5 lug truck maintenance ?
Discussion in '5 Lug' started by TacoMan1911, Jan 3, 2013.
  1. Jan 3, 2013 at 7:15 PM
    TacoMan1911
    TacoMan1911 [OP] Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    Hey guys,
    This is my first post and I just bought this truck. So far so good. Owner took really good care of it and it only has 35,000 miles on it. I really want to keep it up, so I had some maintenance questions. The previous owner said that it always had the oil changed at the dealer and tires rotated, but that's it. Do I need to change anything else like rear differential oil or anything. What about coolant or that kind of stuff. The maintenance guide just says check it all but not to replace it. Any suggestions would be greatly appreciated. I hope to keep this thing a long time.
    Thanks!!
  2. Jan 3, 2013 at 7:17 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    I didn't change diff and tranny fluids until 80,000 I'm pretty sure. You don't need to go to the dealer to get the oil changed and tires rotated unless you get it for free. Seemed like it always ended in a hassle for me
  3. Jan 3, 2013 at 7:26 PM
    TacoMan1911
    LA
    Ok, was your diff fluid really dirty at that mileage or not? Just thinking about doing mine because I recently went through some deep water (maybe 14 inches) tops and heard that water can get in through the breather but it sounds like most people don't worry to much about that. Also, did you use a torque wrench or just pliers to take off the filler and drain plugs?
  4. Jan 3, 2013 at 7:28 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    Diff fluid was still clear. Not much dirt gets in there. And i wouldn't worry about 14in, I've put mine through way more than that before i ever changed it. And use a 24mm socket
  5. Jan 3, 2013 at 7:36 PM
    TacoMan1911
    LA
    Alright man, thanks. Will probably wait a couple years then. I never heard of a rear diff going out because someone forgot to change the oil.
  6. Jan 3, 2013 at 7:42 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    A lot of people say change it every 30K but again, nothing really gets in there so i don't see the point
  7. Jan 3, 2013 at 8:15 PM
    TacoMan1911
    LA
    Ok, the money part isn't such a big deal to me, my only fear is over tightening the plugs. God forbid i would strip them out. Did you just snug yours? Or is there a specific torque? They seem like pretty strong bolts.
  8. Jan 3, 2013 at 9:04 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    my diff fluid went 130k and still looked good. went through water that was up to the door too :rolleyes:
  9. Jan 3, 2013 at 9:15 PM
    TacoMan1911
    LA
    Wow!! 130k!!! Guess I was worrying about nothing. Seems like I need to just put 100,000 miles on this thing with regular oil changes and then start doing other things like this.
  10. Jan 3, 2013 at 9:23 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    you can always check it periodically to be safe :p
  11. Jan 3, 2013 at 9:33 PM
    TacoMan1911
    LA
    That's true, maybe every 15,000 miles or so.
  12. Jan 5, 2013 at 8:09 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    35K is nothing...
    just do oil/oil filters and air filters. i did my diff at like 40 something because i was bored. if you do decide to do it, make sure you take out the fill plug first. that thing is a bitch....and you don't want to drain it and then not be able to get the top plug out.
    went 82.5K on the brake pads...could have gone more
    should do the belt one of these days....and maybe even the battery. 7 years is getting up there
  13. Jan 5, 2013 at 8:59 AM
    TacoMan1911
    LA
    Original owner said the battery was just replaced. It is a Bosch battery which I think is a good product. The belt appears to be good, but I guess it's better to change it early rather than be sorry later. Seems pretty easy to work on this truck yourself.
  14. Jan 5, 2013 at 10:30 AM
    81shark
    lots of space in teh engine bay. if the belt looks good, i wouldn't worry. not alot to do maintence wise on these trucks outside of oil and filters
  15. Jan 5, 2013 at 11:53 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    ^^ thats a good thing. more money for mods :D
