5 Lug Regearing BS and Info
Discussion in '5 Lug' started by Shemicals, Dec 14, 2011.
  1. Dec 19, 2011 at 8:54 PM
    Shemicals
    Shemicals [OP] Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    you getting fiberglass?
  2. Dec 19, 2011 at 10:16 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Using the Tire Size Calculator, 3.91 running 30" tires will put you with 'factory ratios'. You should be getting 20+ MPG.
    Not all 8.4" are the same, i.e. Toyota Sequoia are also 8.4", but their gears will not work in our 5 lug diffs. Just because of the design of our carriers.
    V6 Tacoma (2wd) and T100 gears will work on a 5lug diff.
    The key difference between Tacoma 8" and 8.4" is the diameter of the pinion gear shaft. The few guys that have regeared a 5lug have had to purchase a new diff carrier to make it fit.
    BTW, the truck looks awesome lifted. :cool:
  3. Dec 20, 2011 at 12:03 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    gearing depends if you are auto or manual. if auto you should look into 4.30 or 4.56
  4. Dec 20, 2011 at 12:20 AM
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
    Already have the fronts. Just have to get the bumper caps and rear glass.
    Two sets of 4.10s for $30? Damn, if they are for our 8.4", can I go in on that deal with you for a set?
    Hmm, I'm auto. Care to explain?
  5. Dec 20, 2011 at 12:25 AM
    Shemicals
    Build Page
    pics?
  6. Dec 20, 2011 at 12:31 AM
    Stupid hurts.
    Steven
    So☆Cal
    I haven't picked them up yet. They're still at Engage.
  7. Dec 20, 2011 at 9:36 AM
    Shemicals
    Build Page
    you get glassworks?
  8. Dec 20, 2011 at 3:31 PM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    (4cyl 5 speed)
    30's no regear
    31-32's 4.10
    33's 4.56
    I have has ran all of these in diffrent combos and this is the best set up imo all on 15 inch rims btw .
    I currently run 4.88 w/lsd on my 5 lug but would not recommend it to anyone that daily drives thier truck.
    I also have a set of 4.56 for 50 bucks if anyone is intrested lol
  9. Dec 20, 2011 at 3:33 PM
    NakedTacoma
    West Covina
    pretty much nothing that is a 4x4 or a prerunner with a factory locker ..they are 8" rear ends ... the xrunners have the same rear end as us too.
  10. Dec 20, 2011 at 4:06 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    I guess i'll be the first to chime in about about us lowly first gens with the 7.5" rear end. It's really fucking shitty trying to find c-list/used parts on the cheap for this axle...
    Anybody know what other trucks this axle came in? I think it was just a bastard set up for 1st gen tacos. Or did the earllier toyota 5 lug pick-ups use the 7.5" rear end as well?
  11. Dec 21, 2011 at 7:53 AM
    NakedTacoma
    West Covina
    18 w off road tires is dumb lol sell ur rims and get some 15/16. No one runs 18's
  12. Dec 21, 2011 at 7:54 AM
    NakedTacoma
    West Covina
    you are wrong ... not all 1st gen 5lugs are 8.4 .. i think none are . 2nd gen 5 lug yes . some first genn prerunners (6lug) are 8.4
  13. Dec 21, 2011 at 8:23 AM
    87xjmike
    Folsom
    98 5lug 2rz
    all first gen 5lugs are 7.5's according to my research.
    I did however get a lot of contradicting info online untill i read it in the manual and id'd my axle.
  14. Dec 21, 2011 at 8:16 PM
    Shemicals
    Build Page
    pmd about your 4.56's
  15. Dec 21, 2011 at 11:48 PM
    #35
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    1st gen 5 lugs use the 7.5 and the older toyota pickup minis use the 7.5 diff. i know this because brian (beefed taco) used an 80s pickup axle because its narrower. but he swapped over brakes and 3rd fron his tacoma axle.
  16. Jan 22, 2012 at 6:27 PM
    #36
    TacoMeat
    TacoMeat Member
    Dave
    NC
    09 Timberland Mica Reg Cab 5-lug
    Intermittent wiper switch, Fat Bob's spacer and AAL, Dealer-installed power windows, door locks and keyless entry
    Another option is to buy a third member built with a locker and the gear ratio you want. ECGS sells these as well. http://eastcoastgearsupply.com/i-788575-tacoma-non-eld-t100-tundra-3rd.html This way you can just change out your third member.[/QUOTE]
    In searching for the 8.4" third member assemblies I came across the Just Differentials website. Looks like they could also set up anything you want. Not too cheap though. Just thought I'd mention it.
    http://www.justdifferentials.com/in...d=2578&zenid=308f115926f6f98aec9807e30cb0b61b
  17. Mar 9, 2012 at 10:57 AM
    #37
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Hmmm, I guess I am nobody and dumb with my 18" rims. Thanks for the comment.
  18. Mar 10, 2012 at 2:32 PM
    #38
    NakedTacoma
    West Covina
    Yea you are ... Most Trophy truck run 17 and they r seeing more harsh roads then u Will ever see not to mention the stress on ur stock wheelbearings with 18inch rims plus tires . So stfu and gtfo
  19. Mar 11, 2012 at 12:50 PM
    #39
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Whoa hey now you're not supposed to be an asshole, I AM.
  20. Mar 12, 2012 at 1:30 PM
    #40
    NakedTacoma
    West Covina
    We can share lol
