5 lug 95.5-04 Lowering info for newbs
Discussion in 'Street Trucks' started by Beefed Taco, Aug 5, 2011.
  1. Aug 5, 2011 at 10:45 AM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    95.5-04 five lug suspension is all identical, with the exception of 95.5-97 leaf springs being 4" shorter than 98-04. Important when doing leaf spring mods, like looking for hard to find 3" drop Chassistech leafs, or using 4x4 leafs.
    Websites get the year spans wrong all the time, and Belltech lists their coils for 96-02 V6 or something crazy like that. They fit all 95.5-04 trucks, but extra cabs get the full 2" drop from them while standard cabs only get about 1" due to the weight difference of the trucks.
    Things to know...Chassistech doesn't make drop leafs for 95.5-04 trucks anymore, but 95.5-97 Tacoma can use Belltech drop leafs offered for 89-95 Toyota p/u since they're the same length. I just measured YankeeTaco72's pretaco leafs the other day.
    The 2 most popular coils offered are Belltech and Chassistech, Eibach quit making them.
    Keep your overall tire height in the 25" or less range.
    Here are drop methods and parts available.
    Quality shocks that are firm are always recommended
    3 most popular shocks
    KYB Monomax ($50 something per shock)
    KYB GasAjust ($40 something per shock)
    Pro Comp Toxic ($30 something per shock)
    Mild Drop
    #1. no b/j flip, coils & blocks (usually 2" coils and stock leafs w/ 2-3" blocks)
    Mild Drop for aggressive driving
    #1. no b/j flip, QA1 front coilover conversion & stock leafs w/blocks (usually 2-3" blocks)
    #2. no b/j flip, QA1 front coilover conversion & 4x4 leafs w/all 3 leafs & overload.
    3/4 Drop
    usually ball joint flip & stock leafs w/blocks.
    The foundation of all drops.
    5/6 Drop
    My favorite because it gets rid of all tire/fender gap, doesn't require any special mods other than a c-notch and rear fender trimming, and the leaf spring hangers on the frame don't hit on stuff too often.
    #1. ball joint flip & 2" coil & 3" block with 3" leaf mod (either stock 5 lug pack w/leaf removed, 4x4 pack w/leaf removed, or hard to find Chassistech drop leafs) c-notch
    #2. ball joint flip & QA1 conversion & 3" block with 3" leaf mod (either stock 5 lug pack w/leaf removed, 4x4 pack w/leaf removed, or hard to find Chassistech drop leafs) c-notch
    6/7 Drop & beyond
    Mods needed
    longer upper control arms
    front inner fender modification
    deep c-notch
    cross member notching (requires removing the bed)
    coils required
    have to be in the 3" range
    can be stock ones that have been cut
    can be aftermarket that have been cut
    3" Chassistech
    b/j flip, 3" coils, (or QA1 coilovers) leaf spring mod (3") and 4" blocks.
  2. Aug 5, 2011 at 3:40 PM
    pinktaco808
    pinktaco808 Hot Steppa
    can we have pic in that order to see what you are talking about?
  3. Sep 14, 2011 at 9:44 PM
    ao6902
    ao6902 Well-Known Member
    Arya
    Fayetteville, Georgia
    01 Std cab taco 2.4
    Underdrive crankshaft pulley, k and n filter, dynomax muffler, spectre intake, doug thorley headers
    Question guys, and me and you have already talked a little about this beef, but I want to go with a 3/4 drop but I drive the piss out of this thing. Just wondering how the drop is going to affect the handling, ride quality and reliability of the suspension?
  4. Sep 14, 2011 at 11:19 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    in what way do you drive the piss out of it? DD driving, auto cross driving, taking every turn in a neighborhood at 30mph driving?
  5. Sep 15, 2011 at 8:45 AM
    ao6902
    Arya
    01 Std cab taco 2.4
    Fast cornering, in the neighborhood and everywhere else. Sometimes at 30, bigger curves 60 or 70. Sometimes a little drag racing.
  6. Sep 15, 2011 at 11:01 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    I'm at 5/7 and my truck handles great. Better than anything I've ever owned. It's standard cab, b/j flipped, Belltech coils, KYB Monomax, 4x4 leafs with leaf removed and 4" blocks. The biggest factor to great handling is low profile tires.
    The truck rides on the softer side and not too firm because I use it every day, meaning I chose not to use my friend's Chassistech leafs because they just rode too stiff for me, and the 4x4's with leaf removed ride nice, so do the Belltech coils.
    The truck can driven hard, but when driving them hard, you'll experience front tire rubbing on the front inner fenders unless you're running a size that doesn't rub. It's common, our front inner fenders are low, so tire height is critical.
    If you really want to step up to great handling in front and have complete adjustability, soft to very firm, and be able to raise and lower the front a few inches, the QA1 mod is for you.
    Drops
    http://www.customtacos.com/forum/showthread.php?t=150998
    http://www.customtacos.com/forum/sho...d.php?t=151589
    http://www.customtacos.com/forum/sho...d.php?t=151295
    http://www.customtacos.com/forum/sho...d.php?t=133156
    http://www.customtacos.com/forum/sho...d.php?t=128624
    QA1 coil overs
    http://www.customtacos.com/forum/showthread.php?t=127841
    Tacoma04CA likes this.
  7. Sep 15, 2011 at 11:34 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    if i dont notch the frame and i get a 4" block is bottoming out a big problem, or will it be manageable for a daily? would you say with lo-pro bumps and 4" blocks it would be 2" of travel?
