4x4 only engages when truck turned off...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nutzo333, Mar 26, 2013.
  1. May 6, 2014 at 12:42 PM
    Nutzo333
    Nutzo333 [OP] FreakShow333
    Cory
    Canada
    Lifted 06 SR5
    6" Fabtech Lift, 315/70 r17 Duratracs, TRD Cold Air Intake MBRP stainless with duel side exit rear exhaust
    Any chance its a wire on the tranny? I only ask cause it was a large patch of slush that kickes my 4x4 off again.
  2. May 6, 2014 at 1:41 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it never hurts* to climb under there and disconnect/reconnect lines and wiring.
    *provided you don't bugger it up in the process, or lose a fight with corrosion
  3. May 13, 2014 at 8:56 AM
    Nutzo333
    Cory
    Canada
    Lifted 06 SR5
    Yeah... I don't think ill gamble with the corrosion. Live in a heavily wintet salted area, so corrosion is plentiful lol. As long as I can still get it into 4x4 one way or another, i won't complain.
  4. May 14, 2014 at 2:39 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Yeah you can get some dielectric grease too for the connectors to prevent corrosion.
    But ya the fact that the light doesn't flash to indicate it is trying to switch makes me think either switch, wiring, or ECU issue.
    I'm not sure of this but if it was a differential wire, I would think the light would still flash since the ECU got the command to switch it.
    You need another guy with a Tacoma so you can start swapping his parts in haha. Then can narrow it down!
  5. May 15, 2014 at 12:52 PM
    Nutzo333
    Cory
    Canada
    Lifted 06 SR5
    Had the front end on axle stands to pull tires for a brake inspection, 4x4 was fully functional again. Later on kicked back to being fussy... then worked for a short bit once I hit some rain. I'm thinking wire. But to figure out which is the pain lol. I'm ceetain its not the dash switch though.
  6. May 15, 2014 at 1:24 PM
    gearcruncher
    Canadain bumper technician
  7. May 15, 2014 at 1:55 PM
    Nutzo333
    Cory
    Canada
    Lifted 06 SR5
  8. May 15, 2014 at 2:32 PM
    Kdoug074
    Kdoug074 New Member
    06 toyota tacoma trd off-road
    Hello guys, new to this forum. I currently having the same issue with my 4x4. If I put switch in 4hi with truck off and then crank the truck, it will work find in both hi and lo. Leaving truck running and switch it back to 2wd then to 4 it will not work.
    It won't do nothing if I crank truck in 2wd. No light flashing or anything.
    Has anyone figured this problem out if so please let me know. I'm in need of help. U can reply or send me a private message on here.
    Thanks in advance
  9. May 16, 2014 at 6:16 AM
    gearcruncher
    Is your truck auto or manual transmission
  10. Jun 9, 2014 at 2:21 PM
    White Bear
    White Bear Well-Known Member
    Louisiana
    Probably have the only 2nd Gen with an 8274 in the world.
    I'll keep this rolling - I have a 2007 w/6-speed doing the same thing - will engage when truck is off, intermittent with truck running. Almost got me in a bind today. Has anyone figured this out yet?
    When I crank the truck, I hear the relay (or whatever it is) behind the glove box click and the 4x light blinks once at the same time as the click, but then won't engage. Thanks.
  11. Jun 10, 2014 at 4:04 AM
    Kdoug074
    Kdoug074 New Member
    It's the front diff actuator. Mine did the exact samething. Mine would work perfect if cranked in 4x4. Until u switch it back to 2wd. Of you take front diff actuator out, then take black housing off. You will see two prongs coming off the motor. U solder both of them and it will fix the issue. It takes only about 10 mins. I did it to mine and it is working perfect now every time.
  12. Jun 11, 2014 at 7:37 AM
    White Bear
    Louisiana
  13. Sep 4, 2017 at 10:08 AM
    TacOoLa
    TacOoLa Well-Known Member
    Jp
    Quebec
    Toytec 3'' lift kit/add leaf bilstein5100
    my 5 littles screw on the plastic cover is rusty like hell!!... someone have this problem too? i try many thing but is stock really hard .... need help !!!
  14. Oct 29, 2017 at 2:44 PM
    TacOoLa
    Jp
    Quebec
    After changed my a.d.d., the 4x4 engage like new!! Thanks guys !
  15. Feb 17, 2021 at 2:52 PM
    #35
    TallguyNaTrd33
    TallguyNaTrd33 New Member
    10' silver coma trd
    Ever any luck on this
  16. Feb 17, 2021 at 2:57 PM
    #36
    Mech1txs
    Mech1txs Well-Known Member
    Troy
    Nor-Cal
    06 single cab manual FJ swapped add delete
    Most likely the electronic aviator on the front diff or transfer case this is a very common issue . There are some good threads on here about this issue .
    sorry actuator!
