5 lug shocks
Discussion in '5 Lug' started by DBtaco2003, Mar 21, 2022.
  1. Mar 21, 2022 at 6:33 AM
    DBtaco2003
    DBtaco2003 [OP] Member
    2011 black 5 lug
    Will bilstein shocks fit 5 lug? It says they’re supposed to lift the front 2.5 inches and I just want the front level with the back so that should be good if they fit
  2. Mar 21, 2022 at 7:02 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Unfortunately those wont fit. We 5 lugs need the 5 lug specific bilstein shock
    Left
    https://www.amazon.com/dp/B009FU6WSA
    Right
    https://www.amazon.com/dp/B009FU6Q4U
    Now these shocks don't lift so you will need a spacer in the front to level. Here is a good source of info on 5 lug suspension
    https://www.tacomaworld.com/threads/the-lifting-your-5-lug-guide.518620/
  3. Mar 21, 2022 at 7:07 AM
    DBtaco2003
    2011 black 5 lug
    What’s the point of getting the shocks and spacers if the shocks don’t lift? I’m just curious this is my first vehicle I’ve considered lifting
  4. Mar 21, 2022 at 8:12 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    The spacer is what does the lifting and the shocks are wayyyyyyyyyyyy better than stock. Like mine were pretty blown when I finally changed mine out.
  5. Mar 21, 2022 at 8:15 AM
    DBtaco2003
    2011 black 5 lug
    Are there any other front end parts I should swap out other than the shocks ?
  6. Mar 21, 2022 at 8:17 AM
    DBtaco2003
    2011 black 5 lug
    And what brand spacer did you go with
  7. Mar 21, 2022 at 11:55 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I did the 3" ebay spacer because I wanted more lift than level. There are smaller sized spacers out there. The general leveling kits are 2.75" in the front and 2" in the rear.
  8. Mar 21, 2022 at 11:57 AM
    DBtaco2003
    2011 black 5 lug
    Im not even worried about the rear. But what suspension parts other than shocks should I swap out
  9. Mar 21, 2022 at 12:09 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    If your not worried about shocks just throw a spacer in and send it. You only need the spacer if you want to lift but we usual suggest new shocks all around because they stock ones are usually bad and the new ones will make a big difference.
  10. Mar 21, 2022 at 12:16 PM
    DBtaco2003
    2011 black 5 lug
    Thanks man. I know only the spacers lift it but I also know know they’re supposed to wear down my suspension quicker
  11. Apr 24, 2022 at 9:41 AM
    LegionZer0
    LegionZer0 New Member
    Zer0
    2005 Tacoma
    Hey, Zero here and first time poster.
    I'm getting an 05 5 lugger for basically free, and looking to do some mods. I'm interested in going with a shackle flip and the fat bobs lift, but looking into higher quality shocks that will be long enough. Any suggestions?
  12. Apr 24, 2022 at 5:41 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    For the front I would do the Bilstein 4600 meant for our 5 lugs paired with some polyurethane bumpstops.
    For the rear you can do a Bilstein 5100 or any shock meant for a 6 lug 0-1" lift.
    LegionZer0 likes this.
  13. Apr 24, 2022 at 5:52 PM
    LegionZer0
    Zer0
    2005 Tacoma
    Just clarifying, that's with the shackle flip and add a leaf?
  14. Apr 24, 2022 at 6:28 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Either or both. Just make sure it's for a 6 lug 0-1"
    LegionZer0[QUOTED] likes this.
  15. Apr 24, 2022 at 7:00 PM
    LegionZer0
    Zer0
    2005 Tacoma
    Awesome. I see a lot of people are going for bilstiens. Is this preference or lack of options? I was looking at kyb struts and shocks, but if that's a bad option, a heads up would be awesome before I spend my money.
  16. Apr 24, 2022 at 7:31 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Kyb wasn't really a thing when most of use built our trucks. I know a few users have used them it's just the Bilstein is more popular