  8. Sep 15, 2011 at 12:57 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    With a 2" block and 4x4 leafs with blown rear shocks, I rode at 1.25" of travel on cut stock stops.
    On low pro bumps, I rode at 2" of travel about.
    My 4x4 leafs netted me 3" about. Middle pulled, 2wd overload sad face.
  9. Sep 15, 2011 at 1:13 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i need to find a way to get rid of my current wheels and get different ones without loosing too much money so i can get the 3/4 kit. Needs more low
  10. Sep 16, 2011 at 9:40 AM
    ao6902
    Arya
    01 Std cab taco 2.4
    So Brian, when u gonna come with that rear QA1 conversion kit with full detailed directions and pictures :D. Not everyone lives in CA and can just swing by ya know.
  11. Sep 16, 2011 at 10:27 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    4" and low pro bumps will hit now and then. In the old days before I designed the low pro bolt on bumps, the only ones of their kind that bolt into the stock holes, I saw some trucks that had 4" rear drops, no notch, and had flip flops you wear on your feet zip tied to the frame. There were like 3 trucks at the meet that had this ghetto setup. 4" technically needs a notch, but 95% of DDing can be done w/o bottoming.
    See pics below, they are 4" blocks.
    The Streetacos bolt on 4-link racing kit for 95.5-04 trucks is available in a kit form currently and I've been taking deposits for a few months now. I'm 90% finished with the first one going to Canada, with 2 more kits to follow. When this first kit is ready to be shipped, I'll finally have a picture of the entire kit layed out. Shipped with instructions of course. It's 99% bolt on with the exception of 4 tabs on the axle housing.
    Simple to install, and the bed needs to come off to do so. Your stock parts can easily be reinstalled thanks to no cutting or welding. It has about $900 in high end parts alone, is a fully adjustable full race kit that can be daily driven, and obviously isn't for everyone. Without knowing exact labor cost yet, it's looking to be about $1500 minus shipping for the complete kit. Cost is 2/3 parts and 1/3 labor.
  12. Sep 16, 2011 at 11:02 PM
    ao6902
    Arya
    01 Std cab taco 2.4
    Aww shit. I assume the QA1 coils for the rear are not included in that kit?
  13. Sep 25, 2011 at 11:58 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Nope...the rear QA1's aren't normally included in the 4 link kit, but can be no problem. It's definitely a pricey kit because the parts are top quality racing parts and they don't come cheap. And that's with no markup on my end. There's a good $900 or so of parts just to build it, and that's minus shocks.
    You can get great handling with normal parts though too. I have the flip, 2" Belltech coils, 4x4 leafs, 4" blocks, KYB Monomax shocks and low profile tire/wheels and my truck hits the turns GREAT. Faster than I need to be going, that's for sure.
    because_minitruck and pirate86 like this.
  14. Jul 28, 2012 at 12:13 AM
    WinnieTabz
    WinnieTabz Member
    Hawaii
    2004 Tacoma S-Runner
    whistle, bumper lights on with corners
    Concerning the 3/4 drop, the ball joint flip would give the 3" drop already?? Or will i need drop springs and shocks??
  15. Jul 28, 2012 at 1:26 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Nope, just get new coils
    yes, just doing the bj flip in itself gets you 3". You don't have to get new springs or shocks, however it is reccomended you replace with stiffer shocks while you are under there.
  16. Aug 26, 2012 at 6:11 AM
    icemantaco
    icemantaco LED BARS/HIDs/TRAIN HORN KITS WHOLESALE
    Isaac "Ice-Man"
    HOUSTON,Texas
    97' Taco in progress
    Kicker door speakers Blue LEDs behind instrument panel Blue LEDs in a/c vent White LEDs in grill 30k hids Pioneer single-din radio Aftermarket tail lights White LED reverse lights White LED dome light Multi-color LED underbody kit w/remote Rear view camera kit But still in progress :(
    Does anyone know how hard it is to do a ball joint flip? Or know of a link in detail of doing so?...thanks.
  17. Sep 4, 2012 at 4:23 PM
    tacowhore
    tacowhore Active Member
    ricky
    hamilton On.
    02 tacoma feeler
    lowering kit K&N cold air intake
    do you find a problem pulling a trailer with the drop?
    my trucks dropped too but im not sure if pulling a trailer will put too much stress on the rear blocks etc...
  18. Dec 13, 2012 at 1:19 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    5 lug is spring under axle so the stress isn't on the blocks, it's on the u-bolts. Streetaco's blocks and u-bolts are both high quality which means you wouldn't have to worry about them.
    It all comes down to what you're towing. Being low and having weight in the bed, or on a trailer means you really should have some sort of assistance, like air shocks or helper bags if you're carrying a lot of weight. With trailers, you can always load the tongue light by shifting the weight toward the rear of the trailer if possible.
  19. Jan 20, 2014 at 6:13 PM
    99minitaco
    99minitaco New Member
    Spud
    Mile high unfortunately
    In the worx 99taco
    Cali combo , shaved front corner lights, billet grill, 7 inch static drop ( for now ) .. Zebra interior , on 18inch boss 304's etc etc
    Ok new to this forum , I've heard and read of people using a 90-94 toy pickup rear end in a Tacoma to tuck wheel in the fender well because it's narrower than the Tacoma rear , so does anyone know how much more narrow it is and does it just swap over or are there little things that need to be done to get it to work ??? Any help would be great thanx :D
  20. Feb 2, 2014 at 7:03 PM
    Chris D.
    Chris D. Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    Depends on what year pretaco rear end you use.
