 that was wrecked in the back and c how much they'd want. or just pull everything you'd need off of it. just my thought
  16. Mar 16, 2011 at 8:29 AM
    Pugga
    Massachusetts
    I really want to see someone finally pull this off. Lots of people have talked about adding 4wd using bolt-on parts taken from another parts truck but has anyone pulled the trigger and moved forward with it? Labor would be the biggest variable. If you can do it yourself, your truck will end up being laid up for a decent amount of time or if you pay someone, it'll be expensive but probably a lot quicker.
  17. Mar 16, 2011 at 8:32 AM
    BlueT
    NorthEast
    Thats exactly what I was saying. Some junkyards have sales like $500 for all you can carry out.
    I can carry TC, front diff, computer, wiring. If not I would hit a gym month before to do bench pressing and carry half of the truck on me. :)
  18. Mar 16, 2011 at 8:34 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    hmm... ive been tempted with a SAS on my truck...
  19. Mar 16, 2011 at 9:52 AM
    BlueT
    NorthEast
    True would be nice to see it done and have final cost.
    problem here is
    People with access to tons of 4x4 parts are here in New England but,,,,, if you are in New England then you most likely drive 4x4 already. (unless you are some odd case :D)
    Those who bought 2wd in NE most likely will go to solid axle anyway.
    There are people with know how and access to parts in other sections of US but those most likely will go to solid axle anyway (if they did not purchase 4x4 to start with).
    So that leaves us with people that have 2wd and have no means/knowledge of doing conversion even so they would like to.
  20. Mar 16, 2011 at 11:14 AM
    II PaCMaN x3
    David
    Palmdale, CA
    Ok sorry that was kind if dumb of me..I have a 2006 double cab 2wd sport it's all stock
