4x4 Wanna Be Part 2 - SAS Toyota Axle/3Link
Discussion in '1st Gen. Builds (1995-2004)' started by alove0750, Apr 19, 2012.
  1. Jun 7, 2012 at 7:59 PM
    #261
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Now you're just rubbing it in :p
  2. Jun 7, 2012 at 8:20 PM
    #262
    alove0750
    alove0750 [OP] Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    Amen to that, worth every penny
    :cheers:
  3. Jun 8, 2012 at 4:32 PM
    #263
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    :drunk:
    :D Truth
  4. Jun 8, 2012 at 9:46 PM
    #264
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    gonna do an engine swap next? :p
  5. Jun 9, 2012 at 6:48 AM
    #265
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    Hey alove0750,
    The trucks off road capabilities are no doubt awesome.
    How has it been on the road, especially if you have to hit 20 miles of gravel washboard before your trailhead?
    How does it handle going fast on a loose surface?
    just curious
  6. Jun 9, 2012 at 7:55 AM
    #266
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    On road it does amazing, I am very pleased with it. On the gravel backroads it did good. I want to try swapping the coils to see if I could fine tune the suspension. When I did the swap I was mainly going off of some of the other setup I read online.
  7. Jun 9, 2012 at 8:09 AM
    #267
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    Negative ghost rider lol
    I've had good luck with my 3.4 so far. About the only left on my to-do list would be rock lights, CB, chromo all the way around and possible 4.88's w/ high pinion front :spy:
  8. Jun 12, 2012 at 3:45 PM
    #268
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    Ordered some Amsoil ATF today. I'm going to try to get the cooler installed this weekend. I'm going to have it flushed and swapped over sometime soon.
    I also got around to mocking up the trans temp gauge plumbing today at work. I'm probably going to order an Auto Meter gauge and try to install it in my center console, just in front of my shifter (if possible)
    http://www.summitracing.com/parts/ATM-6157/?rtype=10
  9. Jun 12, 2012 at 7:14 PM
    #269
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    This is a good mod to have!
    How were you planning to use the temp sensor? I recommend just using some brass plumbing and making your own T for it to go in the trans fluid line.. thats what I did.
    I run the trans cooler in series with the radiator and my temps are always at or below 160. Even in moab..
  10. Jun 12, 2012 at 9:36 PM
    #270
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    That exactly how I was wanting to set mine up. I haven't seen it done, before now, and after seeing yours I really like that setup!
    Yeah, I'm doing brass on the T.
    What do you mean by in series with the radiator? Do you have any more pics of your setup?
    I'm really glad to hear your having good luck with keeping it cooler. I was worried that it wouldn't even be worth the trouble.
  11. Jun 12, 2012 at 9:47 PM
    #271
    Ripcord
    Ripcord KM6PIM
    Jim
    This is how the lines are run in my setup.
    Hot from trans > in-line temp sensor for the gauge > radiator built in trans cooler > External trans cooler mounted in front of radiator > in line filter > Back to trans.
    The external cooler I use is the B&M 70268, many other 4runner owners use the slightly larger 70264. But, if you are running with the radiator in series, its overkill. Most 4runner guys bypass the radiator trans cooler all together and just go with the external one due to problems with the 4runner radiators..
    I have the fluid going to the external cooler 2nd becuase it is the one that receives the coolest air as it is in the front. so the fluid receives the majority of the cooling effects after it has already been cooled somewhat by the built in radiator part.
    The in-line filter I used was a magnefine, I dont remember the part number, but I think they are universal as its just an in-line thing.
    With the temps. I also am running a new radiator and a stant 170* thermostat as opposed to the stock 180* thermostat. The radiator is just a stock replacement, nothing fancy. the cooler thermostat is recommended for Supercharged rigs only. But, if you need help with engine temps in addition to trans temps, its worth a shot. My engine temps are now usually at 185* per my scangauge.
    The B&M mounts using a set of 4 zip-ties that go through the radiator and the condenser..
  12. Jun 13, 2012 at 6:46 AM
    #272
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    Thanks for clearing that up for me and also thank you for the write up. It's good to have input and instructions from someone who's actually done it and not someone who "heard from one of his buddies" :rolleyes:
    I'm ready to knock this project out now :D
  13. Jun 13, 2012 at 8:21 AM
    #273
    Ripcord
    Ripcord KM6PIM
    Jim
    Good luck!
