5 lug 95.5-04 Lowering info for newbs
Discussion in 'Street Trucks' started by Beefed Taco, Aug 5, 2011.
  1. Jul 14, 2020 at 5:33 PM
    #201
    TOY 96
    TOY 96 Well-Known Member
    Nate
    So Cal
    96 V6 5-Lug Enkei 92
    15x7 BGF Rad T/A 215/60R15 2" Drop Front 3" Drop Rear
    I used this from Harbor Freight:
    [​IMG] TOY 96
  2. Jul 15, 2020 at 11:40 AM
    #202
    mtb_taco
    mtb_taco Well-Known Member
    2001 Tacoma
    @Plkyone that is a clean setup. What lip did you mount to your 4runner bumper swap? I'm waiting to finish my QA1 swap.
  3. Jul 15, 2020 at 6:54 PM
    #203
    Plkyone
    Plkyone Well-Known Member
    Thanks a lot. That is a universal “All fit lip” works well and very strong!
  4. Jul 15, 2020 at 6:55 PM
    #204
    mtb_taco
    2001 Tacoma
    Plkyone likes this.
  5. Jul 15, 2020 at 6:58 PM
    #205
    Plkyone
    All-Fit Automotive 2.5 Inch Universal Bumper Lip Splitter Kit - Chin Spoiler Protector for Front or Rear - Lips Protect and Cover Lower Bumper for a Dropped Look - Universal Fit https://www.amazon.com/dp/B01LFUI45Q/ref=cm_sw_r_cp_tai_Np7dFbE12BNND
    You also can go with the 3 1/2” for a super low look! Since I’m going to go about 1” lower with my truck this works perfect!
    ireymon likes this.
  6. Jul 15, 2020 at 6:59 PM
    #206
    mtb_taco
    2001 Tacoma
    Thank you sir.
    Plkyone likes this.
  7. Aug 14, 2020 at 8:48 AM
    #207
    Bakey
    Bakey Member
    2001 Tacoma 2.4L 2WD
    Just picked up a 2001 Tacoma, and looking around at lowering kits from Belltech (443ND) shows they're only compatible with the 6cyl. Can anyone confirm/deny this? Can you use the same kit on the 4cyl?
  8. Aug 14, 2020 at 9:20 AM
    #208
    Plkyone
    Try looking for the DJM kit
    pinktaco808 and Bakey[QUOTED] like this.
  9. Aug 14, 2020 at 9:24 AM
    #209
    Bakey
    Bakey Member
    OEM shocks for this? Bilstein 4600s?
    Thanks for the help!
  10. Aug 14, 2020 at 3:15 PM
    #210
    mdh313
    mdh313 Active Member
    Fort Worth, TX
    '02 2WD 2.4 5-speed
    LCE short-throw shifter kit Hurst shifter, knob, and Superboot, home-made console Volant CAI Redline Tuning QuickLIFT hood supports DJM 3/4 drop with their upper control arms Doug Thorley Header American Racing 605 16x7 wheels--not big but perfect for me Belltech rear shocks KYB Monomax front shocks McLeod clutch Sachs flywheel LCE flywheel and pressure plate bolts Two-inch diameter cat back dual exhaust Throttle body bored .003"
    I put them in my '02 Taco 2.4 2wd, and they were horrible. Way too stiff for a 4-cylinder. It rode hard and bounced several times over bumps. A year later I took them out and installed the DJM 3/4 kit, and it's been great. No problems other than occasional mild front tire rubbing.
    I used Monroe Sensa-Trac shocks for three years and just last month (July '20) I put Belltech 8517 shocks on the rear and KYB Mono Max 565030 shocks on the front. The ride is firm but not harsh--just the way I like it.
    Hope this helps.
    Bakey likes this.
  11. Aug 14, 2020 at 3:20 PM
    #211
    Plkyone
    Bakey[QUOTED] likes this.
  12. Aug 14, 2020 at 7:28 PM
    #212
    Bakey
    Bakey Member
    Plkyone[QUOTED] likes this.
  13. Aug 20, 2020 at 6:00 PM
    #213
    InAComa2004
    InAComa2004 Well-Known Member
    2004 Toyota Tacoma(Base)
    I keep reading about 2" coils, what could would be the best?
  14. Aug 20, 2020 at 7:00 PM
    #214
    pinktaco808
    pinktaco808 Hot Steppa
  15. Aug 21, 2020 at 1:18 PM
    #215
    Plkyone
    I am using the QA1 coil overs and I love them!
  16. Aug 22, 2020 at 11:56 AM
    #216
    AlblineStar
    AlblineStar Toy_builder
    SinCity
    TRD 4x4
    TRD S/C, Doug Thorley Long Tubes, DeatschWerks Fuel Pump, URD 02 simulator, TRD Catback, RCD Lift w/ 33s
    wheel/tire setup?
    pinktaco808 likes this.
  17. Aug 22, 2020 at 12:06 PM
    #217
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Reminds me of my GMC S15 (Chevrolet S10 clone).
    I had coils and spindles up front, leafs and blocks in the rear.
    This was at a time where a lot of people were heating and cutting coils :eek:
  18. Aug 22, 2020 at 6:00 PM
    #218
    Plkyone
    17x10
    255/40/17
    Originally had a 275 40/17 but was too high didn’t like it!
  19. Sep 28, 2020 at 7:08 PM
    #219
    isaac665
    isaac665 Active Member
    Isaac
    SoCal, Ventura County
    2002 tacoma base 5 speed 2wd
    Intake, wheels, 3/3 drop all around, tires and sound system
    What lowering springs are you running? Im about to pull the trigger on some kyb monomax all around would you recommend these?
  20. Sep 29, 2020 at 2:50 PM
    #220
    mdh313
    Fort Worth, TX
    '02 2WD 2.4 5-speed
    I'm running the factory Tacoma front springs. The DJM lowering kit is designed to use the factory springs so you maintain the factory ride quality.
    Yes, I can recommend the KYB shocks.
    pinktaco808 and isaac665 like this.
