5 lug upgrade to electric locking differential?
Discussion in '5 Lug' started by smbrewer, Dec 23, 2012.
  1. Dec 23, 2012 at 8:02 PM
    smbrewer
    smbrewer [OP] New Member
    Brighton, CO
    '08 5 lugger
    New here and got a question:
    I have a 2008 access cab. I understand that in 2009 Toyota added an electronic locking rear differential. Is it possible to "upgrade" to this axle and if so, what else would be needed. I'm just looking for some extra traction in snow and dirt. Perhaps just a limited slip would be better?
    Thanks for any input.
  2. Dec 26, 2012 at 7:30 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    are you trying to swap the whole axle or just the 3rd?
  3. Dec 26, 2012 at 7:36 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    You'd have to swap the whole rear axle to an e-locker rear end.
    You'd need the entire e-locker harness (not sure if you can buy it seperately).
    Module(I believe there's a module to operate the locker.
    Dash Switch
    Personally I would wire it up myself with a wiring diagram.
  4. Dec 26, 2012 at 9:01 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    dont forget youd be making the rear of the truck 6 lug meaning you would need 2 different wheels with different bolt patterns... youd be better off getting an aftermarket elocker
  5. Dec 26, 2012 at 9:10 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Good point^^
    Wondering if you can swap out the 5lug axle shafts into the 6 lug e locker rear end? Either way, the non e-locker six is stronger, so it's better to put a locker in your axle.
  6. Dec 26, 2012 at 9:12 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    might be possible but im thinking spline count is different but you never know
  7. Dec 26, 2012 at 9:12 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    i think i read somewhere that the shafts and spline are the same, so you could have a 6 lug rear and swap it to 5 lug.
  8. Dec 26, 2012 at 9:13 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Waste of time, effort, and money. Just put a after market locker in.
  9. Dec 26, 2012 at 9:14 PM
    95 taco
    95 taco Battle Born
    motor? this is about diffs.
  10. Dec 26, 2012 at 9:18 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    lolz
  11. Dec 26, 2012 at 9:27 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    might be true but then again better safe than sorry
  12. Dec 26, 2012 at 9:29 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Distractions lol
  13. Dec 26, 2012 at 9:31 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    ford 302 swap and a spooled 9" :burnrubber: :D
  14. Dec 26, 2012 at 9:39 PM
    95 taco
    95 taco Battle Born
    yyyyeeeaaahhhh buddy.
    go to a junk yard and tear some diffs down and rebuild them with each others parts. :notsure:
  15. Dec 26, 2012 at 10:06 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    not alot of newer tacomas in every junkyard. most around here dont even get toyotas
  16. Dec 26, 2012 at 11:45 PM
    95 taco
    95 taco Battle Born
    forgot we were talking 2nd ten. :eek:
    that might pose a problem with what i said earlier, because i think that was for 1st gens.
  17. Dec 27, 2012 at 7:54 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Axle spline count should be the same between 5 and 6 lugs for the second gens too. I put a prebuilt third with 4.10 gears and an eaton LSD in mine with no problem. The third was originally built for a Sequoia and the guy I bought it from was going to put it in his 6 lug tacoma. I had to get the pinion flange changed but that was it.
  18. Dec 27, 2012 at 10:13 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Ok first off, a Ford 302 is a pile, if you're not putting a Toyota motor in, the next step down in a Chevy LS (corvette) motor mind you.
    Secondly, an electric locker is not that great. More moving parts, more money to throw into a interesting yet horrible design. You can get away with a regular locker just fine and not have to worry about an electronic connection issue and tire wear.
    Third, if you want to keep the same lug pattern, (you can keep the rear end you have now) swap to an X-runner rear end which is still 30 spline, a little wider and can bolt up to your current rear drive line set up, has locker options and can handle a good amount of HP and torque for the trails.
    But number #3 isn't necessary, its a necessity.
  19. Dec 27, 2012 at 11:32 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Not a fan of chevy parts :spy:
  20. Dec 27, 2012 at 11:34 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Also 1st gen 5 lug is 7.5 6 lug is 8.4 or 8