  14. Jun 19, 2012 at 12:42 PM
    #274
    dtmccray
    dtmccray Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    What tires are on this truck?
  15. Jun 19, 2012 at 12:49 PM
    #275
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    They look like Maxxis creepy crawlers
  16. Jul 9, 2012 at 8:00 AM
    #276
    Newbie123
    Newbie123 Active Member
    2017 4x4 Off Raod DCLB Super white
  17. Jul 9, 2012 at 8:05 AM
    #277
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    x2
  18. Jul 18, 2012 at 10:41 AM
    #278
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    Still trying to find the time to hook up the transmission cooler/gauge.
    I did a little 2,000 mile check up on the solid axle and everything is good, tight and greased. I've done everything from around town, interstate to wheeling it and I couldn't be more pleased.
  19. Jul 25, 2012 at 2:16 PM
    #279
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    I finally got around to finishing up my SAS price list, here's the final verdict. :rolleyes:
    3 Link SAS Price Sheet
    Axle
    79 Toyota; 8” 4cyl  $250.00
    Sierra 8” 4cyl 4.56 gear set  $185.00 + 10% off  $166.50
    Sierra 8” 4cyl master bearing kit  $135.00 + 10% off  $121.50
    Spartan Locker 8” 4cyl  $284.26
    Marlin front axle service kit  $179.00
    Trail-Gear Chromolly Hub Gears  $100.00
    Vented rotors (79 FJ40)  60.00?
    Reman Calipers  Carquest #’s 19-1601 and 19-1600 (94 4Runner)  $79.42
    Raybestos Brake Pads  Carquest # RCD 611 (94 4Runner)  $22.53
    Low profile drain plug  $4.99
    TOTAL  $1,268.20
    Suspension
    Fox Coilovers  12in Travel  $620.00
    Upper Coils  10in with 250lbs  $130.00
    Lower Coils  14in with 350lbs  $130.00
    Fox Emulsion Shocks  12in Travel  $320.00
    Toytec 2in Shackles w/ Bushings  $149.36
    Brackets  $400.00
    TOTAL  $1,749.36
    Transfer Case
    82 Toyota top shift case  $100.00
    Tacoma Passenger Side Adapter  $399.00 + 10% off  $359.10
    Speed Sensor Adapter  $100.00 + 10% off  $90.00
    Creeper Gears 4.7:1 – 23 Spline  $492 + 10% off  $442.80
    TOTAL  $991.90
    Drive Shaft
    HD Front Driveline Kit – Creeper Joint  $229.00 + 10% off  $206.10
    Rear Tube Yoke  $39.68
    Rear Flange Yoke  $58.53
    Rear U Joint  $21.36
    Steering Shaft Joint  $100 x 2  $200.00
    TOTAL  $525.67
    Misc Parts Needed
    Oil Pan  12101-65030  $155.62
    Strainer  15104-62060  $62.78
    Oil Strainer Gasket  15147-62060  $2.05
    Oil Pan Drain Plug and Gaskets  Dorman #’s 090-038 (plug) and 097-115 (gasket)  $2.50
    Transmission Cooler  Carquest # 77421  $41.86
    33x12.50 Goodyear MTR Kevlar  $900.00
    TOTAL  $1,164.81
    Fluids/Chemicals
    Amsoil 75W90 Synthetic Gear Oil  $11.55 x 8  $92.40
    Amsoil Synthetic ATF  $8.90 x 14  $124.60
    Amsoil Synthetic Grease  $5.41 x 4  $21.64
    TOTAL  $238.64
    Shipping
    Inchworm  $93.03
    Marlin Crawler  $20.72
    Trail-Gear  $43.98
    Amsoil  $36.05
    TOTAL  $193.78
    Labor
    SAS and Rear Shock Setup  $1,700.00
    Rear Drive Shaft  $75.00
    Gearing and Installing the Transfercase  $300.00
    Differential Gear Setup  $75.00
    TOTAL  $2,150.00
    Parts Sold
    Front Differential (geared and locked)  $800.00
    Icon UCA’s  $630.00
    Toytec/Bilstein Coilovers  $500.00
    Remington Sendero 7mm Mag  $950.00
    Nikon Monarch 8-32x50SF  $480.00
    Sold Total  $3,360.00
    Grand Total  $8,282.36
    Out of Pocket  $4,922.36
  20. Jul 25, 2012 at 2:30 PM
    #280
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Damn you sold your rifle and scope to pay for a SFA!! I have that same scope it's bad ass
