4x4 Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joesmith, Oct 4, 2012.
  1. Oct 4, 2012 at 4:54 PM
    joesmith
    joesmith [OP] Well-Known Member
    Alaska
    2005 Access Cab 4x4
    So earlier this summer I replaced the CV shafts as the boots were broken and I was not sure how long it had been in that condition. I also replaced brakes and rotors at the same time. Everything was working including 4x4.
    About a couple of weeks ago, I go to put the truck in 4x4 and the light would just flash and you could hear it trying to engage. I needed to replace the clock spring so I also asked them to take a look at the 4x4 system while it was in the shop. They put it on the lift and the 4X4 engages just fine, but when its on the ground the weight of the vehicle causes something to not line up correctly.
    For further diagnoses they want the master tech to look at it, but its going to cost me 2 hours of shop time ($107/hr). Also since I have an oil leak from the valve cover gasket its a mess under the engine. They are trying to tell me I have a broken engine mount on the truck that might be causing some of the problems, but they won't know for sure until after they look at it further. I didn't see any broken engine mounts when I checked and the truck was not driving funny, but perhaps I am missing something.
    Any troubleshooting tips for the 4x4 or should I just get rid of this lemon and not dump any more money into it? Sooner or later I will be at the point were the more money I dump into it, I need to keep it and not sell it otherwise I will be taking a loss during the sale.
  2. Oct 4, 2012 at 4:56 PM
    Tacoma Mike
    Southern Maine
    Do you have new tires and old tires on the vehicle ??
  3. Oct 5, 2012 at 8:02 AM
    joesmith
    Alaska
    2005 Access Cab 4x4
    No tires are all the same age and none have abnormal wear on them, even did a tire rotation again, that didn't affect anything at all either.
  4. Oct 5, 2012 at 8:08 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Clean out the actuator just in case
  5. Oct 5, 2012 at 9:22 AM
    joesmith
    Alaska
    2005 Access Cab 4x4
    Is it a PITA to remove?
  6. Oct 5, 2012 at 9:32 AM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    damn how many miles are on that truck?
  7. Oct 5, 2012 at 9:35 AM
    joesmith
    Alaska
    2005 Access Cab 4x4
    Just over 123 thousand.
  8. Oct 5, 2012 at 9:42 AM
    anthony250f
    Anthony
    San Diego, CA
    I would know...I dont have one :p
  9. Oct 5, 2012 at 2:13 PM
    joesmith
    Alaska
    2005 Access Cab 4x4
    LOL
    Right now I am thinking off cutting my loses and selling the truck. :mad:
  10. Oct 5, 2012 at 3:30 PM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Front actuator sounds like the probable cause. I have been through 3. They go bad after some time.
  11. Oct 5, 2012 at 6:04 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You are moving while trying to shift into 4hi, right? Nudge the throttle lightly a few times too. Trying to shift while stopped will give the results you are getting, at least most of the time. If your lucky and the sliding clutch lines up, you can shift in while stopped, but its rare for that to happen.
  12. Oct 8, 2012 at 12:10 PM
    joesmith
    Alaska
    2005 Access Cab 4x4
    Moving forward and backward while trying to shift in 4hi does nothing. Something is loose on the drivers side I can feel when I brake hard so I am thinking that whatever is loose might be causing the problems. I guess I will just have to take a good look at it.
  13. Nov 14, 2012 at 7:37 PM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    Likely actuator issues. I've had it happen twice now.
