5 Lug Regearing BS and Info
Discussion in '5 Lug' started by Shemicals, Dec 14, 2011.
  1. Dec 14, 2011 at 11:01 AM
    Shemicals
    Shemicals [OP] Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    So I see and hear everyone talking about regearing to regain factory power with bigger tires blah blah blah.
    I am asking you wonderful five lug owners what actually happens when the truck is regeared?
    How much do gears go for?
    What is the difference between gear size?
    What is the difference between types of lockers?
    What is the benefit of a locker vs a non locker?
    What happens if i do not but a higher gear ratio with a locker?
    What are the mystical 4.10's i keep reading about?
    When you regear do you get better gas mileage?
    Which gears are best for 2nd gen 5 lugs with 33x12.5 inch tires?
    Where do you acquire said gears?
    PLEASE POST ANY INFO YOU MAY HAVE AND ANSWER ALL QUESTIONS IF POSSIBLE.
    I know i could search but i felt that it would be beneficial for every five lugger to have all the knowledge in one convenient thread.
    Thanks!
  2. Dec 14, 2011 at 6:21 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Lots of questions.....I'll try to answer some of them in a few minutes
  3. Dec 14, 2011 at 6:52 PM
    afd23a
    The Dynamo of Dixie
    Here ya go
    Hopefully some others will reply to add in their opinions.
  4. Dec 14, 2011 at 7:19 PM
    Shemicals
    Build Page
    OOH So knowledgable thanks!
    although one question was misunderstood:
    You'll have better traction offroad but still lack power. You will have also spent a crap load of money to have someone tear apart your diff just to install a locker when for the extra cost of gears you could have power plus traction.
    I meant what if i buy a higher gear ratio without the locker (upgrade to 4.10s or 4.56s but do not install a locker):
  5. Dec 14, 2011 at 7:24 PM
    afd23a
    The Dynamo of Dixie
    Sorry about that, I guess I misread your question. I'll correct it in my post above.
    Edit: Corrected in previous post.
  6. Dec 14, 2011 at 7:29 PM
    Shemicals
    Build Page
    No no my question was posed incorrectly.
    thank you again!
    so i found this
    http://eastcoastgearsupply.com/i-156108-toyota-8-ring-pinion-nitro-gear.html
    but i need a master install kit with it?
    first would this gear fit or would i need a different set?
    also can you show me which master kit i would need? sorry for the derp
  7. Dec 14, 2011 at 7:51 PM
    afd23a
    The Dynamo of Dixie
    That set is for an older toyota 8" third. You need the ones for an 8.4". http://eastcoastgearsupply.com/c-61629-gears-install-kits-carriers-spider-gears-toyota-toyota-8-tacoma-non-eld.html
    They also have a used set of 4.10s for sale. http://eastcoastgearsupply.com/c-121786-used-parts-t100-8-4-used-parts.html
    A master install kit may not be needed depending on who does it, ie. they may already have the parts needed, and the condition of your diff. A master install includes new bearings which you may not need.
    Another option is to buy a third member built with a locker and the gear ratio you want. ECGS sells these as well. http://eastcoastgearsupply.com/i-788575-tacoma-non-eld-t100-tundra-3rd.html This way you can just change out your third member.
  8. Dec 15, 2011 at 6:49 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
  9. Dec 15, 2011 at 6:53 PM
    afd23a
    The Dynamo of Dixie
    When's your's getting done? :D
  10. Dec 15, 2011 at 8:16 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    At the moment, I am done modding my 5 lugger. I am saving money to buy a 4x4. I still have a set of 4.10 ring and pinion that still needs to be installed. I decided not to buy an ARB locker for my 5lug, instead I would like to install it on a 4x4 (but not necessary if I get a TRD Offroad). Besides, I really like the poor man locker. This method has really worked in my favor a few times. :cool:
    Did you get your flange situation taken care of? What gears are you running?
  11. Dec 16, 2011 at 2:48 AM
    aggiepack
    aggiepack Well-Known Member
    Nate
    [**SOLD**] '08 Super White reg. cab waiting for the '16
    Fat Bob's 5 lug 2."75" Lift Kit, Fat Bob's Performance 8000 Rear Shocks, 235/75/15 BFG A/T tires, UWS Low Profile Tool Box, AVID Off Road Sliders, Chrome Grille Assembly, Fog Lights, Black badges, Tinted Rear Window, TRD Bed Mat, TRD Off Road Floor Mats, Maglite Mount, CoverKing Seat Covers
    New 4x4 woohoo!! which means a new build thread by harrelsen!! :D
  12. Dec 16, 2011 at 5:17 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Thanks! Ialready have a mod list in my mind. LOL.
  13. Dec 16, 2011 at 5:31 AM
    afd23a
    The Dynamo of Dixie
    All taken care of. Got the right flange and the third installed a while back. 4.10's with a clutch type LSD. Pretty happy with the setup for the type of driving I do, mostly on road with a few trails to get to hunting spots.
    Good to see around again harrelson.
  14. Dec 18, 2011 at 1:43 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Thanks, it is good to catch on TW. I have had a tough semester. So I have more time to chime in on TW and other forums.
    Did you do the 3rd diff swap yourself?
  15. Dec 18, 2011 at 3:43 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Wife gave the OK to get new gears after the holidays!
    Thoughts on 30's and 4.10...
    Good match?
    Have also seen 3.90 set on the ECGS site.
    Also, what about re-gearing before getting bigger tires? What kind of effect might be had from rolling around on my current tires with a re-gear until they wear out. I've got 225/75's now.
  16. Dec 18, 2011 at 3:48 PM
    afd23a
    The Dynamo of Dixie
    I made two attempts which failed b/c I overlooked one thing or another, so I finally took it to a shop and they did it for a couple hundred. I just didn't want to fool with it again. Wouldn't have been too difficult if I didn't forget to swap out the pinion flange the first time. :anonymous:
  17. Dec 18, 2011 at 4:18 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Your stock gears are 3.58, you should be fine to run 30" tires. IMO, any 5 lug should consider regearing when they plan to run 31s and bigger tires.
    I bought a complete 3rd member with 4.10s from a member here at a really good price. But after receiving it in the mail, I was able to determine I was sold a diff with 3.91 gear ratio. I decided to install it anyways, I too had issues with the flange, two different sizes. I just posted it on Craigslist and it sold within one day.
    As for the install, it was easy than I thought. I was going to create a DIY thread for other members, but I have no one to take pictures while I am working. I don't want to stop every couple minutes to clean my hands and take pictures. :D
    TacoPastorius likes this.
  18. Dec 18, 2011 at 4:37 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Obviously, I would be concerned about power loss and fuel economy. I'd still like to keep above 20+ MPGs, you think thats attainable with stock gears and 30's?
    What about like 3.90 and 30's?
  19. Dec 19, 2011 at 8:33 PM
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
    I'm wondering the same thing. I plan on running 33s and was wondering if the 4.10s would be a good match.
  20. Dec 19, 2011 at 8:51 PM
    Stupid hurts.
    Steven
    So☆Cal
    Not yet. :p Instead of getting a full front bumper built, I'm going to slap on some bumper caps to match the lines of the front fenders. For now, as long as I'm running the stock front bumper, the skidplate is staying.
    Btw, truck looks good. Let's go offroading sometime and test those new UCAs and coilovers. Are you eyeballing those used T100 4.10s on EGS?
